Question about GE Microwave Ovens
Microwave unit goes out after a few seconds of use. I then have to reset time and calender date tp make it functional again. I then try to use the microwave again and the same thing happens again. The microwave goes out again.
  • GE Master
  • 9,098 Answers
Sadly, we hear of this over and over.
This is usually due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details are in a bulletin at
Even if your model is not on the list, the same problem can occur, requiring a kit.
The parts kit is similar to this one:
(Your model may use a different kit - this is shown for illustration purposes only).
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here:
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
New unit used 3 days. Microwave beeps and screen goes to menu, or set time screen. Sometimes changes the date all by itself. Does this in the middle of the night all night long.
I advice you to contact service if it has guarantee. This seems to be a psychological problem about your oven(!). Technical person need to do an electronic research surgery on its board to see if there is any wrong thing.
Nov 05, 2012 | Whirlpool GH7208XR Convection / Microwave...
Ge eterna series - installed above oven. microwave stops working and display instructs to set time and date, then after setting time and date and starting oven again it stops after a few seconds and asks...
The magnetron draws a lot of power and the mains may be dipping beneath an acceptable level, causing the panel to reset.
Check the supply cable size and any connections.
Jan 23, 2011 | GE Microwave Ovens
Ge spacemaker jvm1650sh01 starts to microwave then loses power
See this FixYa solution.
May 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave powers off after few seconds of working
Hello :
This could happen because of a bad keypad . Just replace it and problem will be solved . I need you to think before replacing it . Because sometimes a new unit is better than repairing . Think it before !
good luck .
please rate !
Apr 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker model #JVM1650CH01 that keeps on shutting off everything after a few seconds. I have to rest the clock and month -year - date to try again.
my spacemaker xl jvm 1650 microwave shuts down after just a few minutes of operation and after a few minutes needs to have a clock/time/day etc reset. is this reparable by a homeowner?
Oct 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacesaver powers off 2 seconds after resetting clock and time...
The clue is that you have to reset the clock. You are losing power somehow. the Main Board thinks it is being unplugged and it resets the clock and you have to start all over. The fact that after so many times it will finally work tells me that whatever bad connection you have is finally getting hot enough to expand and make a good enough connection to keep working. Intermittant connections are the worse to find. A lot of trial and error to find the problem. can be bad fuse and fuse holder ( in the unit), bad outlet, loose wire at circuit breaker, loose wire at outlet. Even a loose breaker where it snaps onto the buss bar in the Breaker Box. Etc, it an really drive you nuts trying to find it. Try the unit in a totally different area making sure it is on a compleately different circuit breaker and see what it does, if the problem follows the unit, the problems is in the unit. If not, electrical problems, outlet, breaker, panel,
Aug 18, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Oven shuts down after a few seconds into cycle time for cooking
The magnatron (heating element) is located in the cavity behind the control. If it's leaking microwaves onto the electronics, this will occur. This means the Mag should be replaced and a radiation test run on unit.
Mar 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1650 Microwave Suddenly Stops
Your magnetron tube is leaking RF energy inside and zapping the main board. It is NOT dangerous as any leakage will be contained inside the unit. You will need a new mag tube and it is covered by a 5 or 10 year parts warranty. Call GE Factory Service at 1-800-432-2737or schedule online at
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Shorting out
Sounds like the units main elecrtonic control board. You can contact your local parts house for the parts as they should have them or call GE at the #b in the owners manual. I must advise you that there is a very hi voltage inside these microwaves so you must have some know how on working on large appliace and if not PLEASE seek a pro to assit you in this repair. Good Luck
Jul 02, 2006 | GE EMO3000 Microwave Oven
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
