Question about Cameras
Help with digital camera!
I need a new digital camera that:
1. is less than $250
2. has great zoom (16-18)
3. no shutter delay (must be very fast)
i was wondering if you recommend any particular camera - i've been looking all over
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey xrebecca26,
I am assuming you are referring to zoom range of the lens when you say 16-18. Finding a camera with a 16-18x zoom range for $250 or less is going to be difficult to do, but does have the Canon sx100is in your price range and it has a 10x optical zoom. As far as shutter delay goes most new camera's do a pretty good job at this I would suggest just trying it out before you buy the camera. Shutter delay is caused by the camera having a small buffer where the images are temporarily stored while the camera writes the images to your memory card. Buying a memory card with a fast write speed should greatly reduce shutter delay. I hope this helps!
Go Ahead. Use Us.
Posted on Jun 05, 2008
Nikon D3100 shutter "problem"?
Are your pictures properly exposed and are they sharp or are your pictures degraded? Is that 1/3-second you describe a delay between the time you push the shutter release and the time the picture is taken or somthing else? Check to make sure you're in the proper shutter release mode (slider switch to right of the mode dial). Also, your self-timer may be turned on. Your camera allows you to set a 2 or 10 second delay from the menus. If it is set to 2 seconds and turned on, it might seem like a 1/3-second delay. If that doesn't help, you camera is covered by Nikon's warranty. Contact Nikon Service at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday.
Aug 27, 2012 | Nikon D3100 Digital Camera
At the time of photo taken in zoom please instruct me actual shutter speed & exposer in which better photo is taken pranab
Pranab, When using a zoom or telephoto lens, it's just like using a telescope - a little bit of movement in your hand makes the image jump around a lot. If you take a picture under these conditions it is often blurry. There are 5 things to improve the image quality: 1. Use the fastest shutter speed possible. 2. Since a fast shutter speed captures less light, you also need a wider aperture (that's the size of adjustable curtain in the lens known as the f-stop, a smaller f-stop number indicates a wider aperture). The wider aperture allows more light in. 3. Use a tripod. This works for telescopes and cameras. 4. Bright available light. On a sunny day, there is lots of light available, so you can use a fast shutter speed and still get enough light. 5a. On film cameras use "fast film". This film is more sensitive, meaning it requires less light so you can use a faster shutter speed. 5b. On some digital cameras there is Image Stabilization. The image is electronically stabilized - this is like using a tripod to hold the image still, while allowing the camera to move around a little bit. I hope you found this helpful good luck Al K
Jan 12, 2011 | Garden
Delay between pressing the shutter button and the camera firing. Canon40d
Not sure what you are really asking here as it would depend on the settings you have selected to use.
For instance if your ISO ) ASA film speed) is set to 64 and you have an aperture priority setting of say 6 then the shutter will go clllllllllickkkkk ( be slow say 1/30th of a second. As opposed to say ISO of 200 and an aperture of 16 the camera will go cliick now if you select ISO 400 and aperture of 16 the camera will clk This is the "sports type setting for fast moving objects ) I am presuming daylight average light for the above
after 4pm or in some shade areas shutter speed can also be delayed and the picture result is blurred due to camera shake at low speeds.
then u need a tripod
Now what have you selected as an amateur snapshot artist?
Day night settings
ISO 100 + ........
Any of these settings on auto will also be delayed depending on ISO and the amount of ambiant light available to the camera. So you need to get to know your cameraq by practice
Some settings ( see manual) suggest using shutter priority to get good pics
Others suggest aperture priority.
It might be better for you to get a basic digital photography book to help you understand and compose good pics ( Digital photography for dummies ( or DP basics)
Hers a tip worth remembering with apertures
Smaller the number larger the hole(aperture)
Larger the number smaller the aperture
larger hole for lower light
smaller hole for very bright light
so experiment with aperture to be familiar on what to select for the degree of light then test different ISO speeds and keep notes.
When you use zoom increase the EV by 1+ and see what the difference is to standard distance
All great fun and learning and now cheaper because you dont have to pay for film or development to see what creative pics you have made!
So perhaps the camera does not have a problem, it just has you, and
you need to bond so Good Luck and ,many happy snappy hours of fun
Please rate my help++++Thanks for using FIXYA
Oct 10, 2009 | Canon EOS 40D Digital Camera
Flash Setting Causes Delay
Without seeing the image, it's difficult to pinpoint the problem. But, going on the description you've described here, my guess would be that your shutter speed is too low to record any movement sharply, or is recording movement you are making while holding the camera. Some things that you may want to review with the camera to ensure that you're shooting the images correctly:
First, if you can look at the image using a photo editing program, see if you can review the EXIF (also called metadata) file and look at the exposure. Generally, anything under 1/30th of a second will show motion blur introduced from hand-holding the camera. If the shutter speed is below this, you should consider using a higher ISO setting or opening the apperture (this equates to a lower "F" number, so "F4" allows in LESS light than "F2.8") to allow more light into the lens. Remember that doubling the ISO will allow you to make an exposure with HALF the light. The down side to this is that higher ISO settings, particularly in Point and Shoot cameras, introduce higher levels of noise.
Ensure that you are no more than 10 feet from your subject. Most on-camera flash units are much less effective beyond this distance.
If you are photographing sports/action, remember that a shutter speed of 1/250th of a second will eliminate most motion blur.
Also remember that most point and shoot digital cameras are "one chip" cameras and often have multiple tasks to perform while making an image (focus, exposure, flash, recording and writing the file are all performed at the same time...), so it's not uncommon to see delays (also called "shutter lag") in point and shoot cameras (DSLR's have multiple chips, and don't have this issue...). One way to resolve this is to depress the shutter release half way. This keeps the chip "hot" and ready to expose. Doing this with a point and shoot camera greatly increases the responsiveness to the shutter release.
Hope this helps and happy shooting!
Jul 14, 2009 | Sony Cyber-shot DSC-H9 Digital Camera
D300 long shutter delay
are you using mirror lock-up or live-view feature?
Jun 02, 2009 | Nikon D300 Body Only Digital Camera
Blurred photos
if you are shooting in manual mode or with aperture or shutter priority, be sure your shutter speed is fast enough to avoid blur. hand-held shots are typically safe at 1/250 or faster.
Apr 21, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Olympus mju zoom 140 35mm camera. shutter has started clicking as if taking when zooming (in or out)even when not pressing the shutter button...?
This is like to be the zoom motor playing up.
If the camera is new[1 year or less] return it.
A repair is not a likely option.
Jul 23, 2008 | Olympus Cameras
Sport mode settings
Sports photography requires two things: Long zoom, fast shutter speed, and lots of light. Hey! that's three. Ok. So three things.
With your S3IS, you need to use a fast shutter speed to freeze the action (pitchers' arms go pretty fast!) - I suggest trying at 1/500, then 1/1000 second settings. Your camera won't select that automatically, so set the dial to shutter priority, and select that shutter speed. Then, with that shutter speed, you'll likely need to adjust other facets of your exposure to capture enough light. Zoomed in, you'll have an aperture (f/stop) of f/3.5 - or higher (remember: for f/stop, higher numbers = smaller iris, lower number = wider open iris). With your fast shutter speed, you're now fighting for light, so you need the smallest f/stop number you can get - which will be f/2.7 if you're zoomed out, or f/3.5 if you're zoomed in. If at 1/500 shutter and f/3.5 you still have a dark photo, try bumping your ISO setting up to 200 or 400. If you choose 400 or higher you will have a grainy picture. And will need to use a software noise reduction to clean it up.
With the suggestions above, you'll likely not be blurry, but you may be dark. If this is on a bright sunny day, you'll be fine. If this is at a ball park under the lights you may have different results.
Hope this helps...
Oct 17, 2007 | Canon PowerShot S3 IS Digital Camera
C-2100UZ and low light
If you don't need a zoom, the best film P & S that you can get for what you described is an Olympus! It is the Olympus Stylus Epic which has a very sharp 35 mm f2.8 lens. The f2.8 lens with an ISO 800 or the new ISO 1600 film should fit your bill for low light, fast shutter speed photography. B & H has it for $80. Popular Photography magazine once called it the biggest bargain of all times for no-flash photography.
Sep 11, 2005 | Olympus Camedia C-2100 Ultra Zoom Digital...
Shaking Photography
Here you will find the tips for taking better photos with less camera shaking. Tips 1. Composing and holding the camera with less camera shaking. For clearer images, hold the camera firmly not to cause camera shaking. 1) For maximum stability, hold the camera firmly well over the grip and keep your right elbow lightly pressed against your body. 2) Support the lens or the camera body with your left hand from below. 3) Look into the optical viewfinder as if pressing your forehead to the camera. 4) Do not stand straight, but with one foot stepping forward for taking better balance of your body. 2. Change the composing and holding the camera according to the situation for securer photographing. (Particularly when you take photos using the LCD monitor.) 1) Lean against the wall. 2) Put the camera on a fixed object like a table. 3) Ensure the camera holding by pressing the elbow against the handrail. 4) Use the tripod. 3. Move the zoom control towards wide-angle if your camera has the zoom function. Moving the zoom control towards tele-angle, camera-shaking will easily happen. If your camera has the zoom function, we advise you to take photos by zooming towards wide-angle. 4. Higher shutter speed will produce better images. Slower shutter speed may produce more possible camera-shaking. If your camera has a choice of shutter speeds, we advise you to select higher shutter speed for less camera shaking.
Aug 31, 2005 | Canon PowerShot SD400 / IXUS 50 Digital...
Cameras Logo
63 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
