Question about ASUS VIA KT133 Chipset A7V133 Motherboard
Pc will not boot
Made invalid change in bio. now need to correct the change but on pc startup 1) no display presented .. 2) this is on a kt133a ( asus a7v133 )
    Sergeant:
  • 284 Answers
Try looking for CMOS jumpers of mother board
you see it near the battery of the mother board CLRTC
here the link for the manual
http://www.nek.uu.se/StaffPages/CV/CV93.pdf
Page 14
Posted on Jun 05, 2008
Bios update failed! Now i get 8 beeps and no display.. any solutions?
8 beeps is when the PC fails to write to its display memory. But the only change you have made is to update the bios, so I think the bios does not match the graphics card in the PC. Have you changed the graphics card or touched it inside the case? Check its fitted correctly.
I hope you backed up the old bios. If you did restore it. You may have installed a bios that is incompatible with that PC hardware, check its the correct one.
Dec 16, 2013 | HP Pavilion Desktop - 10GB Memory - 1.5TB...
Tip
How to make computer to fast or fast boot ?
Do the following to make your PC Fast
Do 1
1. Turn on your computer, and hold down delete.
2. In the BIOS window, look for the Boot Menu option.
3. Choose the QUICK BOOT to turn off memory test
.4. Make sure the hard drive comes first in the BOOT ORDER.
5. Turn off any logo displays.
6. Restart
Do 2
1. Open your Start menu.
2. Click Run
3. In the command screen type msconfig
4. In the system configuration utility,click either BOOT tab.
5.In the boot menu, change the default setting for Time Out from 30 to 5 seconds.
Do 3
1. Click the Start button.
2. In the Start Search bar, type control userpasswords2
3. Load the User Accounts window
4. Uncheck User must enter user name passwords...
5. Click Apply
Do 4
1.Click Start button and load the Control Panel
2. Under the Control Panel menu, click Programs.
3. Under the Windows Defender heading choose View currently running programs
4. Choose Startup Programs from the Category option
5. Remove Programs that you feel unnecessary for startup
Do 5
How to disable this indexing service
1. Click on Start
2. Click Run
3. Type services.msc
4. Select Indexing Service and Double click on it.
Select Manual under Startup Type.
5. Click Stop
6. Click OK
on Jan 03, 2010 | Computers & Internet
I cant reformat my ibm pentium 4 where can i find the advance bios i press all the functions but icant see the advance bios
Try the below steps and I hope it'll work for you.
1) Shut down the operating system and turn off your computer.
2) Press and hold down the F1 key, and then turn on the computer.
3) When an IBM or other logo is displayed or if you hear repeating beeps, release the F1 key. The IBM BIOS Setup Utility will start.
4) Select "Start Options" from the first menu.
5) From the Start Options menu, press <Enter> on the top bullet labeled "Startup Sequence" (it is above all the other options). This brings up a new "Startup Sequence" menu.
6) Change boot order as needed using arrow keys.
Jul 24, 2012 | IBM Netvista Intel Pentium 4 2.4GHz /...
How do i set my laptop to booth from cd/dvd?
There are 2 things you could do. 1) you can change the boot settings in the bios or 2) you can choose the the boot device on the logo screen or bios screen on startup. to do #1 you need to press either DEL or F2 on the logo/bios screen. inside you can change the boot priority. for #2 once you see the logo/bios screen you can either press F10, F11 or F2 to go to the boot device selection. To know which buttons to press for these once you are on the bios screen the right button will be flashed.
Jun 06, 2012 | Computers & Internet
The BIOS startup time is 5-10 minutes, showing
Either you have failing hardware attached or bios is looking for a device (probably a drive) that is not present.
May 13, 2010 | Acer Aspire E380 ASE380-UD500A PC Desktop
I have a invalid boot diskette a error message.
1.at startup press f8 2.in menu use arrows to safemode3.start windows in safe mode 4.delete any new startup software.
Oct 16, 2009 | Dell Dimension 4100 (-JM0TB01) PC Desktop
I cant install a new operating system into my HDD. My setup does not suportt boot from CD.
The Bios Settings need to be changed to boot from The ATAPI drive. When you turn on computer press the F2 or F1 or Delete button, sometimes its F10. Once you are in the bios setting look for boot devices. Follow the on screen instructions to change the boot order. I hope this helps.
Mar 30, 2009 | IBM NetVista PC Desktop
Thinkpad 390x 2626, won't boot from cd drive
Try pressing F12 at startup, you should get a boot option.
Nov 19, 2008 | Computers & Internet
Pc will not boot
I am not sure if there is a jumper or not, but just unplug it and remove the battery wait a minute or two and replace the battery and plug it in and see if that helps.
Jun 04, 2008 | Intel Motherboard
Change battery for bios
when the pc is booting press F2 or Del to get into the bios, then in the advanced cmos settings look for default settings, highlight it and press enter then when prompted save the settings and exit for a rebbot.
Oct 31, 2007 | ASUS VIA KT133A Chipset A7V133-C...
ASUS VIA KT133 Chipset A7V133 Motherboard Logo
167 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
