Question about Whirlpool Washing Machines
My whirlpool washer (calypso) will not drain... It is flashing a code "LD" and soapy water is still in the bucket.
  • 413 Answers
The drain pump has either failed or is blocked. If you can hear a humming noise while draining, the pump contains a blockage.
Posted on Jun 04, 2008
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Why do i get a "ld' signal or a "co" message?
LD = Long Drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Press STOP/CANCEL to clear the display
I don't see an CO error. Here is a complete service manual for your washer. I am sure it will come in handy in the future. Look on page 46 for a list of the error codes.
Regards, Rich
Feb 08, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso error code
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 31, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Error code "LD" displays, what do I do next?
an LD code indicates a long drain was detected by the control.check for a kink in the drain hose. the most common reason for this code is something caught in the pump. many times a piece of clothing(small sock,shoe lace or string from a sweatshirt etc..) gets stuck and restricts the water flow to the drain...the pump can be removed by tipping the washer forward approx 45 degrees(use something to prop the washer up so it doesnt fall all the way to the floor)then remove the back panel. the pump will be gray &have 2 hoses. calypsos used 2 styles of pump . one was integrated into the pump motor and the other was attached to the pump motor with 2 springclips.remove the clamps on the hoses and see if you can see whats caught inside..if the foreign object is wrapped up in the pump too tightly you will have to replace the pump..if you have to replace the pump and it comes as part of a new motor.,the front panel will have to come off to unplug the pump motor and plug in the new one. there is a space at the top of the front panel where it meets the lid, use a putty knife to release 2 clips so you can lift the lid up. you will see several screws along the top.remove them and the front panel will come off . you wil be able to see where the pumpmotor plugs in. . you will have to work in front and behind the washer. always unplug the washer before doing any work on your appliance. hope this helps get you back up and running...
Mar 25, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
We are getting ld error code, also machine motor dosen't seem to be running when we try another cycle
Ld flashes when the water level does not change after the drain
pump is on.
➔ Is the drain hose clogged?
➔ Is the drain hose height greater than 96′?
➔ Is the pump running?
TECH SHEET
Feb 17, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer stops when Ld comes up on display before final spin, but washer drains fine.
ld flashes if it takes longer than 5 min to pump out water to the point where the operating pressure switch resets.check the drain line for kinks,check drain for blockage,check pump operation.
Jan 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
LD flashing
Press STOP/CANCEL to clear the display.
Usual causes are easy to check:
1. Unplug the washer and clean the pump strainer. It is located between the drum and the pump, and will be attached to the drum with a rubber hose.
2. Dump your drain hose into a bucket to remove any build-up in the drain hose. If possible, run an empty load, with the drain hose pointed outside.
Best regards, --W/D--
Aug 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer - LD Code - clothes still wet
harborstuff,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. I would bet that the bath mats left a bunch of stuff stuck in the recirculation pump hose, or pump itself, and the water cannot be drained fast enough. Check the intake and exit hoses of the recirc pump. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. Hope this helps.
(Definitely get under there and check to make sure the pump hoses are not clogged. At $129 it's an expensive fix for a $10 bath mat that clogged up the hose with fuzz. 'know what I'm sayin'' :o) )
-samson39
BTW, I have the maintenance manual & have experience at replacing the recirc. pump, control board, motor board, touchpad, & lid switch so far.
Jul 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer won't empty water....
Ld Long drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Mar 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
LD.;....................
LD= Long drain if the unit has taken more than 5 min to drain out the water this code appears.. you eiter have a pump issue or a pressure switch issue.. does all the water go out of the unit??
Feb 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
76 people viewed this question
Dan Webster
Dan Webster
Sal De
