2003 Samsung HDTV 1080i 42" wide screen has just developed picture problems distorted and red. Almost looks 3D. MODEL NO.:HCN4226WX/XAC SERIAL NO.: 37083CEX400297E
  • 3 more comments
  • Anonymous Jun 13, 2008
    my screen just moved and different colors throughout the who thing????
    HCL652W Samsung 2003 HDTV convergence problem - mine started looking 3D too - red and green really off - tried to manually fix and it looked shot. Then it started smelling like something was burning inside the tv so i unplugged it. What could be smoldering inside there? And should i assume this tv is shot? what to do? thanks Lynn
  • bitchbruno Aug 06, 2008
    I have the same problem, when i go into the service mode, the red, green and blue are really out. The green and blue can move but the red still very far from the others, my question is, if i change the Convergence Board the color will be back together? Or i will have to replace it in the service menu after installing the new Board?
  • jramirez040 Oct 10, 2008
    in my 1080i HDTV the blue lighting is in place but the green & red light are out of place, and im not sure how to fix it.Can anyone help?
  • Anonymous Apr 07, 2009
    I have the same problem,the red, green and blue are really out. The green and blue can move but the red still very far from the others, my question is, if i change the Convergence Board the color will be back together? Or i will have to replace it in the service menu after installing the new Board?
  • 4,234 Answers
This is a convergence problem and can easily be fixed either by resoldering the pins on the convergence ICs or by replaceing them if they prove to be defective. Can you solder? Do you feel confident in replacing these parts?
Keep us posted.
Dan
Posted on Jun 04, 2008
The tv will not turn on while pushing the power button. It sounds like it wants to come on the red light is flashing on the power button.
Posted on Aug 09, 2011
My samsung 1080i just started showing a really awful looking pictures.. the colours arent aligned anymore. does anyone know how to fix this problem?
Posted on Jul 18, 2008
My 1080i picture is out of place how do i fix it
Posted on Jul 14, 2008
Samsung rear projector tv Model SP42Q2HL HDTV ready 1080i Looks like i should b wearing 3D glasses when watching tv, Is it game over?
No,is it not.It a repairable tv.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 12, 2010 | Samsung HCP4252W 42" Rear Projection...
Convergence panasonic HDTV 1080i bbe hi definition
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Hi my problem is I have red lines across the screen with double picture
These sets have several common problems listed below.
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
Mar 19, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Problem with picture on wide sreen TV
You probably need to get a Sony TV Convergence Kit. More information can be found using the link below.
Convergence Symptoms:
  • Colors wont align
Feb 05, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Distorted picture
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Jan 16, 2010 | Samsung HCN4226W 42" Rear Projection...
Seeing red, blue,geen wavy lines across screen which distorts picture while viewing.
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 02, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
I have a samsung 42 picture lines top and bottom of screen
DAve1645 is correct!
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
You can see some examples here...
Nov 28, 2009 | Samsung HCM4215W 42" Rear Projection...
Samsung HDTV 1080I-Model#HCP4363W-Convergence Problem
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Red/Orange looking picture
Jan 21, 2009 | Samsung HC-P4752W 47" Rear Projection...
42" Rear Projection color issue
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 22, 2008 | Toshiba 42HDX82 42" Rear Projection...
Samsung hdtv 1080i
Whats the model number of your set? Need that info also let me know does the picture appear almost 3D?
Aug 28, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
920 people viewed this question
Top Televison & Video Experts
