Question about ASUSTeK M2A-VM HDMI Desktop Board - Athlon 64, Athlon 64 FX, Athlon 64 X2 Dual-core, Sempron - nVIDI... Motherboard
Support DX10 does my Asus M2N-VM HDMI support DX10
  • ASUS Master
  • 13,433 Answers
Nope, it is a DX9 integrated solution - not good for gameing
Integrated Nvidia® Geforce®7Series Shader model3.0 DirectX 9 graphics processor
Maximum shared memory of 256 MB
Supports RGB with max. resolution 1920 x1440 (@70Mhz*32bpp/75Mhz*16bpp)
Supports DVI-D with max. resolution 1920 x1200 (@60Mhz)
Posted on Jun 04, 2008
No monitor signal on my m2n-vm dvi after installing my new graphics card asus en210.The graphics card was tested on my other pc and works fine..any help?
First boot the computer without connecting Graphic Card, then go to BIOS and find for VGA option change the option to compatible mood, save the setting and come out of it. now off the computer re connect your graphic card and start the computer.
Aug 15, 2012 | ASUS M2N-VM DVI - Motherboard - micro ATX...
What type of battery does the M2N-VM DVI motherboard use?
Most motherboard BIOS batteries use a 3 volt lithium battery, this is a coin size battery type CR2032
Apr 06, 2012 | ASUS M2N-VM DVI - Motherboard - micro ATX...
MB drivers for Asus M2N-VM DH for Windows7
Go to their support site:
http://support.asus.com/download/download.aspx?modelname=M2N-VM%20DH&SLanguage=en-us
Select Windows Vista instead. Vista and Windows 7 have the same kernel so the drivers are compatible. Just make sure you choose correctly between 32/64bit. Please vote if this helped you. Thanks.
Mar 07, 2011 | Computers & Internet
I need all lan and wan and audio drivers for the M2N-VM DVI
Here is the website with all drivers and you just have to chose the operating system (windows xp , windows 7 etc)
http://www.asus.com/product.aspx?P_ID=fyD1uSu233yBDeCq
Mar 05, 2011 | ASUS M2N-VM DVI - Motherboard - micro ATX...
How can i run C language on Asus M2N VM HDMI motherboard
My favorite answer to C questions is http://www.microsoft.com/express/vc/
M$ are giving away Visual C Express, a windows C & C++ development environment & support it
But if you have a favorite you wish to use read on::
  • many compilers/interpretors require the source file name in the command line or exit with nothing to do
    assuming your c interpretor is RUNC.EXE runc sourcefile
  • try running the c compiler/interpretor from a command prompt instead of directly typing the name in a shortcut,
    start
    run
    Cmd
    runc (or runc sourcefile)
  • or try compatibility mode for a windows98/95 program (dos ran pretty well under win98se) until you find something that works
    right click the shortcut that launches the c compiler or c interpreter,
    properties
    compatibility
  • or load win98 in a virtual machine and code on that (as a last resort)
  • development is easier, there are a bunch of notepad replacements for windows that support code highlighting for c so will make syntax checking simple
Jul 16, 2008 | Computers & Internet
About motherbord drivers
You really don't want to run Windows 2000 on that setup. You should run at least Windows XP instead.
Support for Windows 2000, especially with modern processors like you Athlon64 X2 is limited. You have a good processor and motherboard. It would be a shame to cripple them with an old OS.
May 26, 2008 | ASUS Computers & Internet
IDE ports in asus m2npv-vm & m2n-mx motherboards
hi, i have a couple of those boards. they have 2 ide ports on them and 4 serial ports. if youu do get the m2npv-vm, one thing that is weird about it, one faces up from the board and the other lays flat off the edge. also the ports are right next to each other and the polarity (which side you put the ribbon cable stripe on) is opposite each other. so if you don't use a keyed ribbon cable you might hook them up wrong.
Aug 22, 2007 | ASUS M2NPV-VM Motherboard
ASUSTeK M2A-VM HDMI Desktop Board - Athlon 64, Athlon 64 FX, Athlon 64 X2 Dual-core, Sempron - nVIDI... Motherboard Logo
159 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
