Question about Akai Televison & Video
I have a convergence problem with my akai PTH5498 REAR PROJECTION TV. Please tell me how and where I can order the part plus how to install it.
  • Akai Master
  • 8,617 Answers
You need to replace both convergence ICs they are STK392-040 you can get replacement Ics at the following link and they provide free instalation instructions. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jun 04, 2008
Red and blue pic adjustments areso out of adjustment how can i get them back
Convergence board is dead.Go to Tv repair World.com buy a new convergence board replaced the board will solved ur problems.Samsung/Akai use same convergence board.
Jan 22, 2010 | Akai PTH5498 54" Rear Projection...
Akai pth5498
the part number for the convergence board is aa95-00705a and you can order it at www.vancebaldwin.com. send me your email addy to fixa@markservicepro.com and i will send you a wiring diagram....
Nov 02, 2007 | Akai PTH5498 54" Rear Projection...
Convergence board is bad
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 28, 2009 | Akai PTH5498 54" Rear Projection...
Akai (PTH5498) 54" rear projection TV with red and green ghosting and large curve in the picture at the top and bottom of the screen. Unable to fix using manual convergence. Thinking it must be the...
Hello:
Yes is is your convergence IC's. One has gone bad, but consider replacing both of them because if one has gone bad then the other is not far behind. They are located on the middle board of your set. They are mounted on a large heatsink, the part # should be STK-392-040. Replace these and your set will work fine again.
Nov 15, 2009 | Akai PTH5498 54" Rear Projection...
PTH5498 Akai TV Concave on top and bottom
I just picked up the same tv for free, and have the same problem.
but mine also has shadows of blue and red everywhere. but yes, it is in fact a convergence problem.
you can buy the part to repair it yourself, but its not as easy as just plugging it in. you have to solder it, plus a resistor(if that blew too), and a fuse(again, if that blew as well).
tvrepairkits.com claims they can make a kit for any tv, i sent them an email to see if they can make one for the akai.
here is the part number for the convergence ic's STK392-040 if youd like to find them on your own.
Jul 03, 2009 | Akai PTH5498 54" Rear Projection...
Double image
yes you just need two ICs
Jul 12, 2008 | Akai PTH5498 54" Rear Projection...
Double image
If your model number is the PTH5498 you will need to replace both convergence ICs they are stk 392-040 you can get replacements at the followig link and they will provide fre instalation instructions with pictures. Here is the link.
Jul 11, 2008 | Akai PTH5498 54" Rear Projection...
PTH5498 54 in. Rear
convergence amps possible have been blown. also check fuses and resistors on that board. it more that likely blown if fuse go. As a tech that happens to me all the time
Dec 02, 2007 | Akai PTH5498 54" Rear Projection...
Akia tv
Replace Stk392-040 convergence IC's. Use Panasonic brand
for reliabilty.Re-check alignment....
Let me know by your rating....T.
Oct 22, 2007 | Akai PTH5498 54" Rear Projection...
TV will not turn on...
Convergence board failure. $300 repair
Sep 19, 2007 | Akai PTH5498 54" Rear Projection...
Televison & Video Logo
54 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
