Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Caloric prestige series model no. rws214uww mfg. no.p1132442nww
The timing control center suddenly started making noises,and the oven won't turn on. Turning the dials does not help, and if I unplug the wire from the back of the timer the sound will stop but the oven still won't turn on.
  • shellwebb99 Oct 01, 2008
    Having the same problem. Need to know what part we should order.
jessee007
  • 310 Answers
SOURCE: caloric gas range problem
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Posted on Jan 01, 2008
SOURCE: caloric gas stove prestige series
My one spark ignitor on my stove top comes on by itself and keeps clicking till I pull the plug. It will reset itself and stay off for awhile then it will come on by itself again sooner or later. What is the problem??
Posted on Sep 30, 2008
  • 15 Answers
to jenna 12 Does your stove have a stop and start timer? When you set your clock you may have inadvertantly moved the stop or start time on that timer. Check them, if they have knobs for setting the stop and start time, make sure the pointer is pointing to the current time and that the knob is popped out and not stuck in. when you have it right both the stop and the start knob should be out, not pushed in. They will pop out when you turn them to the current time.
These timers allow you to start something cookin at a time delayed several hours. this means they will not allow the oven to come on until it hits that time that you may have set in error.
If your stove has a digital stop and start timer check each one so that both show the current time, then your oven should light.
Posted on Oct 07, 2008
docjohn174
  • 943 Answers
SOURCE: Oven makes a poof noise when turning it on.
HI thanks for your question. the poof you hear is the gas sorta igniting because of a failing bake igniter. i would replace it thanks if you need help don't hesitate. thanks.
Posted on Oct 14, 2008
jsrock516
  • 5911 Answers
SOURCE: broiler coil is on when bake is turned on...is this normal?
On some kitchen ranges, the broiler comes on during the preheat cycle to speed up the process of warming up the oven and reduce the wait time. This is intended as an energy saving feature as well by reducing the amount gas used on a gas range and the amount of electricity with an electric range.
If the broiler comes on and STAYS on while you are baking, this is NOT normal and is probably an indicaiton that you have a problem with the Electronic Oven Control (EOC) board. This is your timer/clock assembly on the operator console. The EOC controls all the oven features.
If you have any questions, please post back and let me know. Please post your MODEL NUMBER when submitting questions, so I can determine how your range is configured. I hope this helps you.
Posted on Mar 10, 2010
Finding the flame pilot on a caloric prestige series gas stove
There is no pilot. The igniter is in the oven cavity under the floorpan. This is a picture of the regulator and gas valve- the wire nuts at the top of the pic just left of center are on the leads that go to the igniter...
Jun 26, 2016 | Kitchen Ranges
Why won't the gas oven heat? The oven won't light and gas is not leaking when I turn the oven on.
does it have a pilot light or is it electronic ignitor . might need ignitor replaced
Jul 23, 2014 | Ovens
Please help find oven mauel
open oven doors and check behind the bottom of the doors for mod number
Nov 21, 2013 | Ovens
How to turn on self-clean
I have an older model prestige series caloric oven
Oct 01, 2012 | Fisher and Paykel Titan OS301M Electric...
I have a caloric oven, prestige series. Don't know model. it is about 15 years old. last year the oven wouldn't heat and smelled gas. That was repaired. Now, oven ignitor comes on but oven...
The ignitor is bad again,if it (ignitor) comes on but no flame/heat its the ignotor again, what would make the ignotor go bad so fast (usually last 10-15 years) is a problem with the oven burner, so now BOTH the ignitor and burner would need to be replaced,if it is 15 years old the ignitor is readily avaliable but the burner may not be
Gene
Aug 04, 2011 | Ovens
I have a Caloric stove of the prestige series with a self cleaning oven. How do you turn on the self cleaning oven?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Feb 22, 2011 | Microwave Ovens
Broiler coil is on when bake is turned on...is this normal?
Mar 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Looking for a Oven knob for the Caloric Presige
http://www.appliancepartspros.com/partsearch/
or
http://www.expertappliance.com/caloric-stove-parts.html
Oct 18, 2009 | Ovens
Need owners manual for Caloric prestige series electric stove. self cleaning instructions
prestige cooker with built in oven is suddenly making loud noise .don't know what to do?
My caloric heritage series stove oven will not ignite.. pilot flame is on. I need parts..w here can i get them thanks.
I have a caloric prestige electric stove and the electronic ignition don't work. Does anyone have a solution for this problem?
Oct 05, 2009 | Stoves Ovens
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
335 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
