Question about Dyson DC14 All floors Bagless Upright Cyclonic Vacuum
Dc 14 no suction/noise
We are having the same problem as in the topic already started.
We called Dyson and they called the sound "ratcheting." It sounds like plastic grinding together. No smells. If you lay the vacuum down in the recline position the brush does not spin but the noise is present. Also, if you leave it upright the noise is not there but when you go to recline it into the position you use it in, it starts the "ratcheting" noise.
  • 372 Answers
The sound you can hear is the clutch slipping the machine is designed to do this if the brush roller is jammed or foriegn object obstructing brush roller.
Remove the sole plate by turning the 3 plastic screws to unlock pull off sole plate now look for anything that is stopping brush from easily turning. If nothing obviouse but roller hard to turn by hand remove the brush roller & check the bearings at either end of the roller if they are siezed up A new roller will sort this out.
If brush roller is turning freely then your problem will be warn out clutch this will need replacing.
Its A lot to explain so try this site it has clutch removing manual for Dc14. http://dysonmanuals.llc.nu/
Posted on Jun 06, 2008
Dc 14 does not suck very well when on carpets massive suction through wand
Hi Diane, it's Jack at Dyson.
If your DC14 isn't picking up well on carpets despite having strong suction through the wand, there are some simple troubleshooting checks you can run through. I understand you've checked for blockages and washed the filter, but there may be something you've overlooked. These checks will help you determine if there's a blockage or another issue that may be causing this: http://www.dyson.co.uk/support/dc14/dc14-all-floors/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/no/loss-of-performance
If you'd like further advice after giving each of these diagnostic checks a try, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jan 18, 2015 | Dyson DC14 All Floors Upright Vacuum...
The suction on my dyson is too strong
i don*t know alot about dyson but if it has a thing to raise it up off the floor then that will work
Jan 26, 2013 | Dyson Vacuum Dc 14 Low Reach
Dyson DC 14 upright not suctioning
Start by cleaning the filters. Watch this video:
Jan 22, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Makes a ratchetting noise due to hair caught in brush; cleaned the brush and replaced the brush cover but still makes noise. what is the problem?
You have to take it to a vacuum shop and have a new clutch put in. The DC-7 and DC-14 have a clutch that needs replacing usually every year to year and a half.
May 01, 2010 | Dyson DC14 All floors Bagless Upright...
My dyson 17 dc is making a noise like a loose roller but it's tight. it sounds loud and vibrating type noise
Hi there, your machine is designed to make a ratchet noise if the brush bar is obstructed.
Please check to ensure that there are no blockages around the brush bar and that any hair or threads have been removed. If you need help with this, you can follow our self help guide in the support section at www.dyson.com.
If you need any further help or advice, please contact our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Apr 16, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
A Dyson dc 17 Animal and the wand/hose has lost suction
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the wand/hose is blocked. To check this, remove the wand/hose assembly from the machine, switch it on and test the suction from the top of the wand with your hand. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its good here, then you know that the wand handle is blocked.
For the full diagnostics, check out the Support section on our website at www.dyson.com or call our Helpline on 1866MYDYSON.
Kind regards
Darran
Jan 30, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
He dyson is making a very loud grinding noise
The belt that rotates the beater bar may be damaged - call the Dyson helpline for troubleshooting and for a solution to the problem.
Jul 03, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
While using my Dyson a rug got caught and that ratcheting sound started. I removed all signs of strings, etc until the brushes rotated fine but when I started the Dyson the ratcheting started again. I have...
The rattly sound means the drive belt has snapped or the protective clutch has slipped. This needs repair by someone who knows how to repair Dysons officially. Sadly its the kind of model that can't be done by the owner.
Jun 16, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC 14 animal bagless--unable to use wand
Hi.
Try these tests & tell me the results.
Remove the hose & wand completely from the machine it unclips at the bottom of the back.
Leave handle in full upright position & switch on do you still get the sound of something blocked ?
If yes remove the (U) shaped inspection port again at bottom back of machine now repeat last test what happens ?
Please reply with your answers.
http://dysonmanuals.llc.nu/index.htm
Chris.
May 18, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
261 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
