Question about Sony SA-WX900 Subwoofer
Low noise is heard when sub is on..very low brum.
Very low brum is heard from sub but once the receiver is on this noice disapear.The sound is ok.What's that????
  • Star Adriatic
    Star Adriatic Jun 05, 2008
    Thanks,but this sound is heard even when the conection cable is not conected
    Novelist:
    Scholar:
  • 100 Answers
Salutations valikan,
It sounds like you may have some basic interference either in your power, or other sources. I have something similar when my sub is not in use I pick up talk radio, it drove me in sane for months untill I figured it out.
There are a few things you can do to help eliminate interference would be to purchase a surge protector with a power "filter" or conditioner. Also check the cabling to your sub-woofer if there are any breaks or weak spots in the insulation this could be causing interference as well.
And as always if possible read through your owners manual to see if there are any adjustments that can be made on your sub-woofer it self.
Hope this helps.
Jon
Go Ahead. Use Us.
Posted on Jun 04, 2008
Hyundai Accent 2016, 4811 km. makes grinding noice which can be heard when driving on smooth asphalt road. Noice is on for a while and then you don't hear it for a while. What can be the problem?
Wheel bearings could be the problem. While moving and steering to the left, if the noise increases, it could be the RIGHT wheel bearing. And the opposite when steering to the right. I wouldn't rule out brake noise though. Rotors almost overnight get a surface rust and must be worn off when first driving in the morning. Very common in high humid areas.
Aug 24, 2017 | Hyundai Cars & Trucks
Why is there low humming in the receiver sub channel(only?)
Sounds like a shorted capacitor in the sub out circuit.
May 04, 2015 | RCA Audio Players & Recorders
Low sound and buzz from speakers / Hum noise from sub-woofer
Select Start > (right click) My Computer > Manage
In the Management window select > Device Manager
Next to Sound, Video and Game Controllers click the + sign
A yellow triangle will signify a problem so if one is present, right-click that device and select Properties
You can then choose to update the driver
For more details check Dell Xps 420 Manual.
Dell Xps 420 Manual
Apr 14, 2017 | Dell A525 Computer Speakers
I get no bass sound from sub-Woofer connected to Yamaha RX-V465
Check your speaker settings in Setup menu / Speaker Setup / Manual / Config (and then in this submenu also Equalizer).
In Config, choose where should low frequency sound go - subwoofer and/or front speakers (if they are big enough). The settings are: Bass Out: SWFR/Front/Both.
Also check Subwoofer phrase in SWFR Phase.
Check settings of all speakers, they can be Large / Small / None. If small, frequencies lower than "Crossover" settings, will not be put on them.
Nov 13, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Hitachi plasma buzzing noise
sounds like bad audio pcb if buzz comes thru
the speakers,
Aug 19, 2009 | Televison & Video
Low level hum noise from sub-woofer, once it warms up.
You could try cleaning both the female ports you are connecting to along with the cables ends you are interting with DeOxit. Sometimes they both develop oxidation over time. Good luck! http://store.caig.com/s.nl/sc.2/category.188/.f
Mar 21, 2017 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Yahmaha rxz9 no output signal to sub
the part where you plug in the sub has blown or warn out over night dude get it repaired i think u need to change the fuse inside the reciever
Dec 31, 2008 | Yamaha RX-Z9 Receiver
Pioneer model sx-315 shuts off
if you are hearing noises from inside the amp,then something is burning up. Your sense of smell may be a guide here too. I suggest taking the amp to a tech to repair it unless you have had some experience with repairing amps
Jan 30, 2008 | Pioneer SX-315
Subwoofer
first isolate trouble by giving audio signal to your power sub. by your finger.you know when we put our finger on input signal the noice is amplified and you can listen sound.if nothing is noticed on sub that menas sub has problem.
Dec 18, 2007 | Harman Kardon AVR 320 Receiver
BOOM SOUND AT AUDIO MODE CHANGE
Suggest turning the volume down on the Receiver/Amp before changing modes. Changing modes can produce signals that can hurt speakers if driving at mid-high levels.
Regarding the sub, turn off the receiver first, then turn off the sub. When turning everything on, turn on the sub first, then the receiver. If you still hear the noice in the sub, turn down the volume in the sub before turning it off (making note of what volume level you prefer for it when it is on).
Oct 26, 2007 | Denon AVR-2500 Receiver
Sony SA-WX900 Subwoofer Logo
338 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
