Question about Toshiba Televison & Video
Model CF1926A TV with insufficient vertical height. I replaced c308, c305, c301, c315. voltage was missing from ic501, pin 29; restored with replacement of c301. no help to vertical. voltage was missing from ic501, pin 37. replaced c315, still no voltage pin 37. 9 volt supply is present. ic301: all voltages present & correct, except pin 6, which jumps up when meter lead touches leg, then fades to 1/4 volt. replacing c308, d301, no effect. vertical is 6 inches top & bot short of full screen. Height control works properly. no resistors found bad. 26 volt line good, 9 volt line good. Is ic301 bad? output voltage is 1 volt high at pin 2. Pins 7 and 3 have same voltage, as though d301 might be bad, but replacing it resulted in no change.
  • 4,234 Answers
I think you missed one cap. Look for another 1ufd cap close to the jungle chip. It will have the circuit designation in the 300's like the others in the vertical circuit. It is just not located close by. I think that one will fix it.I don't have the service data with me so I can't give you the exact designation.
Dan
Posted on Jun 04, 2008
Tv came in shop with shot down problem ,checks were made and a resister for the vertical supply was open..after replacing , set come on only with insufficiant vertical sweep at top and bottom.. am at my...
Have you checked all the solder terminals of the vertical output IC, for any loose contacts? Check it. Re-solder all the suspected solder terminals by applying a little more solder. Check all the low value capacitors at the vertical output section circuit. Replace all of it at once, with same capacitance and voltage ratings. If these do not help you, have to enter its service mode option to adjust the vertical height, linearity etc: By the way, what is the brand name to your TV? What is the number of IC used as vertical scan output. For more information: http://electronicshelponline.blogspot.com/
Nov 18, 2013 | Televison & Video
My sanyo ds20425 has a white horzontal across the screen
On most , it is caused by Vertical IC and sorrounding components
Guide on How to find Vertical IC
Look and check for cold solder joints for IC501
part number
LA7840
Resolder the pins of the IC , and replace if necessary
Let us know if you need further assistance.
Sep 21, 2012 | Sanyo DS24205 24" TV
My sony tv model no. kv-ha21m80 is on standby mode & its LED is blinking four times that means it has some problem in vertical section.But when I tried to check voltages of its vertical IC AN5522
Disconnect Vertical supply and so that your Horizontal system run check all voltages before connecting vertical again ...should the protection come in again when vertical connected ...replace Vertical Ic and safety resistor in line
Apr 21, 2012 | Televison & Video
My Panasonic TC-21Z88RBN doesn’t displays the total picture vertically ,when the picture is display it like not in the center of the screen sum of it is disappear in the bottom
Hello
Your TVs vertical output section has the fault. You just open your TV after disconnecting it from the AC mains wall socket, and locate the vertical output section. This section uses an Ic marked as part [IC 401] on the board and its number is LA7840. Just look for any loose soderings around its components legs, and the solderings at the IC legs, which has 7 of them. The IC stated above will be screwed onto a heatsink to radiate heat out of it when it works.
If all soldering point are fine, come towards the IC legs and measure the voltages at each leg. The voltages must be
pin 1= Ground
pin 2= 12.6
pin 3= 24.7
pin 4= 4.4
pin 5= 4.4
pin 6= 24v [vcc]
pin 7= 1.8
All voltages stated above are DC voltages with respect to ground. If any of this voltage is missing, find out the reason for that. If all of them are noted abnormal, IC may be defective, and replace it.
[vcc] stands for main input voltage to the IC.
If you need any more assistance, feel free to contact me through Fixya. Ok.
Dec 07, 2010 | Panasonic TC-21Z88R 21" TV
Magnavox color tv model no 20MT4405/17 vertical shrinking
Hello
Vertical shrinking means lack of height we thinks. If there is a height problem for philips tv, surely some of the philips electrolytic capacitors should be replaced. Most of the electrolytic capacitors made by philips shows either a slight leak or lack in capacity after some years or days after use. When replacing them make sure to select other brands of same capacity and voltage ratings. If this doesn't help, get into the service mode of that tv and adjust "VH" and "VLI" functions, if you knows the service mode code. If you don't know it, please get assistance of a technician.
Oct 15, 2010 | Philips Televison & Video
Vs 5043 mitsubishi no picture
Dear dc_rock,
These the most common failures for this TV Model VS-5043- VZ3:
1. Check base bias Voltage of Q217, for 0 VDC (BIASED OFF) if .7 VDC (BIASED ON) check C268 (22 UFD 50 V) off C OF Q215 V-Protector on the SIGNAL PCB.
2. Vertical Beam Blanking Active, check PIN 4 of IC401 for 3 VDC. If missing check IC202 (5V REG) PART # 266P932010, on The SIGNAL PCB.
3. Check Pin 6 of IC200 for 9 VDC if low or missing check IC203 Part#
270P210010 on the SIGNAL PCB.
Thanks for using FIXYA, big IRISH.
Dec 25, 2009 | Mitsubishi Televison & Video
Top half black and bottom half OK on 27" Trinitron
could be an easy fix, soldering the pins on the vertical IC (IC501 I think)may fix it. also check the standup board pins being loose/dirty on the left rear (if yours has one). best quick test is bang on the set and see if the top half comes back for a second, if it does you have bad connections, an easy fix if you can solder.
thanks
E
Jul 18, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Toshiba CF3254j
You may have one or both caps in backwards =
Observe polarity and re-check............
Nov 05, 2007 | Panasonic TX-28CK1 28" TV
No vertical deflection
Never heard of this model/make. Must be a label TV How many pins and whats it start with ie TA-LA?
Aug 19, 2006 | NetTV DTV-29XF3 29" TV
Televison & Video Logo
309 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
