Question about Dryers
Kenmore 70 Series
I have a Kenmore 70 series gas dryer that is not heating up. I used it one night and the next day it would not heat. However if I continue to restart the timer the clothes eventually dry but not by heat.
gas dryer not heating
  • dminky Jun 15, 2008
    I have a Kenmore 70 series gas dryer (model # 97575110 75751) that is not heating up & the timer stays in the same position. I used it one night and it worked fine and the next day it would not heat. However if I continue to use the dryer the clothes eventually dry but not by heat.
  • Anonymous Jul 15, 2008
    dryer won't heat
  • 177 Answers
You probably have an open thermal fuse, the dryer will run in some cases and not heat, Just moving air across you clothes will dry them however it takes forever.
If you are electrical or mechanical replace the thermal fuse yourself if not call someone you trust, you can purchase thermal fuses on line from just do a parts search for you specific dryer.
Posted on Jun 07, 2008
Kenmore Dryer 70 series electric-quit heating and timer wont shut
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
Nov 24, 2017 | Kenmore Dryers
Kenmore 70 series gas dryer - does not start when pushing the start button
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
May 19, 2010 | Kenmore 77632 Gas Dryer
I have a kenmore 70 series gas dryer. It won't
Check the thermal fuse and thermostats first, then the ignitor and the valve coils are the next possibilities.
Jan 24, 2010 | Kenmore 63942 Dryer
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
My gas dryer stopped heating it is a Kenmore 70 series. I am getting good gas flow but dryer will not heat.
Try this link I hope it helps, I know it helped me a ton!! ps don't forget to rank my help. Thank you and have a nice day!
May 07, 2009 | Whirlpool LGR3624JQ Gas Dryer
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 | Dryers
Kenmore dryer 70 series flame ignites, but goes out after 5 mins
If it's gas, the coil valves get weak and are unable to hold themselves open when hot. First, check the exhaust vent. If it's clogged, it can't remove heat and it will shut off prematurely. Most likely the coil valves though.
Mar 03, 2009 | Kenmore 63942 Dryer
Kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Aug 12, 2008 | Kenmore 63942 Dryer
Kenmore 70 Series
Unless the dryer is extremely old, you do not have a standing pilot. It uses and ignitor or glow coil which could be your problem. It could also be defective gas valve coils or an open thermal fuse. Since it is a gas unit, I recommend you call a technician.
May 09, 2008 | Dryers
Kenmore 70 Series
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
507 people viewed this question
Top Dryers Experts
