Question about HP LaserJet 1020 Printer
Will not print
When I try to print, I get a message that says either the door is open or the printer cartridge is missing. Neither circumstance is true, can you help?
When printer installed some print ok then some print problem
Posted on Jul 01, 2008
Check print cartridge blinking cartridges refilled today and installed laptop not recognising printer as result
    • If the message on the computer does not identify a particular cartridge (it says only Print cartridge error ), follow the steps below to determine which cartridge is causing the problem.
      1. Open the cartridge access door.
      2. Remove either cartridge (not both).
      3. Close the cartridge access door.
        • If the computer message is Print Cartridge Error , then the print cartridge that is still in the printer is the problem cartridge.
        • If the computer message is NOT Print Cartridge Error (instead, it says that the cartridge you have removed is ...Either missing, not detected, or incorrectly installed), then the cartridge you have removed is the problem cartridge.
  • If the problem still occurs, the electrical contact between the cartridges and the printer might be bad. Removing and reseating the cartridges might help. Also, you can clean the electric contacts on the cartridges with a dry cloth.
Hope that will help solve your problem!
Jan 16, 2010 | HP PSC 1205 InkJet Printer
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kadak Easy Share 5300 printer. Screen reads "Please wait"-stuck
Try this one
Take out the inks and printhead
Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
Close the cartridge door once the cord is unplugged
Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
Thanks Josh - Kodak Tech Support
Aug 12, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Message says that door is open or missing print cartridge
many printer cartage /tray/cover/ and paper are connected with sencer.while one of them are not connect .printer show this you should open all out of cover of printer. then blo w air by air blower, then it can be work. in practic we do this, in our workshope. thanks
Jun 13, 2009 | HP LaserJet 1020 Printer
Front cover dore open or cartridge missing
Try reseating the ink cartridge and see if the cover door is firmly closed.
Mar 27, 2009 | HP LaserJet 1020 Printer
Print cartridge "missing"--NOT
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts):
1. Door A not closed properly. - Open and close door A, then power cycle the printer and check for the error again.
2. The rails that the print cartridges slide in are misaligned or bent. - Remove the Transfer belt and all print drums, then check and re-align print drum rail guide. Then reassemble and verify proper operation.
3. Interlock actuator tab for the front door is broken off. - Check the interlock actuators on the front door if misaligned or broken then replace the front door, if they can be reconstructed then repair. Otherwise call for additional parts.
4. Cable connection to the Engine control board is not seated properly or fully. - Check all cable harness and wires to the Engine control board and make sure proper connection is made.
Check all media trays, access doors, and front cover for proper closure and interlocks being disabled.
Apr 01, 2008 | Xerox Phaser 7700 Laser Printer
No print catridge
The solution above worked on my printer, without power cycling.
1. Remove all paper from the input tray.
2. Open and close the door.
3. Reinsert the paper into the input tray.
Nov 14, 2007 | HP LaserJet 3050 All-In-One Printer
Lexmark x1180 printer all in one
Clean the contacts on the cartidge and printer ( open the replace ink door wait for the printhead to come to center and turn off power) if that does not work then replace cartridge, it might be a recycled one that they did not chane the chip.
Oct 11, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
HP LaserJet 1020 Printer Logo
Ben Johnson
