Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Suction my powersteramer pro wont **** up water can u tell me how to fix it
  • 4 more comments
  • e3145 Jul 04, 2008
    want release water and when it does, it want **** it up.
  • 717sweetpea Aug 22, 2008
    Mine won't pick up the water either. Also there is something that when I try to push it forward seems to catch.
  • susan wagner Mar 21, 2009
    My hand tool lost the suction it had when I first got it. I haven't even had it a year. The plastic is on right and the belt is ok.
    the hand tool lost it's suction. I've had it for less than a year. The belt is ok and the plastic is on right.
  • luvneverfail May 23, 2009
    The suction doesn't isn't working properly
  • CJ C
    CJ C May 11, 2010
    try moving the selector from tools to floors and see if that works
    Problem Solver:
  • 16 Answers
Your machine has a clear plastic front cover. its on wrong.
if it has an inner crescent shaped one it may be that one.. the fact it catches on the ground... guaranteed.. and yes i used to answer the phone for bissel in this regard.. hell call em the number is on the model # tag..
Posted on Dec 19, 2008
Why won't my Bissell pro heat wont suck up water with the upholstery tool
You may have a valve that switches from floor suction to tool suction. This could be not deployed or stuck.
Nov 09, 2014 | Bissell 2X Proheat 9200 rug cleaner
My bissell pro heat pet carpet cleaner wont suction
I have a pro hear Boswell I can't.get it to sick up water help
Apr 03, 2014 | Bissell Vacuums
Bissel Pro Heat carpet cleaner is not suctioning cleaning water off of the carpet back into the tank. How can I fix this?
There is a knob on the base that says floor and tools. Make sure that it is closing when you switch it to floor, Make sure that the hose works when you use it too. That will tell us what the problem is.
Jan 30, 2014 | Bissell 1699 ProHeat Clear View Upright...
What cause it to stop sucking up the water?
has anyone answered.you or figured it out yet I just bought one and the suction wont work at all not from bottom or the attachment part heat works solutions works no suction at all help!!!please email me at taraamcgavran20@gmail.com
Jan 17, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a bissel pro heat 2x and it wont spray
I love these and have 2 of them! The warrantees are usually good and it is your pump if both the hand held and carpet positions won't spray water. Both the soap tank and water resevoir need to have at the very least water in both for the unit to work. Yes... You can use just hot water for light cleaning in both. The pump controls both the spraying water and suction. Last, if one or the other won't spray, the unit can have residue blockage. The passages are narrow, check to see if they are clean. Last test. Turn it on, release the handle. At the base of the neck there will be an oval shaped opening. With the handle on the floor as if filling the unit with water...put either your hand or a paper plate over the hole to see if there is suction. If the pump is good, you will feel a lot of suction against your hand or the flat surface of the plate.
Sep 05, 2011 | Bissell Vacuums
Bissell proheat2 Wont spray water, or the suction isn't picking up.
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Nov 20, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Will not **** the dirty water back in.
check for clogs in hoses and head.mine gets clogged up all the time.
Jun 06, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
MY BISSELL PROHEAT WONT SUCTION
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
ffuutr
Jan 28, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Eureka Atlantis Rug shampooer wont **** up the water, how can I fix it. Thanks Dennee
make sure that the two slide-tabs on the front of the machine are all the way down so that they can hold the front see-through cover down and create suction at the front. I did the same thing. you can tell when they get moved while cleaning because you will hear a muffled pop like something just got sucked into the vacuum. It is just the sound of suction being broken.
Jul 17, 2008 | Eureka Atlantis 2595A Upright Wet/Dry...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
174 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
