Question about Samson G-TRACK USB RECORDING MICROPHONE Microphone
Samson im trying to record acoustic guitar and vocals basically using the mic as a condenser rather than using the instrument input (which has the same needing to turn up very high or else theres distortion problem). As you can imagine its a big deal the volume is off as when your recording an acoustic guitar you really need to get the natural sound its plugged straight in to the usb, no adaptors.
    Genius:
  • 1,447 Answers
Try using the instrument input lets see if its going to change something.
Posted on Jun 04, 2008
How do i get levels from my g track mic im using cubase le 5 i only get one side level how do i fix this issue?
The mic is only on the Left channel, and instrument input is on the Right channel. So in Cubase you need to select only the Left channel in your first track, and then only the Right channel in your second track, and then you can record Vocals and Instrument at the same time on 2 different tracks.
May 02, 2011 | Samson G-TRACK USB RECORDING MICROPHONE...
Hi, i would like to buy some sharp microphones, two for lead singers and 6 for musician. can you give me some advice on what types i should get?
Hello
microphones broadly fall into 2 distinct types
  1. Condenser - requires a power source either a battery inside the microphone itself or remote 'phantom power' usually provided from a p.a. mixer.
  2. Dynamic - do not require a power source. Most famous of all is the Shure SM57 (instrument / vocals) and SM58 (lead vocals) used by many musicians and singers around the world.
Condenser microphones are used extensively in recording studios because they are very sensitive and have a better range than dynamic mics. However they are a bit fragile and good ones are expensive. There are plenty of cheap condenser microphones about but they give a rather tinny sound.
If you want the microphones for general band work, especially gigging you will get better value for money with dynamic microphones. These are much less sensitive that condenser mics and are intended for close up work - no more than a few inches from the mouth of the singer (use a pop shield to prevent unwanted noises) or hung close in to an instrument.
There are also 3 different pick-up patterns for microphones. Which ones you go for will depend on the use for which they are intended.
  1. Cardoid - cone shaped directional pick up pattern. These will only pick up sound from in front of the microphone in a cone shape of about 60 degrees. Suitable for general vocals and instruments. Good resistance to feedback. To effectively mic-up a big instrument like a piano you may need to use more than one mic.
  2. Hyper Cardoid - as above but with a much narrower pic-up sone - a cone of about 30 degrees. These are very good for lead vocals as you can drive them a bit harder without risk of feedback or picking up other instrument sounds on the stage (particularly useful if you have a singer who plays an a loud acoustic instrument or a keyboard with built in speakers). THese are okay for using to mike-up an instrument where the sound comes from a small fixed point (saxophone, violin, trumpet, acoustic guitar - provided that the musician stands still) but not much good for larger instruments like pianos or harps. They are also good for mike-ing guitar amps, but only if they don't have a separate tweeter.
  3. Omni-Directional . These will pick up sound from all around. Whilst they can be good for picking up large acoustic instruments or choirs they are very prone to feedback and are not really suitable for public address purposes.
Don't be tempted to buy cheap microphones with permanently fitted cables, especially ones with a standard 6mm jack-plug. Always go for mikes with a balanced (3 pin xlr) cable as they do not pick up as much radio interference on the cable (but only provided your mixer/amp also has balanced inputs too).
Although many professionals swear by the Shure SM57 and SM58 mics mentioned above I personally prefer the AKG D55 a hyper-cardoid which has a longer pick-up range and higher output than the Shures (useful if musicians or singers hang back a bit from the mic) and usually slightly cheaper too. It is really good for lead vocals but makes a good instrument mic too with a nice crisp but warm sound across the frequency range.
For larger instruments, or two backing singers sharing a mike, I use the standard cardoid version of the same AKG (but I'm afraid I can't remember the model number now).
If you want to mike up drums that is another subject all together.
Jan 31, 2011 | Sharp Audio Players & Recorders
Only a dynamic mic works on my lap top not condenser mic
Make sure the 48 volt phantom power is on.
Remember this preamp has TRS BALANCED output. If you run this with a stereo adapter into your laptop, the signal and the inverse will be sent into the L and R channels of your laptop and they will CANCEL!
You need to use a special cable that takes say just the tip of the cable from the ultragain connecting to BOTH the left and right inputs of your laptop.
Sep 21, 2009 | Samson Audio C01upak C01u Microphone and...
Recorded acoustic guitar is fuzzy and distorted
Try anouther Microphone sounds like the frequence sprecturm is to low.
Jul 09, 2009 | Samson C01U USB Condenser Microphone...
Cannot record both mic and electric guitar in daw
Disagree with previous post. The GTrack is designed to record vocals and a mono insrtument at the same time. That's its main selling point. It should also allow monitoring of both the vocals and guitar alongside the playback from the computer. In your computer's Control Panel, go to sound preferences, select the usb microphone and click on advanced tab. It is likely yours is set up to record 1 channel at CD quality - this is how many ship for some reason. Set it to 2 Channels CD quality.
In Sonar, set your track input as USB Left for the vocals, and USB Right for your guitar.
Mar 31, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
My acoustic guitar sounds choppy when played back.
Try Using A Condenser Mic Or Making Sure That Your Phantom Power Is Turned Off When Using A Regular Mic.\www.Myspace.com/CrossRoadsToNowhere2007
Nov 06, 2008 | Boss Micro BR Digital Recorder
Tascam DP-02cf
You've got two inputs on the DP-02 so you can record two sources at once.
Depending on how you want the electric guitar recorded (mic the amp, or direct line in) you can in the first case plug your guitar mic into one of the mic inputs on DP02 and plug your vocal mic into the other mic input. You also have the option of plugging the guitar directly into the DP02 (using the hi-z input - I believe it is labelled 'guitar' or something on the DP02. I any event I believe it's the one on the left). This way you only need one mic for use recording the vocal part.
To avoid any 'bleed' between channels you can use the headphones while recording this way and you'll avoid having the unamplified guitar sound coming through over the vocal mic.
Once you have the mics or guitar and mic plugged into two inputs, you need to assign the inputs to a channel (track) to record on. You do this by pressing the select button for the input and then pressing the select button for the track where you want to record the input. Do this for both inputs so that they are recording on different tracks. Then arm the tracks for recording by pressing the record button for each track and the lighted buttons will flash above each armed track. Then just press play and record and you'll be recording. You can go back and redo it as many times as you like and record over what is there, or preserve a take and assign a new track (or tracks) for another take. You've got 8 to play with.
Hope this helps.
bd.
Sep 01, 2008 | Tascam 2488 Portastudio Multitrack...
Inputs
ok, heres what try contacting the support line on your samson mic and ask the setup if you are going to connect an acoustic guitar, there might be some info for it. actually there is here check this out
Acoustic Guitar
There are a variety of ways that the G Track can be used to mic an acoustic guitar. The
microphone placement will depend on the type of instrument and what kind of sound
you’re looking to capture, for example the tonal quality you want to focus on, and how
much finger slide or pick noise you may or may not want. When miking a standard
steel string acoustic, a good place to start is with the microphone positioned pointing
towards the end of the fingerboard at a distance of about 6 inches to 2 feet away from
the instrument. You can experiment by moving the microphone slightly in the direction
of the sound hole, which will produce more low frequencies, or move it in the direction
of the fingerboard to capture more high-end or to remove any unwanted boominess.
For nylon string acoustic, try positioning the microphone above the bridge to emphasize
more of the attack from the sound of the finger picking, or for less, move the mic closer
to the sound hole. If you have a pair of G Tracks, try one positioned at the fingerboard
and the second over the sound hole.
Jun 04, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Can not record vocal and guitar at the same time
The monitoring switch should not affect the recording at all. Maybe you have a defective mic?
Does it record from the line input if you set it to Line In mode?
Mar 27, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson G-TRACK USB RECORDING MICROPHONE Microphone Logo
125 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
