Question about Starbucks Saeco Italia Digital Barista Coffee Machine
No longer have instruction manuel
Triangle w/ vertical line showing red. What does this mean and how do I solve? Thank you.
  • 40 Answers
Few possibilities:
Water lines clogged, boiler valve housing problem, flow meter bad, pump is bad, boiler is bad, CPU is bad, or grinder issue. Have a SAECO Authorizes
SErvice Center assist you.
Contact Saeco USA Inc. at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at :
Posted on Jul 17, 2008
How do we install an antenna on our smart tv, we no longer want to use cable carrier
just use the same input port where the cable carrier used to connect or if the tv has another input marked aerial antenna [symbol looks like an inverted triangle (base up) with a short vertical line at the bottom of the triangle].
Oct 03, 2015 | Televison & Video
I have a Sharp SF-2020 pedestal copier. The red triangle dots appeared above the yellow digital copy #. Prior to this, it took over a minute for the copier to "boot up". I added factory toner...
Hi r_finch424,
The blink red triangle means that the toner is completely over and can't be refilled. The toner cartridge comes with on-chip sensor that counts the toner life. To resolve this issue, you need to replace a new toner cartridge.
Hope it helps.
Thank you for using FixYa.
Aug 29, 2011 | Sharp SF 2020 Copier
Image is bright but there is a slight issue - on the left hand side a purple line displays vertically. Anybody knows why is this fault appeared and how could it be solved.
There is three LCD in the projector red, green and blue. If green LCD make any fault mean line or dot or dots then screen show these line or dot in purple color:
If line is very straight and sharp edges then green LCD is faulty and need to be replaced.
If line is not straight and faded edges then some thing in LCD block so your projector need service
Feb 22, 2011 | Sony VPL PX40 Multimedia Projector
Thin vertical red line on my LG 50PC56
First you must clean connector contacts between plasma module and driver boards, if not solve the problem and continuing increment of wide red line, may be you must change plasma module to solve this problem,
May 27, 2010 | Televison & Video
No manuel. Triangle lights on - will not copy/
triangle light (Looks like billiard balls) means that you have run out of toner.
Oct 25, 2009 | Sharp AL 1631 Copier
Red vertical convergant line
convergence Ics you will need two STK392-120 convergence ICs. You can get replacement ICs at the following link with free instructions.
Jan 19, 2009 | Hitachi FDX Series 43FDX10B 43" Rear...
Red light
The triangle dots are "need toner"
the cylinder is "need new drum"
the jagged line W means "paper jam"
Sep 16, 2008 | Sharp AL 1631 Copier
Sony gv-27v42 27" tv picture cuts out after a few minutes
Vertical lines down the center only means that you have a loose connection on the Yoke. Re solder all the connection on the yoke and where the yoke connection meets the main board.75481bd.jpge307a54.jpg
best regards
Dec 21, 2007 | Sony KV-27V42 27" TV
Horizontal line in my TV.
"Guest" obviously has no idea what he is talking about. There is no such thing as "frame section" and if the vertical IC, ramp generator or vertical hold circuits were bad, you would have no vertical at all. If you mean that there are thin white lines at the top 3 inches of the picture, and the top of the picture seems folded back on itself, it means that the pump-up capacitor is going bad in the vertical output circuit. This is a very easy thing to correct but should be done by a qualified tech.
Sep 01, 2007 | Televison & Video
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
196 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
