Question about RCA HD52W56 52" Rear Projection HDTV
Picture I was watching the tv and the picture went funny. The color is off and the picture curves inward and it has shadows....can you help? Thanks Laura
  • 5 more comments
  • jenknower Jun 15, 2008
    SEE RED ,BLUE,GREEN LINES ACROSS SEE SHADOWS PICTURE LOOKS DIFFERENT
  • sicnyc Jun 17, 2008
    52 in rca hdtv inward curve, shadows, off color, 2 1/2 years old
  • RCATVBroke Jun 17, 2008
    Picture showing funny and fuzzy and inward
  • Anonymous Jun 23, 2008
    Is there any way to fix it by manually moving the lens by the notches around the housing?
  • jclunn Jun 23, 2008
    Having same problem. Color is separated, appears as red shadow, bule shadow and green shadow around figures. Picture curves inward from the top and the bottom. Wanting to know if anyone has had a repair done and what to expect as far as cost to repair.
  • Jskrillz11 Jun 27, 2008
    TV has lines and curves inward then outward towards the edges. tv has a wierd picture and seeing doubles with different colors
  • sherry3335 Jul 09, 2008
    same problem as everyone else is there anything that can be done
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Convergence bad have it rebuilt
Posted on Jun 04, 2008
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
I have a Toshiba 57H81 57 in. Rear Projection Television. The picture started having "squiggles" in it, which at first went away after the T.V. "warmed up". Now they appear to be...
Ur tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replace on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 22, 2011 | Toshiba 57H81 57" Rear Projection...
PICTURE IS BOWING INWARD AND THE COLOR . LIKE PERSON FACE IT WILL HAVE A SHADOW OF RED, BLUE, GREEN, YELLOW
Tv have a problems known as a convergence problems,it dead.Colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts are dead,must be replaced on the tv convergence board to repair the convergence problems.The shop,will cost u $300,350 for parts and labors.
Sep 14, 2010 | RCA HD52W58 52" TV
Picture is multi color, double shadows, curved
This is failure of convergence out ICs in TV. Qualified TV tech will replace convergence out ICs or board.
Feb 14, 2009 | Philips Televison & Video
Convergence
Convergence. your convergence has failed. first questuion does the autoconvergence work.. in the customer menu under setup do you have the convergence option if you do not go to the tips and tricks section under my profile and read the article fl231 problem this is a simple inexpensive repair. NOw if you do have that option then you may need to replace what is known as convergence power supply
Oct 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Color is off and picture curves inward
Depends on your geographical area...300-450
Jun 23, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA Projection TV model #p61926
The convergence circuit is your problem and most times with this model the convergence power supply bd. is the problem.
Feb 11, 2008 | RCA P46921 46" Rear Projection Television
Tv repair
My Tv was doing the same thing, and I had to unplug the set in order to get rid of the blinking light. And what i did was to turn the power on and as soon as i saw the picture i turned it off, I did this 5 times and on the 6th time I let it power and tv stayed on, however something did happend to my set, i found that my convergence was wacky. Tried to center convergence but i could not center the blue. Turns out, i think the problem is with my Convergence ICs that went bad. I can still watch tv but the Image has blue color shadows and the picture slightly bows inwards from top and bottom. To sum this up, i will need to replace 2 ICs, IC C5AA00000203, and this should fix my problem. I will do this repair myself, each part is about $41..
Let me know what happened to your problem.
Thanks
Tony
Dec 01, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
RCA HD52W56 52" Rear Projection HDTV Logo
91 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
