Question about Amana ALW880WH Top Load Washer
Water leaking around machine
Removed front panel, lifted top panel with lid closed, When machine drains and spins, water climbs up the side of the tub and spills over the top. I comes out the back holes of the tub enclosure.
The timing cycle - wash stops - pause for a few minutes - then spin and drain - appears that water is too full as it is forced up the side of the tub by cyntrifical force until it comes out of the tub enclosure holes at the top of the enclosure.
Pump is working, no leaks through hoses ???
Thank You
    Genius:
  • 1,028 Answers
Ck belt or replaced belt is designed to slip to a point if belt grabs too quickly the tub rpm come up to fast not giving tub time to drain down far enough to prvent climbing over the side also be sure drain hose is not plugged reducing water flow to drain
Posted on Jun 05, 2008
Washer not draining
First is machine spinning? machine only drains in spin mode.
If machine not spinning check lid is closed and check lid switch and plastic plunger that operates the switch located on the lid.
If machine is spinning then most likely a blockage on the drain hoses or pump. if there is water in the machine, lower the rear drain hose to low level, if water starts to flow out the hoses are not blocked, more likely a pump failure. To replace pump first drain all water from the machine with drain hose at low level.
Tilt machine back and remove the belt from below.
Remove the front panel.
To gain access and remove front panel insert a knife or thin blade approx. 4" in the from each side in between the front seam on the front panel, this will release the lid clips, lift and hinge back the lid panel, remove the two screws securing the front panel and remove.
Pump on right hand side at the back, disconnect main hose from pump by squeezing hose clip with pliers (may be a bit of water remaining). Unbolt pump and pull forward with the drain hose attached until it can be disconnected and pump fully removed.
Check pump for blockage and damage to impellor, replace/refit in reverse order.
Nov 23, 2013 | Admiral AW22 Top Load Washer
Large amount of water leaking from bottom
lift the top first by 2 clip between top and front panel at 2 inch from each side with a metal plate,after removed the front panel 2 screw on the top, and just see where the machine leaking
possibility drain hose,pump,hose pump to tub,seal kit at the center top of the transmission.
good luck
hypersteve
Dec 15, 2010 | Maytag Legacy MAV208DAWW Top Load Washer
I have an older washer top load frigidaire gallaxy and water is spilling on floor and tub is spinning but water wont drain all the way
you need to check the drain pump for anything that may be obstructing the flow of water.If the water is coming from the bottom of the tub the you mif=ght have a bad tub seal.
You can use a screwdriver and push the tabs in on the lid to lift up the lid and remove the two screws from the front panel on the bottom and remove the front panel. and check all the hoses from the tub and the drain pump.if there is still
Nov 06, 2010 | Washing Machines
Whirlpool direct drive washer. Problem: water doesn't drain after wash cycle, no motor humming sounds during spin cycle. Have replace timer/timer motor, removed agitator and tub to check for obstructions....
It's most likely a lid switch issue. Depending on your model there are a couple different varieties, but the most common one was a switch activated by a plunger on the side of the lid. See if you can see the plunger and look for the corresponding hole that it would go into on the top, and there is your lid switch. the purpose of the switch is to stop the tub from spinning when you open the lid during spin cycle. Broken switch equates to no spin or drain however even with the lid closed.
Here are some basic instructions:
Accessing this part requires you to flip up the control panel by removing two phillips head screws in either the front bottom corners (may be behind the end-cap covers), or rear bottom corners, pull panel forward and lift to disengage the tabs at the bottom. Flip the panel upwards and it will swing back out of the way.
Next you will see one wire connector going into the top of the machine, this is actually your lid switch connector, disconnect it. Now using a flat screwdriver pry the front of the two brass clips towards the rear of the washer (put tip of screwdriver into front most part of clip and press handle of screwdriver towards rear of machine). The clips should pop off the top pretty easily.
Now you can open the lid and place a hand on the front of the opening and pull the cabinet forward. The entire front and side wrapper will come off the base platform and you can set it on the floor to gain access to the lid switch that is screwed to the underside.
Good luck to you on this!
Jul 09, 2010 | Whirlpool Washing Machines
I have a kenmore stackable washer/dryer. On occassion when drain/spin cycle starts. Water will spin itself out of tub and onto floor. Any ideas?
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 29, 2010 | Kenmore 23822 Top Load Washer
Kenmore 417.99980120 stack washer/dryer won't drain.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
May 12, 2010 | Kenmore 98702 Stacked Washer/Dryer
Very loud when spinning leaks a little water under it with spots of oil mixed in . i cant remove the agitator , bolt on the side but will not come off . when it is spinning it sounds like metal to metal...
Mar 23, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Machine stops in Rinse & Spin Cycle & leaks water
Mar 09, 2009 | Kenmore Washing Machines
Lady Kenmore 90 series not spinning or draining, leaking
Mar 08, 2009 | Kenmore Washing Machines
Tub leaking
Mar 03, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Amana ALW880WH Top Load Washer Logo
145 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
