Try this;
Go to (>) Start>Control Panel>Bluetooth
A window will open showing you all the wireless devices that are already recognised by your computer. If the icon for this mouse is shown there then highlight it and click 'Remove Wireless Device'. Then click "Yes" (Sometimes removing a device and then reinstalling it fixes the problem)
NOW
Click on Add Wireless Device ( a new window will open and the computer will search for the device. When it finds the mouse an icon will appear. Highlight the icon and click Next
The computer will load the driver for the mouse.
Once this is done the mouse should be working OK.
Also check this:
Click on "Bluetooth Settings"
Place a tick in the box next to "Allow Bluetooth devices to find this computer > Apply > OK
on the receiver there is a a little circle with the words connect around it. Its actually a button you press that and you should see the receiver should light up make sure the receiver is connected the computer and press down right on the circle. after it lights up press connect button on the mouse and it should start working again
unplug the mouse sending unit from the computer remove batteries out of the mouse and let it sit for 5 minutes, reinstall batteries after 5 minutes be sure to get them in right, next plug the mouse in with the computer off then turn on the computer afterwords push the connect button on the mouse and the wireless device connected to the computer at the same time. then let go, does it work? Yes? your done No? then try a different plug on the back of the computer also notice if the Lazar is on when you pick up the mouse, if this does not work try switching the connection of the mouse with another device to see if the connection went out on the board. Hope this helps.
Hi there. Some wireless mice seem to go into some kind of sleep mode, in other words if you leave them for an amount of time they disconnect, the way to reconnect is to right click while moving the mouse. Also check to make sure that the batteries in the mouse are seated properly.
You have to press the button on the receiver that is directly connected to the computer. While doing this, press the connect button both the mouse and the keyboard. I did this and now my keyboard is working, despite the battery indicator turning itself off a few seconds after I install it.
Normal
0
Turn the mouse over and find the small
rest/connect button on the bottom of the mouse and press it to
Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press
the mouse. This should be done whenever you change batteries or
glitch.
Hope this helps you. Bud
I think you said you changed the batteries. if so try the following.
Normal
0
rest/connect button on the bottom of the mouse and press it.
This should connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the button on
glitch.
