Question about Toshiba 62HMX84 62" Rear Projection HDTV
62HM15 I just replaced a light engine on this model and it stills doesn't work. The TV tries to restart itself just like with the old engine. I dble checked all the connections and was sure the lamp door was closed and the lamp was peroperly in place. I was told it was the light engine by an authorized Toshiba repair center, but it was not covered under the warranty... any suggestions?
When I turn the TV on the pictuer comes on for a few seconds then the screen goes green but I can still hear the audio? My wife was playing with the remote and may have accidently hit something. Any clues??
Posted on Oct 05, 2008
Same problem with mine...
Posted on Jun 10, 2008
My remote does not work
Remote Code for LCD Coby TV model TFTV2425 - Comcast Help and ...
forums.xfinity.com/t5/XfinityTV.../Remote...LCD-Coby-TV.../916553
Apr 14, 2011 - Remote Code for LCD Coby TV model TFTV2425 ... If your home entertainment device does not respond to the remote control after trying all of the codes listed for your ... I just changed to an hd box andcodes given by comcast did not work. Looked at my old remote notes and that is what I found and it works. Comcast DVR remote won't "select" an input from th...
May 26, 2011
Remote code for coby tvs
Feb 7, 2011
Comcast remote code for Coby tv/dvd
Mar 20, 2010
More results from forums.xfinity.com
Coby tv remote doesn t work Questions & Answers - Fixya
www.fixya.com > Forum > Tags > tv remote doesn t work
Dec 15, 2015 | Coby TFDVD2274 22 in. LCD TV
How do I fix 62HM15 picture. Have sound-No Picture. Have red light steady and Green light blinks 8 times and cuts off and back on.
Usually 8 flashes means the lamp is not lighting.
When most lamps go bad , they physically crack because of excess heat.
The problem is probably the lamp or the ballast, which makes the voltage to light the lamp.
Replace lamp and remember to close the lamp access door after replacing, because the lamp will not light if the door is open an
Jan 23, 2015 | Toshiba 62HM15 62" Television
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Headlight doesn't work
Try checking the fusebox under the engine compartment. You should find fuses for both lights in there. also check your light relays also in the same compartment. You might have a bad relay.
Jun 26, 2012 | 2003 Buick Century
The red light is blinking and the tv want come on
First on this model remove the lamp and examine it to see if shattered inside---customer replaceable and door (unplug set first) is on left side as seen from the front.
With door off remove two brass screws and grasp handle on lamp cartridge and slide it out---with the screws removed the lamp cartridge just slides out--pull it out and look.
Mar 24, 2012 | Toshiba Televison & Video
Will a light from a 62HM196 work on a 62hm15a
I looked up both models and both tv sets have different part numbers so probably not!
techman
May 04, 2010 | Toshiba 62HM15 62" Television
62HM15 Toshiba DLP TV won't respond to remote or control panel
Blinking is a trouble code. Try unpluging for a longer time then hold power button in when pluging back in to try and reset.
Mar 15, 2010 | Toshiba 62HM15 62" Television
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 62hm15a
honestly i dont have any idea about the t-chip but if this chip or repairing your tv cost you a lot then buy a new one. its better to have new than old ones. hope that helps!
CHARCOIS
Sep 14, 2008 | Toshiba 62HM15 62" Television
Toshiba 62HMX84 62" Rear Projection HDTV Logo
127 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
