Question about Volfenhag ZX-8200 Car Audio Amplifier
Volfenhag zx-8200 best sound
How do i make my amp put out most wattage and still be countroled by the remote. i do have my subs bridged, and they are two 12 inch 1200 watt pyramids
    President:
  • 624 Answers
Some of what you say is true, but some is wrong. Sounds like you have a decent knowlege of this but a few misconceptions.
The alternator does not determain what your amplifier's wattage is, it only determains how much current the electrical system in your car will supply. Let's just assume that the wiring is proper and the connections are clean, so you will have minimum resistance from the alternator to the amp (less than .1 ohm). even with a little more resistance, it is still in series and will have very little effect on the amp unless the voltage at the amp drops below the turn on level of the amp. Most amplifiers require 12 volts. Most vehicles will supply 14.4 volts even with not so perfect connections at the battery or alternator. If the voltage at the amp is at or around 14 volts you are good to go.
If you have an amplifier that requires more current than your alternator can supply, you need an upgraded alternator. Your amplifiers ratings do not change. Of course you need to have correct wiring and good clean connections.
By bridging an amplifier, it does not take away from sound quality, don't know who ever told you that, unless you are refering to the fact that it is a mono signal. That is not degraded sound quality, just a mono signal. It does not change the s/n ratio or THD (Total Harmonic Distortion).
The real answer this person was looking for is simple.
The most power you will get from your amp will depend on the impeadance of your speakers, nothing to do with the remote. If your amp is rated at 2 ohms bridged, you can connect 2 subs that are 4 ohms each in parallel and then bridge them to the outputs. That is the most you can get and still stay within the ratings of the amp if it is rated at 2 ohms bridged. I do not know the ratings of your amp. Whatever the rating is in stereo, you can double that for bridged and be safe. Most subwoofers are 4 ohms single voice coil. some are dual voice coils and 4 ohms each voice coil, if you parallel those together it is now a 2 ohm load. It is very important to stay with in the ratings of your equipment, otherwise you can blow up your amp, short your speakers voice coils, ect.
It is important to have speakers that are rated (wattage) a little higher than your amplifiers output, that lowers the risk of blowing the speakers. If the speakers handle more than the amp outputs, they should never get blown. Sometime when you blow your speakers, it then causes the amp to get blown.
The wattage ratings of the speakers have no effect at all on the output of the amp. The ohm ratings of the speakers have everything to do with the output of the amp. The lower the impeadance (ohms) the more wattage output of the amp. This comes from the knowlege of something called "Ohm's Law" (P = E squared over R). Then you must make sure that you have the proper guage wiring for the speakers as well as for the power connections.. The only way to increase power in an amplifier is to lower the impeadance of the load (speakers). Just stay within the ratings of the equipment or you will be visiting somebody like me and paying me to fix your equipment.
And by the way, the magnet is not there to be used as a heat sink, it does not dissipate any heat, it is a magnet, it has an magnetic field, the voice coil is not sinked to the magnet. If it was, it could not move the cone in and out. The signal that goes into the voice coil creates a magnetic field in the voice coil which in turn works with or against the magnet, causing the cone to go in or out. The voice coil is connected to the cone, not the magnet. The actual sound is created from the cone moving in and out creating a change in air pressure which our ears hear as sound.
The super cap people use is for keeping the voltage level up. With a very current hungry system, the voltage from the alternator can sometimes be brought down by a big bass hit. The regulator in the alternator can not always maintain the proper voltage when the current exceeds it's limit. That causes the voltage to drop to adjust to the current draw (more Ohm's Law). The capacitor works kinda like a battery in this case, the capacitor stays charged up since it is on the main power line and when the amp draws heavy amounts of current it drains the capacitor first, before it drops the system voltage. Then the capacitor charges back up again rather quickly and waits until it is needed again.
Posted on Jun 16, 2008
    Scholar:
  • 71 Answers
Your amps wattage is determined first by alternator voltage, amperage, Then all, and I do mean all, the wiring from there to the battery, battery terminal condition, amp connection, wire size, power and ground and the resistance of every connection.
Next comes the amp itself, Is the RMS rating honest ?
Their is no FTC law or standard governing car audio specs.or for that matter, even home theater except for the two front channels, but I digress.
The amp itself comes in a few flavors A, B, AB, D and those are just the basics. except for D most are only 50% efficient.
Why do you suppose they make such good heaters ? ( wasted power)
You also have regulated, non-regulated, low voltage only regulated etc. etc.....
Than their is bridging, It's a generic term for using both voltage rails in the amp to accomplish more power at the cost of sound quality. There ain't no free lunch.
Speaker size or rating has absolutely no bearing on wattage,
The only parameters here are impedance and efficiency (larger is usually a little more efficient and go's lower in frequency). And power handling (voice coil and Magnet assembly (heatsink)
So your options are, custom wound alternator, big wires.a capacitor, only helps for transients (a very short durations of sound) Extra batteries will only give you longer play time before you have to start the car,
It's important to have a properly constructed and internally braced box, 3/4 MDF minimum, well sealed.
In order of SPL, declining power handling and increase in size they are, sealed, ported, and bandpass.
Oh. Did I mention money?
What does a remote have to do with SPL ? Beats Me.
Class dismissed, Sumthin
Posted on Jun 11, 2008
What speakers I can wire to my amp? a volfenhag zx-8200 1000 watt amp. Currently 800 watt bose sub bridged to it, capacitor as well. and a 150amp circuit breaker. I have a 14 volt 105 amp alternator.
1. It depends on how many and what type of speakers you run.
It is a 'bridgeable' amp and therefore has a variable number of configurations.
You can run that Bose sub on one channel and twin up. It's not a great idea to have the drivers max near or lower than the output of the amp and puts out serious thump from a 30W cone.
Jan 15, 2017 | AMP Car Audio & Video
The one terminal on my volfenhag 1000wat amp does not work what could be the problem
It sounds like your amp has lost a channel, based on the testing you have done so far.
Feb 14, 2012 | Volfenhag ZX-8200 Car Audio Amplifier
Volfenhag zx 8200 amplifier cooling fan not working
open the back of your amp and see if the leads from the fan are burnt anywhere. trace them from the fan to where they are soldered into the board. if the wires appear to be fine, then test them using a volt meter. if the positive is not recieveing power you may want to solder the lead to your remote turn on.
Aug 24, 2010 | Volfenhag ZX-8200 Car Audio Amplifier
I want a reliable system.
if you bought that equipment today then your answer is yes your amp will power the subs but if i was you and you want more bass I would go with a two channel amp or even a mono block amp that will be 1 ohm stable and if you decide to do that you might want to get subs that are dual 4 ohm voice coils and run them in series that will get you 1 ohm of resistance
May 19, 2010 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
Zx-8100 amplifier is red lighting.
try wiring them differently. here is a link for u to go to http://www.crutchfield.com/learn/learningcenter/car/subwoofers_wiring.html . once there find your amp configuration (ie. mono, or 2 channel) then down to the type of subs an how many subs ( ie. 2 dvc (dual voice coil) 4 ohm subs) an that will show u how the subs should be wired and wired to the amp.
Mar 21, 2010 | Volfenhag ZX-8100 Car Audio Amplifier
Sub box dimentions
12 " subs need 1.5 cubic feet sealed box...
Jul 17, 2009 | Volfenhag ZX-4812 Car Subwoofer
Zx-8400 amp too much for zx-4812?
The amp and sub combo should work fine the subs can really take a crapload of power-i have a neighbor thats running 1200 watts rms to each sub in his caddy and OMG- its sick. Your amp should be pushing around 800 watts rms(continous) to the sub which should do very well-my concern with your setup is that the sub is designed for a vented box- you can use any box u want but im just suggesting that you use a good solid vented box with these subs- my other concern with your setup is that having only the single sub if its a dual coil 4ohm + 4ohm coils then you might run into trouble if you dont have it set up right-by that meaning to get all the power handling capability of the sub you would want to use both of the coils right? well to do that you have to either wire the coils in series or wire the coils in parallel right? In series the coils will yield an 8 ohm load to the amp and youll only get about 400 watts from the amp bridged into that 8 ohm load- on the other side of that if you wire the coils in parallel then the cols yield a 2 ohm load and that could cause the amplifier to become unstable and fry its little guts. All of this is assuming that the amp is made to run bridged at 4 ohms- if it is 2 ohm stable in bridged mode than you have nothing to worry about. Now the popping noise- that sounds like its coming from the amp somehow and just feeding through to the sub-like you ive never heard a sub popping unless its bottoming out and you say its not so its gotta be the amp id say-if it were me id check all power connections especially the ground for the amp . It could be that on the heavy bass notes that your amp is not getting enough juice -throw a 3.5 farad capacitor on the power line and see if that helps your system out-
May 22, 2009 | Volfenhag ZX-4812 Car Subwoofer
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Volfenhag zx-8400 amp and ZX-4712DVX subs
First of what you have should work great together....now the next thing is: does the bose system carry powered speakers if so the spliced speaker wires should be put onto a converter(a small box with RCA outputs) then you should make sure the levels in the little box is not set to full but 75%, if set to full you can be looking at distortion. Then they should set the amps to full range and see what you get.........oh and by the way you don't have to use that little controller(with the telephone wire) for the bass. You can control the bass with the frequency controllers on the amp or your head unit. And it's not a german thing trust me they come with nearly all amps now. These guys are full of ****. If you don't get the punch you want they should try bridging the amp for more of a punchy sound. Oh and you can use that decent sized box with the vent holes......that should work fine.
Jun 15, 2008 | Volfenhag Car Audio & Video
Volfenhag ZX-8200 Car Audio Amplifier Logo
178 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
Professor_V
Professor_V
Electro Med Services...
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
