Question about Sharp AL-1642CS Copier
Toner Dumping in machine
I have toner spilling into my machine. It is all over! There are no lights or error messages indicating that something is wrong. But my copies are covered with slotches of black and the toner is not fusing properly to the page. Do I need to replace the drum? What is the best way to clean the toner?
  • Sharp Expert
  • 1,326 Answers
Do you have a shop vac with a hose on it? Turn the copier OFF and UNPLUG it from the WALL and use the vac to do all the lose toner & use a brush to get into the cracks and hard to reach areas. The blotches are most likely coming from the paper path, make sure you clean the whole paper path and run some blanks pages in the copier to clear up any left over... Good Luck
Posted on Jun 05, 2008
I have sharp ar-5316e indicator massage error ink.drum. toner
Toner indicator says that there is low toner in the machine. It is necessary to replace toner cartridge and then continue with other error messages.
Apr 29, 2017 | Sharp Office Equipment & Supplies
Message the toner bottle is full please call the server machine printing rico 4500
The bottle full message indicates that the waste toner collection bottle is full. The full bottle needs to be removed and the toner disposed of properly. Then a replacement collection bottle needs to be installed and the waste toner counter reset. This site has the toner bottle: http://www.precisionroller.com/waste-toner-containers-for-ricoh-aficio-mp-c4500/details_47769.html . It is possible to reuse the bottles but most people will spill the toner when they try to empty a collection bottle. You do not want loose toner in your environment.
Turn off the printer (at the power switch) and wait for the lights to stop blinking before attempting the replacement. See page 62 of the network guide for the replacement procedure. See https://www.ricoh-usa.com/downloads/downloads.aspx to search for your printer and get the manuals.
I hope this helps
Jul 06, 2015 | Office Equipment & Supplies
Have an error message on my oki B4600 that I cant get to reset
you should have an RFID chip in the toner try replacing the RFID chip for the toner
Jun 09, 2014 | OKI B4600 Laser Printer
My bizhub c25 waste toner was full so replaced and will not now reset.
The C25 stores toner in a waste toner container. On the front of that container there is rectangular clear window that fits into a sensor when installed into machine. The sensor passes a beam of light through that window. When the bottle is full there is toner inside that clear plastic window which stops the light from making it through the window and the machine will tell you the waste toner is full. Just dumping the container out will not clear that window and by putting it back in the machine you will get the same toner full message. If you are going to try to reuse that container you will have remove the black plastic cover that is glued to the container above the clear plastic. Then use something like a Qtip to clean all the toner off of that clear window(much easier and faster to just replace in with a new container). if you still get the waste toner full message after you install it then remove it and wipe off the sensor that the clear window sits in. This will clear the message and you can continue your copy job.
Apr 02, 2014 | Konica Minolta Office Equipment & Supplies
Toner dumping straight into toner bag
use original toner OR reset toner indication
Sep 12, 2012 | Toshiba 2860 Copier
I am getting the Replace Waste Toner error on my Ricoh CL3000. I have already emptied and cleaned the waste container, and blew off the section of the printer I install the waste bottle onto, but I'm...
not a solution - but a problem... i emptied the toner waste bottle in my MPW2400 and a new error message appears...says there is no toner and it keeps dumping toner from the new cartridge until it is coming out of every orifice of the machine. What is that about?
Sep 06, 2011 | Ricoh CL3000E Laser Printer
Error code 19
E019
Indicates that the waste toner case is full.
Thereafter, if the waste toner case is not replaced after making a total of about 2000 prints
(A4/LTR), the machine will indicate 'E019' on the control panel; the error code can be reset
by replacing the waste toner case and then turning off and then on the power switch.
If the waste toner case is not set, the light-blocking plate will block the light between the
photosensors, causing the Waste Toner Case Full message to appear.
Feb 04, 2011 | Canon imageRUNNER 2200
Xerox DC12 Error code 9-355
Error code 9-355 indicates, the magenta toner dispenser is broken and in need of repair.
Open the Front Door
From left to right, the Toner Cartridge colors are Cyan, Magenta, Yellow, and Black.
As a pre-caution, place a few sheets of paper on the floor, under the Toner Cartridge area, to catch any toner that may spill.
Remove the Toner Cartridge by rotating the handle to the left until the handle is in the unlocked position.
Pull the cartridge completely out of the machine.
Check for any obvious damage in the cartridge or printer and reinstall. Replace cartridge if damaged.
If error message continues, call a qualified repairman.
I hope this helps you fix your printer.
Jan 28, 2011 | Office Equipment & Supplies
What is C 710 error codes?
You machine toner is empty insert toner
Jun 14, 2009 | Kyocera KM-1505 Copier
102 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
