Jackson 24 in. JPX-300H Built-in Dishwasher
Problem for Jackson 24 in. JPX-300H Built-in Dishwasher
Soap pump
By jwchef on Jun 04, 2008
soap pump runs continuosly after cycle ends
Solution #1
posted on Aug 19, 2008
Not Helpful)
kermit854
Rank: Wiz
Rating: 87%, 20 votes
There are 2 different models of the JPX300H. One has a digital timer assembly, while the other is a cam-timer. Regardless of type, the timing unit is located under the wash tub, which can be accessed by removing the front panel directly below the door. If it is a cam assy (which I think it is), locate the microswitch on the cam assembly for the pump which is running incorrectly and turn the cam so the arm of the switch rides along the outside edge of the cam when the pump should not be running.
If timer is the digital type, then contact Jackson Tech Support for troubleshooting assistance. Their service is free and you can find the phone number at www. jacksonmsc.com
Was this helpful?
Yes
No
Popular Solutions for Jackson 24 in. JPX-300H
Questions and Unsolved Problems for Jackson 24 in. JPX-300H
Do you recommend Jackson 24 in. JPX-300H Built-in Dishwasher?
Answer
Answer
Why does the inside has condensation and the dishes remain wet after the drying cycle?
Answer
I'm trying to find either an owners manual or repair manual - or both for my Maytag WC504... (More)
Answer
It seems to run ok, but about 30 minutes into the cleaning process, we notice a burning smell that... (More)
Answer
how can i wire a jackson dish washer jpx 300h with out the relay useing a contactor
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Jackson 24 in. JPX-300H...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
