Question about Canon PIXMA MP150 All-In-One InkJet Printer
Canon mp150 & windows vista
I have a new hp laptop w/windows vista. I cannot get it to connect to my wireless router and locate this printer. I did not have this problem with my compaq which used windos xp. Is there a solution?
Duane
  • sam_22003 Aug 27, 2008
    i lost the cd and I"m trying to print but i can't
  • destiny957 Feb 15, 2009
    Is there a windows vista verson of the software that came with the printer yet? Where can i get it please
    Guru:
  • 61 Answers
Download printer driver for windows vista
http://www.driversdown.com/drivers/12692.shtml
Posted on Jun 05, 2008
I purchased a SBG901 and have connected 2 MAC pc's wireless - 1 HP printer and 1 Compag laptop, I have one more pc which is running Vista on a HP Pavilion dv5 and visited the HP website to update
It might not be anything your doing wrong, the wireless portion of the card may have just gone bad. you could check this out by reconnecting your old router back up to verify it works or doesn't. If it doesn't work your wireless in your laptop went bad presuming that the wireless was not deactivated on the laptop. if it does work the Vista Driver may be incompatible with the new router, you may be able to hook up both routers at the same time which would allow you to keep using your HP system.
Feb 28, 2012 | Arris SURFboard SBG901 Wireless Cable...
I have HP Officejet 6500 connected via USB to office desktop. I also need print from vista laptops on the same wireless network as the desktop. How do you do it ?
Hi, I just completed this same query this week.
to set up my remote network i followed promts from windows and then had to run my windows xp startup disc on my vista laptop.
After that was complete i had to install the hp printer setup cd onto my vista laptop and connect the hp printer to my router using the ethernet cable. I followed the prompts on the vista as the cd continued to install. then at the end of it all it showed i had correctly installed the printer via wireless and asked me to do a practice print which i did and all seems fine.
I can now print from my vista laptop and my windows xp desktop. I hope this helps
Jun 12, 2011 | HP Officejet 6500 AllInOne InkJet Printer
I have a new HP laptop and want to install my printer. I have a pixma MP150 All in one. Will it work on a wireless laptop?
The printer does not have a wireless network feature. If you connect it to a wireless print server, you will need to check if the print server is compatible with your laptop's OS. (If you have Win7 on all computers, the homegroup should let you share the printer via your network.) If you use one of the network options, the scanner may only work with a direct USB connection.
It will work with any supported OS with a USB connection. Drivers are available here: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp150#DriversAndSoftware . Install the software before attaching the data cable. If you forget, the scanner features may not work (a generic driver gets installed). If you do install the generic driver, uninstall it and then unplug the data cable before rebooting and installing the Canon driver.
I hope this helps.
Oct 18, 2010 | Canon PIXMA MP150 All-In-One InkJet...
HP photosmart used to print wirelessly from my Vista loaded laptops. printer was usb connected to desktop with XP. Had to get new hd and reload with XP for desktop and now cannot configure for wireless...
As your printer is not wireless itself I assume you shared the printer. To enable this again goto Control Panel on your desktop, select printers, right click your printer and there should be an option for sharing. Enable sharing.
Now using your Vista laptops you should connect to your home network (in your case this is probably a wireless router, as long as your desktop is connected to this router too), goto Control Panel, printers, add printer, search for printer not connected to this copmputer (or network printer).
Hopefully the Vista laptops will then pick it up and install it correctly. You may be asked to install the correct driver for the vista machines. Windows should provide you with instructions on how to do this.
Hope this helps,www.PuterCare.com
Feb 27, 2010 | HP Photosmart 2610 All-In-One InkJet...
I am trying to connect my laptop to my hp printer
It's the password you used to setup security in your wireless router.
Feb 02, 2010 | HP Officejet Pro L7680 All-In-One Printer
I need help installing my MP150 printer to my HP windows vista computer?
Download the driver for Windows Vista from the following link.Connect the printer with your computer using data cable that comes with printer. Power it on and then install the driver that you download from the link that i provide you.
http://software.canon-europe.com/products/0010247.asp
Oct 22, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printing remotely from laptop -- can I?
I assume it's a Brother printer not your brother's printer right? I have an HP and it's a wireless printer which is accessible through my network, you have to install the printer driver and software on to the other laptop that is connected wirelessly to your network.
Mar 31, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Printer is offline
Please tell me how to have my printer online.
Apr 16, 2008 | HP Photosmart C6100 All-In-One Printer
Windows Vista
Please go to Canon's website, and download the Vista Driver.
You can go straight to you model by clicking HERE
(you will have to wait for the page to load before you can see the drivers/software lists)
In the "select OS" drop down, choose VISTA (not Vista X64) and then click on the driver that pops up. Then, click on I agree.. Download the driver and install!
Apr 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
New vista windows working with a wireless routerand a new laptop
this can be done..want to do a Shared screen experience? send me a note to my email from my profile.
Feb 18, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
768 people viewed this question
old marine
old marine
