Question about ASUS M2N32-SLI Deluxe/Wireless Edition ATX Motherboard (1254095)
Video error beep codes not video problem
I have 2 computers connected to a KVM switch. i shut down to connect a new monitor and when i rebooted i am receiving 1 long beep and 2 short beeps on my ASUS system, which should indicate a vid card error. the second system booted up perfectly and the monitor works fine. after removing and reinstalling card several times, i sent my vid card in for warranty replacement. i installed the new card when it arrived, and still have problem. i connected another power cable to the card with same results. i have removed and reseated the memory modules (just in case). could problem be CPU? could CPU need to be reseated? any help would be appreciated.
  • Anonymous Aug 17, 2008
    i have the same problem my machine was working fine i restarted and got error beeps one long two short, did you manage to get yours fixed?
    Sergeant:
  • 284 Answers
Sounds like Bad Memory chips try just using one chip. even though youve replaced the video card. so im guessing memory could be bad, at least one of them.
try not reseating them but just using one at a time in the slots
also yeah reseating the CPU can help too, an over heating CPU will still boot up, but not advisable. make sure heatsink is present and fans are working. thermal grease is good too on cpu.
but check memory if you have mixed memory like 128mb and 512mb chips try smaller one first if it works then try the higher one.
but sounds like a memory problem, they can go bad almost instantly.
GL
Posted on Jun 05, 2008
What is the best way to connect 2 computers to this monitor
If you have two separate computers for different purposes, such as personal and work use, you may find it convenient and necessary to connect both to a single monitor. Many monitors have dual inputs, making such a connection simple. However, you might need a keyboard, video and monitor switch to accomplish this task if the monitor lacks a second input. Dual Inputs
Step 1 Examine the back of your monitor for the presence of dual video inputs, such as a single VGA and DVI or HDMI output.
Step 2 Connect the VGA cable to one computer. Plug the other end of the cable to the matching input on the monitor. Rotate the retaining screws until tight at both ends of the cable.
Step 3 Plug the DVI or HDMI cable into the back of the second computer. Insert the other end into the monitor's digital video input. Screw down the retaining screws if you're using DVI.
Using a KVM Switch
Step 1 Ensure both computers are turned off. Place the KVM switch on your desk where it is within convenient reach.
Step 2 Locate the video output port on the back of the KVM switch. Plug a VGA cable into this port. Plug the other end of the VGA cable into the monitor.
Step 3 Plug the VGA monitor outputs from each computer into the inputs on the back of the KVM switch. Tighten the retaining screws down for each connected VGA cable on the computers and the KVM switch.
Step 4 Plug the keyboard and mouse cables into their respective outputs on the KVM switch. Plug each set of keyboard and mouse cables from their ports on each computer into the matching inputs on the KVM switch. Plug each cable in sequentially to avoid mixing them up between machines.
Step 5 Double-check that the mouse, keyboard and monitor cables leading from each computer all correspond to the right machine. Plug the KVM switch's power cord into a nearby AC outlet or power strip.
Step 6 Turn the computers and monitor on to verify the connections are correct.
Required Items
  • VGA cable
  • DVI or HDMI cable
  • KVM switch
  • Power strip (optional)
Jun 13, 2014 | Acer 22" X223w LCD Monitor
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
Avocent KVM switch keeps turning off and on, blinking, then turning itself off again. Is it in a display mode??? When it comes up, it will display the video output from the computer. KVM...
the switch should beep if you switch between channels or Ports.
It seems that you might want to download the manual and try to reset the unit. If this doesn't work call their support. Avocent has free support as far as I know.
Jun 03, 2011 | Avocent SwitchView 10040-SC 4-port KVM...
I just buy a new computer and go to hook up my KVM switch that I was previously using and was working flawlessly. All cables are connected (KVM PS2) except the KVM video cable to computer # 2. So I'm...
I would look first at rep;lacing the cable itself, KVM's usually last a very long time. Cables can break down after awhile. The easiest way to check is to try the other cable on the new machine., or a pin could be bent on the cable.
I would look at those two things first before the KVM. IT is possible that the KVM may not support the new machine, depending on how old it is.
Jan 18, 2011 | Belkin 2640-FTUA 2-port KVM Switch
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
KVM is Starview SV411. I'm Testing Windows 7. The problem occurs with all versions of Windows 7 but does not occur with previous versions of Windows nor with Linux. I set the display to 1680x1050 on...
The KVM switch you have did not support "Active Full-time DDC" which Windows 7 need to keep communicating with all connected systems over the KVM switch. Two solutions: find a DDC Ghost adapter put in between the KVM switch and connected Win 7 system. Or just replace a new KVM switch which support Full-time Active DDC function - such as ConnectPRO new PR or UR serial KVM switches.
May 05, 2009 | StarTech.com StarView SV411 4-port KVM...
Channels missing on the box super
Channels on a KVM? A KVM connects a keyboard, monitor and mouse (KVM = keyboard, video, mouse) to multiple computers. there are no "channels".
Feb 09, 2009 | StarTech.com StarView SV211K 2-port KVM...
Causing fatal error when not plug into KVM Switch
dear sir,
her eu have a chek yr kvm switch is connected thru earth.. this becouse some of time eart bypass thru switching yr monitor keyboard and mouses and mosr of time laptop don't face high static electricity.. it's first chance........ other is that yr pc has serious visus problem may be it's face thru Pen drvier or a internet or a some cd's which has infaction before data write in to cd.. so have to cek virus........ one more thing happen if yr pc is connated thru electticity and yr laptop is thru battry that time when u switch yr kvm module it's pass bunch of power so u have to chek all this thing's it's help u...:)
IOGear 2-port KVM Switch
Nov 17, 2008 | IOGear GCS632U 2-port KVM Switch
When I went to use my destop am5100 - b5303a desktop thee light was flashing but couldn't get a signal to monitor reboot the unit twice then shut down the power supply and now the on light doesn't flash...
did you confirm the cable running from the video port on the computer to the monitor is firmly attached? Also did you hear any beep codes. What video card are you using and what operating system. Most likely this problem is 1. bad connection from pc to monitor, 2. graphics card not seated properly in it's slot or 3. defective graphics card. 1 and 2 are easy to fix (1 - tighten connection, 2 - push card back into it's slot on the motherboard) and the case of 3 you'd need to get a new video card.
May 03, 2008 | Computers & Internet
Hyundai monitor connects two computers .how do i switch between them?
Use a KVM (keyboard,video, mouse) switch to connect your 2 computers to this monitor. Then you can also have only one keyboard and one mouse. Connecting to the VGA header with one computer and the digital with another is probably not a good idea and the only way that can work is if your monitor has a built in video switch that can be controlled with software. If that is the case they would boast about it in the user manual and tell you how to activate the switch. VGA KVM switches are relatively in-expensive. Some high end KVM switches will exceed the cost of your monitor.
Jan 18, 2008 | Hyundai L90D+ 19" LCD Monitor
ASUS M2N32-SLI Deluxe/Wireless Edition ATX Motherboard (1254095) Logo
128 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
