Question about Eureka Mighty Mite 3670 Bagged Canister Vacuum
Won't work My Eureka Mighty Mite 3670 Bagged, was working fine, and we unplugged it to switch to another outlet in another room and it just stopped. We tried several other outlets and it just won't turn on. We thought maybe it got hot because we had been using it for a while and we let it rest for a while and then changed the bag just to be sure, although it was not full. But it still will not turn on. Any ideas?
  • Anonymous Jun 06, 2008
    I had the same problem today. Have a 9 amp model I bought 10 years ago which I never use. Has been sitting for years. Today put in new bag and ran it continuously for 45 minutes. After I turned it of it wouldn't restart. Tried another outlet and wouldn't restart. Felt canister at back and motor housing was hot so I thought I might need to let it cool down. After letting vacuum cool off for 10 minutes it restarted. All I can assume is that the vacuum has a built in overheat sensor on the motor.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=12151&thid=646957
Won't work (by 2 users)
Posted by AndiR on Jun 04, 2008
My Eureka Mighty Mite 3670 Bagged, was working fine, and we unplugged it to switch to another outlet in another room and it just stopped. We tried several other outlets and it just won't turn on. We thought maybe it got hot because we had been using it for a while and we let it rest for a while and then changed the bag just to be sure, although it was not full. But it still will not turn on. Any ideas……X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
1 Other User Has the Same Problem Comment by Guest, posted on Jun 06, 2008 I had the same problem today. Have a 9 amp model I bought 10 years ago which I never use. It has been sitting for years. Today put in new bag and ran it continuously for 45 minutes. After I turned it of it wouldn't restart. Tried another outlet and wouldn't restart. Felt canister at back and motor housing was hot so I thought I might need to let it cool down. After letting vacuum cool off for 10 minutes it restarted. All I can assume is that the vacuum has a built in overheat sensor on the motor. Hello,
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka Mighty Mite #3670 Bagged Canister. I have the same type Mighty Mite Canister and from what you are saying the must be some type of heat sensor that is shutting off the motor to protect it from excessive heat. Al of the old ones have had lower amps and did not needs the heat sensor but once the bag is full and the filter clogged; they will shut down as well. They all use a plastic hose to clean with and that even gets hot sometimes. So I suggest that you get an owner’s manual from the manufacturer on you particular model so that id if happens again, you will be prepared. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
5855 Terry Fox Way
Mississauga, Ontario L5V 3E4
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 09, 2008
Our's did the same thing. I cleaned the clogged motor filter, took out the clogged hepa filter and replaced the bag. In my case the plugin arc'd and I also had to replace the plug for safety. All is well now.
Posted on Aug 22, 2010
Eureka Mighty Mite 3670 Bagged Canister Vacuum just stopped working
Should be under warranty. Take it to a warranty center for repair
Jan 05, 2014 | Eureka Mighty Mite 3670 Bagged Canister...
Need to replace belt in eureka envirovac model 4470
You must remove the screws that hold the top cover onto get to the belt. Remove top cover then remove brush roll to install new belt. Replace belt at least twice per year for proper cleaning.
Oct 26, 2013 | Eureka High Filtration s Mighty Mite...
Eureka 4870 brush won't stop turning in upright position
there will be a linkage that as come loose and not operating the limit switch to turn it off, try looking at 23. Idler Clamp Assembly on the link below.
http://www.vacpartswarehouse.com/Eureka-4870-Ultra-Smart-Vac-s/1928.htm
Jan 27, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
My Sebo hoover trips the house mains sockets every time I switch it on, yet doesn't trip the kitchen mains. Have replaced filters/bag to reduce load but still no good. What should I be investigating in the...
It sounds like your vacuum is fine if it works when plugged in the kitchen outlet. It is tripping the breaker switch in the other room because the circuit is overloaded (too many things plugged in this circuit). Try unplugging some things in that room and try your vacuum again.
If it only trips when using one particular outlet, then the outlet should be replaced. I would recommend having an electrician check your wiring out.
Hope this helps
Feb 01, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Brush stopped rotating and little suction on unit.
Even though the brush is spinning, you probably need to replace the belt2_bing.gif because it is stretched. It is probably slipping on the beater bar..
Jim
Nov 28, 2009 | Eureka High Filtration s Mighty Mite...
How to change the belt on a Eureka Mighty Mite II.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=700499
Generic problem for all Vacuums
Posted by Sawpit1 on Jun 23, 2008
How do I change the belt on a Eureka Mighty Mite II.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Normally the Mighty Mite II does not have a belt unless you have the model with the turbo head and then I believe it is a geared belt and then you can pup the belt from your local vacuum cleaner dealer or the Eureka factory parts dept. there are 2 to 4 screws on the bottom of the turbo head and then I believe the top will come up and then you can get to the belt. The average belt change is every year if it is a geared belt for the best cleaning or if you have a flat belt it is every 4 to 6 months. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Go Ahead. Use Us.
Jun 23, 2008 | Vacuums
Eureka Mighty Mite 3670 Bagged Canister Vacuum Logo
728 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
