Question about Sharp AL-1551 Laser Printer
Al1551cs Sharp: Document feeder feeds 1st sheet halfway
The sheet feeder takes the 1st sheet halfway and then the copier displays a jam in the sheet feeder. The sheet stays halfway until manually removed.
    New Friend:
  • 91 Answers
Replace the paper feed roller
Posted on May 13, 2009
  • Budi Raharjo
    Budi Raharjo May 13, 2009
The paper keeps jamming, I cant see anything in the way. any help is appreciated.
If paper doesn't feed correctly when printing, remove it and fan the edges of the paper to separate the sheets. Reload the paper against the right side and slide the edge guide against it. Do not load too many sheets at once.
If paper has jammed: 1. Press x Start to eject the jammed paper. 2. If paper is still jammed, gently pull it out from the output tray or sheet feeder. If paper is stuck inside, press the P On button to turn off the printer. Then lift the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the printer back on.
If documents don't feed correctly in the Automatic Document Feeder, make sure the corners of the paper are not bent, folded, or curled up. Do not load more than 10 sheets of legal-size paper at a time. If documents have jammed: 1. Open the ADF cover and pull any paper out to the left. Caution: Do not try to remove the paper without opening the ADF cover first, or you could damage the mechanism. 2. Select Yes or press OK to clear any messages on the display screen. 3. Reload the paper.
Feb 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
My 1900 printer power is on and flashing slowly and the paper/garbage light is on and not flashing.
Hello.
You most likely have a paper jam or a paper feeding problem. Paper may have jammed in the sheet feeder, manual feed slot, or roll paper slot.
Sheet Feeder or Manual Feed Slot: Press the
paper button to eject any jammed sheets, then open
the printer cover and remove any paper jammed inside.
Press the paper button again to clear the error.
Hope this helps.
May 31, 2010 | Office Equipment & Supplies
I need document feeder tray & document feeder unit for Sharp AR507
The RSPF (Reversing Single Page Feed) document feeder unit doesn't have a single part designation for ordering the entire unit. It's a standard item with the AR507 (meaning it's considered a part of the full machine).
If you want to order individual parts of the document feeder, you can contact Sharp via their website.
Sep 15, 2009 | Sharp Office Equipment & Supplies
Extra paper feeds and jams after each print. One copy prints and then the printer drags the next sheet down halfway and jams.
The feeder assembly is not timed right, it happens when you pull out a jam. It may have a broken spindle or gear, I would take it to a shop to figure out.
Aug 11, 2009 | Canon PIXMA MX310 All-In-One Printer
E-studio copier won't multi feed, it jams
Hello sir; Open the feeder cover clean all the rollers by rubbing alcohol or rubber rejuvenator( recomend) it should take care the problem.
Feb 03, 2009 | Toshiba Estudio 200L Copier
Document feeder
Am not sure but,it looks like problem with static charge building creating the problem.See that the document path grounding is ok
Oct 25, 2008 | Office Equipment & Supplies
Ricoh C21SF Automatic Document Feeder (ADF)
Take a little soap and a little water and clean the gray feed tire that is located in the document feeder. Check for any paper obstructions. If the machine has had a lot of prints I would replace the feed tire.
http://www.websitetoolbox.com/mb/copierquestions
Sep 25, 2008 | Ricoh Aficio SP-C210SF Printer
Jams but only w/sheet feeder
Theres is a spring clutch in the adf that goes out. Once that is fixed it should work just fine.
Aug 13, 2008 | Sharp AR-507 Copier
HP PSC 1610 All-in-One paper jam
ur printer paper feeder gears r jammed or misaligned. kindly get ur printer serviced from a good technician.dont worry its a normal problem.wish u success
Mar 11, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Problem with Automatic Document Feeder
There maybe a small piece of paper stuck within the feed path check this as it is all sensors so the machine is giving a reading that there is a jam or place a original on the feeder and press the copy button as you may of had a jam and the machine is asking for the original to pass through it again.
I suggest the first one though
Thanks J
Jan 11, 2008 | Sharp AL-1551CS Printer
Sharp AL-1551 Laser Printer Logo
269 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
