Question about Frigidaire Kitchen Ranges
How do I calibrate a frigidaire electric oven?
  • Anonymous Nov 12, 2008
    About every 90 days, I have to recalibrate my new electric Frigidaire wall oven. What gives?
  • 413 Answers
On most ovens, set the oven temperature to either 500 or 550 degrees. Press and hold the bake button until the display changes. (5 to 10 seconds). then press the up/down buttons to adjust the the temp between + 30 to - 30 offset.
Posted on Jun 04, 2008
2 Suggested Answers
SOURCE: Calibration
Electric ovens are calibrated behind the temp knob. Pull the knob straight off of the shaft and look at the back of the knob. There should be a metal slide with a scale and a little set screw. Loosen the screw and move the slide in the direction indicated for your needs.
Posted on Jun 02, 2008
OVEN TEMP AT LEAST 75 DEGREES COLDER THAN IT IS SET AT .CAN I ADJUST THIS FRIGIDAIRE GAS RANGE GALLERY SERIES SELF CLEAN ,CONVECTION OVEN .
I appreciate your post, Ronald!
From the information you have provided you would like to calibrate the oven temperature on your Frigidaire range. I was unable to locate any instructions on how to perform a calibration on your oven. I would recommend consulting with a professional technician for proper calibration of your range. I hope this information is helpful. -Matt
Jan 01, 2015 | Frigidaire Kitchen Ranges
My oven temp is not keeping correct temps set at 350 and acutual temp cooks at 325?? problem correction?
Hey friend, I appreciate your post!
It sounds like your Frigidaire oven could need to be calibrated. If could also be an issue with you thermostat or control panel. In order to properly calibrate your oven you would need to seek assistance from a professional. I would also recommend seeking assistance from a professional for proper diagnosis to avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Oct 04, 2014 | Frigidaire Ovens
Takes an extremely long time to cook in oven, but elements seem to be working
If your oven has a digital timer then it is capable of being calibrated. Usually the oven is pretty close to accurate but can vary sometimes. In your user guide it may explain how to adjust the setting. You need to purchase a thermometer that you can put in your stove. Set it to 300 degrees and time how long it takes to stabilize. It is possible your stove will not get to 300 but to 270 or 280. If this is the case then the thermostat needs calibration. You can find out how to do this out of your guide or in the tech sheet that you should be able to find on line.
Jan 13, 2012 | Frigidaire 30 in. Electric Gallery Series...
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
I need to calibrate an electric oven
Probably. There is often a key sequence that will enable a calibration mode. We need the full model number to find the tech info, or you can probably find it in the tech sheet which is normally taped on behind the control panel.
Oct 13, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
How to calibrate double wall frigidaire ovens. temperatures are not true to digital control.
plaese post model number to assist you further. directions for calibration should be in user manual..
Feb 21, 2009 | Frigidaire 27 in. Electric Double...
OVEN WILL NOT COME UP TO TEMPERATURE
You can calibrate the oven on this model. Press the bake button, adjust the bake temperature up to 550 degrees and then press and hold the bake button until a 0 displays. Now you can adjust the oven temperature up or down to match the display.
Here is a repair manual link that you can use to download frigidaire repair manuals. The one for 30 inch freestanding ranges will have the section on calibrating the oven's electronic control.
Thanks
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
We just purchased a frigidaire professional gas/electric convection oven. It is clearly not heating appropriately. Any ideas?
put an oven termometer in side the oven for about 20 minuts at 250 degrees that will tell you how bad it is. behing the oven knob you will find inside the shafh for the thermostat a small adjustment screw. you can calibrate it.
Dec 07, 2008 | Kitchen Ranges
Calibration
Mar 06, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Kitchen Ranges Logo
180 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
