Question about Compaq AC Adapter Projector Lamp
Need ac adapter for Compaq projector
Need a ac adapter for a Compaq MP2800 Microportable projector. Does anybody know where I can buy one??
    Producer:
    Uploaded 30 video answers.
  • 95 Answers
Hi Tech Lady , greetings !!
Your projector has a "Multimedia Adapter" .
You can purchase the adapter from www.trademoon.com or directly from HP.
Trademoon is a discount supplier of new and refurbished Compaq and HP parts.You can call them at 97
2-682-5000 or log on to www.trademoon.com
Or you can also call HP/Compaq at 1-800-474-6836 and say "SPAREs"
The specifications of your adapter is :
Power Consumption 5 Watts (standby)/185 Watts (full power)
Power supply 90V to 255V (auto switching): warm restrike after 45 seconds
Goodluck :)
Posted on Jun 05, 2008
I have two dlp infocus X2 projectors. Both of them have lost their color. Is there something I can do to fix it?
This could be one of 2 things. It could have a bad color wheel or there is a setting problem in the unit. If the video mode is not set correctly like NTS or PAL it can give a black and white image.
The other could be your color wheel has failed. Did the unit make any noises before the color went out?
Some times the color wheels will make noises when the age before they crack or break from the heat.
I believen you can pull the lamp out and with the lamp out try and power the unit up, look into the little hole the lamp shines into and see the color wheel spinning. when you first plug it in and unplug it the wheel should spin and you should see the colors change. DONT TOUCH THE COLOR WHEEL they are fragile and can break easy. Some get more brittle over time from the heat of the lamp.
May 19, 2010 | Compaq MP2800 Microportable Projector sps...
it might be a problem with overheating, have you ever cleaned the projector? there might be alot of dust blocking the airflow.
If that doesnt help let me know.
Apr 15, 2008 | Compaq MP2800 Microportable Projector sps...
Compaq MP2800 DLP Projector
If the projector is not getting a source it might go on standby maybe check where you plug it in.
Projectors require quite a bit of power and should be on a single loop/outlet not hooked up to a powerbar with more things on it.
Hope that helped.
Dec 26, 2007 | Compaq MP2800 Microportable Projector sps...
Infocus X2 projector
resolution changes. if you hit auto image, that should correct it.
Sep 03, 2009 | Compaq MP2800 Microportable Projector sps...
Compaq MP 2800
Hi there
Does your Projector support Windows Vista ?
Mar 07, 2008 | Compaq 207685-001 - Microportable...
Compaq iPAQ Microportable Projector MP1200
you will not be able to find these parts
really...
Good luck
honestly
buy a new projector
Jan 16, 2008 | Compaq iPAQ MP1200 Multimedia Projector
Compaq MP 2800
Have you tried cleaning ther bulb housing and fan area with a soft brush and vacuum?
X2 infocus projector
make sure u have the lid back on or wont come on for the lamp
Nov 11, 2007 | Compaq MP2800 Microportable Projector sps...
Compaq MP 2800 Micropotable Projector
I had the same problem!  The problem is dust on the color wheel.  At side of the color wheel is a wire connector attached wit one small screw,  with a cottom tip clean the small lens  and surface, that's all. Put the connector and screw  and it will OK!!
Oct 10, 2007 | Compaq MP2800 Microportable Projector sps...
No power on Compaq MP2800 Microportable Projector
I am currently struggling with this issue.
There is an easily-accessed fuse inside the projector.
I was very excited to discover this last night.
However, before you get you're hopes up (as I did) remember: If the fuse blew, something else probably went first. After buying and replacing the fuse today, I realise that I need to replace or repair the power supply as it pops the fuse every time.
Here's how to get to the fuse:
Take off the lamp.
Now, looking at the projector from the back, you need to remove the left hand side panel.
This involves taking out 2 screws from that panel, 2 from the bottom and the 2 video connector hexagonal bolt things that are also in that panel.
The panel sort of hinges off, starting from the bottom.
You will see the fuse in the bottom right corner where the power lead goes.
It is a slow-blow (time delay fuse) so get the exact same one to replace it. A pack of 10 cost me €4.19 in Maplin, Galway, Ireland.
Anyways, this did not do the job for me... the power supply set the fuses off like fireworks and also blew a few in the socket plug as well (I don't think US readers will have those)
I will let you know how I get on with the power unit....
Good luck to ye!
Sep 23, 2007 | Compaq iPAQ MP2810 Multimedia Projector
96 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Tony
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
