Question about Sony PS-LX250 Turntable
Won't start Hello, I've had the SONY PS-LX250H for three years now, and gradually a problem has worsened where if I push start, the arm lifts up, moves to the record and begins playing, and then lifts up and returns to its holder after about a second. If I put the arm there manually it still lifts up as if I've pressed the stop button. No matter what tricks I do the arm lifts up and returns to its holder immediately after playing. Sometimes if I quickly move the arm onto the record i can manage to get it to continue playing.  Any thoughts? Your help is greatly appreciated.    Thanks so much,  Rob
  • 1 more comment
  • Anonymous Jan 12, 2009
    I am having the same problem, and it is driving me nuts.
  • drewbody Mar 08, 2009
    I also have this problem, let me know if you find a fix.
  • Anonymous Apr 01, 2009
    i have the same problem, anyone with a solution yet?
I had the same problem with the arm constantly starting and stopping, and the suggestion above works. Despite, I was a little confused on how to do it. Here's what I did in detail:
- Remove the turntable mat.
- Unhook the belt and remove the turntable platter.
- Once the platter's removed, you should see two plastic white gears in the middle. Rotate the center gear clockwise until its tab hits the larger gear. The center gear should move freely and without resistance until you hit that gear.
- Put the platter back, making sure to re-hook the belt around the spindle.
- Put the mat back.
After that, you should be set!
Posted on Aug 23, 2009
Needle Won't Stay Down
Hi, sounds like the automatic function has gone out of time. With the record player powered of spin the platter manually appox 12 times to reset. Cheers john. Stylus City
Jan 24, 2014 | Sony PS-LX250H Turntable
Sony turntable ps-lx250h won't stop turning it has to be unpluged. what do i do?
When the arm moves it contacts a switch which should start and stop the motor. Clearly this switch has broken and the contacts are now in the on position.
Jan 18, 2014 | Sony PS-LX250H Turntable
Hi, I've had this turntable for about 10 years. I have moved a few times and this may be the cause. The problem is that the platter starts spinning once the unit is plugged in. It won't stop until its...
I suspect that you might have dislodged some of the mechanical parts in the move. Or something plastic has broken. The only cause of action is to remove the bottom of it and look around it.
Aug 18, 2013 | Sony PS-LX250H Turntable
Sony PS-LX55II Tonearm Doesn't move when playing
Is there an antiskate or skew adjustment and also a way to set that counter weight? If any of those are wong then it wont work
May 11, 2013 | Sony PS-LX250H Turntable
Sony PS-LX250H Player arm won't set down to play
Have you made sure the "up/down" button is not depressed? It's the furthest button to the right of the player if you are looking at it head-on. If it is depressed, it will cause the needle to simply hover above the spinning record. A good thing if you want to "pause" your musical experience, but not much help if you are trying to enjoy some sonic sensations.
Nov 23, 2012 | Sony PS-LX250H Turntable
My stylus arm exerts 4 grams weight
Four grams seems a little much. I find it hard to believe Sony relied solely on an inaccessible spring for stylus pressure adjustment. Back in the day, we used to tape a coin on top of the back end of the tone arm to adjust pressure so it may be necessary to improvise
Sep 29, 2012 | Sony PS-LX250H Turntable
My Sony PS-LX250H turntable will only spin at 45rpm. When i push the speed button for 33 it doesn't change. i also sometimes have to give the deck a little push to get it to spin.
I have the exact same problem for the same model. Only spins at 45 and I sometimes have to kick-start it. I tried de-activating the switch (so that it's not making a connection) and therefore in the 33 position but that does not help.
Dec 14, 2010 | Sony PS-LX250H Turntable
I push the start button and no power
You need to check if any internal fuse has blown. Next the switch itself might have broken.
Dec 13, 2009 | Sony PS-LX250H Turntable
How do i replace belt on lx250h?
Not sure about yours, but some of these one lifts the rubber pad to get access to the belt through holes in the platter when you are re-installing to get the belt back on the hub it runs on. One usually has to lift the platter off to get the belt around the center hub and the motor pulley first..
You can probably find the belts online with a Google search.
Dec 10, 2009 | Sony PS-LX250H Turntable
Sony PS-LX250 Turntable Logo
585 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
