My Indesit IDL 50 fails on all cycles apart from No. 4. On all others It seems to start normally but then it will stop and I get flashing green lights on 1 and 2. At this stage there is approximately 1cm of water in the bottom of the washer that won't drain until I reset and then use program 4.
-   hello! Calling from sweden here:)
I have the same problem, the dishwasher stops and the first and second lamp are blinking and there is a little water at the bottom. I cant figure out how and what it is??
pleas help med-   Guest
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
Was this helpful?
Yes
No
Popular Solutions for Indesit 24 in. DE73 Evolution
Indesit 24 in. DE73 Evolution Free-standing Dishwasher
I start up the dishwasher then after a while I get the error code A03 flashing. can you please tell...
(More)
I start up the dishwasher then after a while I get the error code A03 flashing. can you please tell me what you think it could be or why this is happening. Regards Kathy
