Question about Maytag Neptune FAV6800AW Top Load Washer
Uc code error
Will adjusting the locking mechanism solve the problem? what kind of adjustment do i need to make on the door lock mechanism? it keeps giving me a uc code (won't spin)
There's only 1 circuit board right that i need to replace?
Posted on Jun 05, 2008
  • 525 Answers
Uc code means unbalanced condition. My research shows this as being an unbalanced load or a faulty control board.
Make sure your load is balanced, otherwise you may have to replace the control board.
Posted on Jun 04, 2008
Toyota avalon 2000 front drivers side door closes but lock does not lock it to a solid shut....can still pull door open whats happening
Sounds like a badly adjusted door lock. Either the hasp on the door post is too far in, not allowing the lock to cycle to a complete lock position, or the lock is faulty. The hasp can be adjusted, so try that before looking at replacing the lock mechanism.
To check the door lock, open the door and manually turn the lock mechanism until you hear the lock click in place, then using a round object like a longish 8 mm bolt, hook it into the lock mechanism and pull real hard. It should be impossible to turn the mechanism by hand once it is locked.
It is also possible that the hasp (the bent piece of metal mounted on the door post) is too low. This will allow the lock mechanism to slip over it and not close properly.
Mar 02, 2015 | 2000 Toyota Avalon
Jennair oven 8114 p472-60 or p458-60 f9 error code
The F9 error code for this model number Jenn-air range indicates a door lock issue. The control sees it as locked, unlocked, or both at the same time.
The technical manual instructs us to check the wiring to and from the door lock mechanism and if no issues are found replace the motorized door lock.
Mar 24, 2014 | Kitchen Ranges
F9 error code
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen it is clean.
Oct 24, 2013 | LG LWD3081ST Electric Double Oven
F9 error code
F9 problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes the panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen behind it is clean.
Sep 07, 2013 | LG LWD3081ST Electric Double Oven
Flash FDL code
Fdl error code means a "door lock error code".
This error shows up because the door cannot be locked. The door will try to lock six times before displaying the error code. In order to solve it, your door lock switch needs to be replaced.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day
Dec 19, 2011 | Washing Machines
How do you adjust a trunk latch on a 03 Ford Focus Sedan?. The lock mechanism does not engage all the way in the lock. The catch has 3 bolts which can be moved for adjustment.
loosen all 3 bolts, then do them up so that they are pinch tight then push door to close as hard as you can,open door and tighten bolts,close door again to ensure no rattles/leaks and that door locks.keep adjusting till you get it right...
May 04, 2010 | 2003 Ford Focus
It keeps flashing dl-f
Hi here is the meaning of the code and the corrective action needed. If you have any other questions please feel free to comment. Mike
"F/dL" Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Jan 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
#790.95202102/Stove-oven not working right F9 keeps coming on.
hi..
This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced...
thank u
rate me!!!
Aug 14, 2009 | Kenmore Ovens
Washer won't turn on, code FdL appears in timer window, GHW9250M
Hi. this is a Door lock mechanism error. here is a description of the code and troubleshooting tips below.
Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
You may need to replace the door lock mechanism if the wire harness checks out OK. Now, if the wires are connected well and the door lock mechanism if working, this could be a more serious issue concerning the Control board.
You can test the door lock mech by using a volt neelde or multimeter as well. use the connector clips for testing the proer voltage.
Please rate and god bless:)
May 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool glass top oven self clean latch won't engage.
Door latch mechanism is out of adjustment and needs to be adjusted
Nov 14, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Maytag Neptune FAV6800AW Top Load Washer Logo
674 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
