Question about Logitech Z-5300 Computer Speakers
Fuse&holder needed lost fuse&fuse holder, where con iget 1.
    Sergeant:
  • 458 Answers
You can get one at Radio Shack. Why is this question in the computer section?
Posted on Jun 04, 2008
Where can I get the fuse holder for a F5A450V fuse for my Micro computer massage chair. My ******** brother lost the housing when he was supposed to get the fuse. Can i use black tape to hold it in?
I believe that your looking for an "in-line" fuse holder. These are common and can be purchased from several online sulpiers. Need on pick on similar to the one that was broken. Here's a link to Radio Shack for starters: Fuse holders taps
P.S. Don't use black tape. Fix it right or you could end up starting a fire.
May 22, 2014 | Health & Beauty
LOCATION OF FAN RELAY 2004 COROLLA 1.8
Hi Miguel, The relay for the radiator fan is located in the fuse holder and those for the air con, usually in a separate holder close to the main holder. To check the operation of the radiator fan, disconnect the cable from the sensor switch fitted onto the lower tank of the radiator. Turn on the ignition without starting the engine and check the fan is working. If it works and not when the temperature requires it to, the sensor switch is defective and needs replacement. Regards John
Feb 09, 2013 | Toyota Corolla Cars & Trucks
Techwood home subwoofer model psw112 fuse and fuse cap or holder
Unless the same type is found the fuse cannot be fixed into the holder. So it isbest to get this sample to the nearest electronic store and check out th ereplacement type availabe and if the alternative fits the provision.
Othere wise you can solder a fuse wire of the same rating internally to get the set connected.
Jan 07, 2012 | Microwave Ovens
Blown Fuse / SX - 205 / Pioneer reciever
Check the area where the fuse was...it's usually marked on the board or next to the fuse holder. Check the size also, 2 types 5x20mm or 1/4x1 1/4 in. Usually slow blow.
Mar 30, 2010 | Pioneer SX-205 Receiver
I'm looking for a 12A slow burning fuse holder for a sportcraft TX 5.0 treadmill. The treadmill works fine had it for four years, but I lost the fuse holder, I have the fuse I just need the holder.
Hello. Here is a website for the Bussman fuse and fuse holder company. They have many locations and this site will direct you to the one closest to you http://www.bussman.com/
You might also call Radio Shack.
Regards, Joe
Jan 14, 2010 | Computers & Internet
Battery drain. alternator and battery ok. 30 amp fuse in front location shows arc. can't identify what fuse controls. is there a schematic which will show these fuses and their. purpose? ie coutesy lights,...
my battery drain indicator lamp is lit on my 2000 Toyota Camary. i checked the battery and have 12.5 volts when not running and 14.5 volts when running with lights & heater on. since all my other gauges are working ok i'm not sure if its a fuse or what fuse. can you help. altenator shows 14.5 volts when running.
Oct 26, 2009 | 2001 Toyota Avalon
I have year 2000 (Old shape) audi 1.9tdi and the air con has been topped up but is still not working.
You may need to check the thermostat and have your clutch bearing checked for your ac pump.
Jun 01, 2009 | 2000 Audi A4
WHERE DO I GET DRIVERS FROM
WHERE DO IGET DRIVERS FOR GE A730 DIGITAL CAMERS .I LOST DRIVERS DISK
Jun 26, 2008 | GE A730 Digital Camera
Memory loss since changing fuse!!!
The unit will have 2 fuses, or at least a second power supply that is generally connected to continuous power, best bet is straight from the +ve batt terminal. If this power supply has been disconnected or has a blown fuse, then you will also loose memory functions from you radio.
  1. Check first under the bonnet for a memory backup fuse holder that has generally less than 1 amp fuse,
  2. no luck, then about the rear of your fuse box for a fuse holder,
  3. or worst, behind the unit up under the dash. The wire from the back of the stereo on Sonys is generally the RED one for memory backup
restoring this power supply to your stereo will then allow for all your presets to be retained in memory
Good luck, happy to talk to you more about the problem, a "FixYa" rating will help my profile
regards
Graeme
Feb 14, 2008 | Sony CDX-GT300 CD Player
Logitech Z-5300 Computer Speakers Logo
69 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
