Question about Canon PIXMA Pro9000 InkJet Photo Printer
Unable to share printer
The Canon pro 9000 only has one usb port for connection. What can I do to enable it to have two computers connected?
  • 76 Answers
You will need two computer connected through rj-45 (internet cable) so its network up, then you will just have to share the printer on that main pc and then the other pc will be able to print to the printer as long as the main printer is turnt on.
Hope this make sense
Posted on Oct 24, 2008
Can i hook up my printer to my wireless router and if i can how do i tell it to print when i need it to print
The iP6310D can't connect to the wireless router directly. It has a USB port and an optional blue-tooth receiver.
If you connect the printer to one computer, you may be able to share it using that computer as a server. Install the printer software on all of the machines. For the software, see http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_series/pixma_ip6310d#DriversAndSoftware . For Windows 7 and 8, if you set up a Homegroup, enable sharing for the printer on the computer that it is directly connected to. Then use Add a Printer command from the Devices and Printers Control Panel option to locate networked printers. For other OS options, you'll need to make sure that the computers are in the same workgroup. (See the Network set-up information.) Then add a network printer.
If your wireless router has a USB port, you may be able to connect the printer to the router. Again install the printer software on each computer. Then use the router's software to add a printer on the computer. (For Linksys routers, that is the Cisco Connect software. Some routers may not offer this software for all OS's or for all printers.)
A similar option is a print server connected to the USB port of the printer. You will need to check the specifications for each one. There are some that only work on select printers.
Once the software (the printer driver and then the network software/shared printer is set up), then any program should be able to print following the File > Print command.
Please add a comment with your OS and/or router model, I'll try to walk you through setting up a shared printer or a USB connection on the router.
(Note: I have a USB printer connected and a wired network printer to a Cisco router. My only issue is that I get a printer error with every print job. The printers print the documents anyway. The error is due to the printers not responding to the software as fast as if it were a direct connection.)
Aug 10, 2013 | Canon PIXMA iP6310D InkJet Photo Printer
I bought a canon pro 9000 Mark II printer and just changed all the colors. it now says it is offline and will not print. how can i fix? need to use printer now and stressed to the max
hi there,
have you checked the connection between the printer and the computer to make sure it didn't get loosen or disconnected?
If ok, then try turning the printer off, shut down your computer, reseat the connection between your computer and the printer (both ends of the cable - or can try a different USB port on your computer), then turn the printer and the computer back on in the order described.
Jun 26, 2011 | Office Equipment & Supplies
How do i connect a canon pixma op 4300 to the usb
You can share your printer as a shared printer on your network. This computer and the attached printer must be on at all times to allow other computers on your network to print on this printer.
Please click on this link and follow my instructions on how to setup a shared printer :
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
Jun 20, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Which firewall service is in use ?
The ICS service can be enabled along with teh Port 9000.
start the Windows Firewall/Internet Connection Sharing (ICS) service at the command prompt by using the net start sharedaccess command, you see the following output:
C:\>net start sharedaccess
The Windows Firewall/Internet Connection Sharing (ICS) service is starting.
The Windows Firewall/Internet Connection Sharing (ICS) service could not be started.
A system error has occurred.
System error 16405 has occurred.
Hope this will help you....
Cheers!!!
Vivek
The system cannot find message text for message number 0x4015 in the message file for BASE.
Dec 15, 2009 | Logitech QuickCam Pro 9000 Web Cam
I have an canon pixma mp480 connected to a windows xp home computer. It work fine. I shared the pinter to the network. I got the windows xp connected to that shared printer, but the windows vista computers...
Is the printer connected via USB to the XP computer?
How did you map the shared printer (ie; what port)
When you're on a Vista machine, go to Network, find thw XP computer, explore, can you access the printer through this method? I need to know if Vista machines were set up with this printer on Local Port or Connected to this machine.
Jun 19, 2009 | Canon Pixma MP480 All-In-One InkJet...
Print sharing
No matter how you slice it, if you want to share the printer, you will be creating a network. If I remember this printer correctly, it has an Ethernet port to connect to a network or USB to connect ot a computer. If your router supports wired connections, you can connect it there and just inistall drivers on each device and selec tthe network option. If not, you will probably want to connect it via USB to your desktop machine and enable print sharing on that machine. Te enable printer sharing, open up the Network and Sharing Center. In the Sharing and Discovery section, turn on the option for Printer Sharing. You will still need to install the XP driver on the netbook and select the network option, but give it the proper network location (ie.\\mycomputer\this printer).
May 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer sharing wirh USB hub
I would connect the printer to the main computer, network the 2 computers and enable printer sharing. The only draw back to this is that the main computer will have to be on in order for the other to print. Vista makes this easy to do.
Jan 31, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Panasonic KX P1121 how to choose USB printer port for my laptop
Hi and welcome to FixYa,
Initially, a couple of ideas you may want to try:
  • goto Start (or Control Panel), Printers (& Faxes);
  • if the Panasonic KX P1121 has been installed, right click on its icon;
  • click on Properties;
  • click on Ports tab;
  • scroll down till USB... Virtual printer port fo.....;
  • click to check/enable;
  • click OK button;
  • ensure no Pending print jobs/Cancel Print;
  • try printing a test page;
  • in some instances, a reboot may be necessary;
  • in most instances when installing, the printer through the USB connection should not be connected yet;
  • connect printer to computer through USB only when instructed by the installation program;
  • if errors persist, uninstall, re-do clean fresh installations.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 19, 2008 | Canon LBP 800 Laser Printer
Unable to print to canon IR 2020 when connected through router.
Try to conect directly with cross utp cable to an pc, if every thing works, its your network problem (maybe privilegies, banns,...) if not ... good luck :-)
Try to reconect the pcb s
Dec 10, 2008 | Canon imageRUNNER 2020 All-In-One Laser...
How to redirect lpt print to canon lbp-3000 printer
Here's what you need to do. ON the computer that you want to associate that LPT1 port, you need to know the name of the computer, and the share name of the printer. In this case, I am assuming you have the Canon LBP-3000 physically connected to this system running the FoxPro program.
Step one: Find the computer name. Click on START SETTINGS CONTROL PANEL. Double click SYSTEM. Click on the tab COMPUTER NAME and under FULL COMPUTER NAME, write down the name. Click OK to exit the window.
Step two: Click on START, SETTINGS CONTROL PANEL. Double click PRINTERS AND FAXES. Right click on the Canon LBP-3000 printer and click on SHARE. In the window that opens, click on SHARE THIS PRINTER and take note of the name in SHARE NAME: and write it down. Click on OK to share the printer and exit out of the wizard.
Step three: Click on START, RUN. Type CMD in the box and click OK. in the black window, type NET USE LPT1 \\COMPUTER NAME\SHARE NAME
Follow with RETURN or ENTER and you should be good.
Aug 04, 2008 | Canon LASER SHOT LBP-3000 Printer
Canon PIXMA  Pro9000 InkJet Photo Printer Logo
50 people viewed this question
old marine
old marine
