Question about Gigabyte Slot 1 GA-BX2000 Motherboard
Motherboard GA-BX2000 dose any one knows the sequense of the connections from the front panel to the motherboard? replaced power pack and for some reasn removed the cables from front panel to board
Go here.....page 37 onwards
http://europe.giga-byte.com/FileList/Manual/motherboard_manual_bx2000_1002_e.pdf
Posted on Jun 04, 2008
I need the front panel connections location, which ones go where for the ga-73pvm-s2h motherboard
Gigabyte has the manual for the GA-73PVM-S2H on the product support site: http://www.gigabyte.com/products/product-page.aspx?pid=2691#manual . The full manual is near the bottom of the list. The direct link to the English version of the manual is http://download1.gigabyte.us/Files/Manual/motherboard_manual_ga-73pvm-s2h_e.pdf . The Motherboard Installation Guide at the top of the list is a generic manual for all motherboards.
The front panel connections are shown on page 28 of the manual. There are two lines of pins. From left to right, the inside line of pins are the Power LED +, Power LED -, Power Switch +, Power Switch -, then the Case Speaker +, Case Speaker -. (The speaker - is next to a Case Fan connector; so there are a couple of blank spots between the speaker + and - pins.) On the line of pins at the edge of the board, again from left to right: HD LED +, HD LED -, Reset Switch -, Reset Switch + . There is no contact on the last pin in this group.
I hope this helps.
Jun 06, 2016 | Gigabyte Computers & Internet
Building computer from scratch need to know where cords connect
Not a problem hicksdusty3
Post the motherboard manufacturer name, and model number.
In the meantime here is a Generic guide, (Which I despise posting),
Power cables;
http://www.playtool.com/pages/psuconnectors/connectors.html
IDE (PATA) data cable information,
http://en.wikipedia.org/wiki/Parallel_ATA
SATA data cable information,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
http://en.wikipedia.org/wiki/File:SATA_Data_Cable.jpg
The plastic front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
Known by many names, and abbreviations.
I CANNOT give you the Front Panel pinout, without knowing what Exact motherboard we are dealing with here.
Can't tell you where to attach what cable to where, on the motherboard, or any peripherals.
(Harddrive/Optical Drive {CD/DVD drive)
I also need to know if the Harddrive is an IDE (PATA) unit, or a SATA unit.
Same with the optical drive/s.
Post back in a Comment.
Regards,
joecoolvette
Mar 01, 2013 | HP Computers & Internet
I have a packard bell winfast mcp61dm2ma-8ers2h mother board, with a gigabyte ge-c3209-a2 power box that is in a gigabyte 24zm1-bpd715-32r chassi. I recently took the whole thing apart to clear all the...
The first thing I would do after I copied off all personal info, is to smash that computer into little tiny pieces, pack it in a box, and ship it to Peckerd Bell. "Here.........this is whqat I think of your computers, and your 'support'." (Support = $$$$$$)
OH, did I say that out loud? My bad. lol!
Rant off.
I love the nomenclature you used Jan. You are definitely my kind of people! (Power box)
1) Let's go back to the beginning Jan, and look at the 3 power cables to motherboard;
http://www.ebay.co.uk/itm/PACKARD-BELL-Winfast-MCP61DM2MA-8ERS2H-AM2-/130457057251?nma=true&si=BtiiltyOkHpDiIr8VnpbUWON7BQ%3D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
I see that a 24-pin ATX main power cable, plugs into the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
[NOTE* Color of connectors does NOT matter]
,and a 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Yours plugs into the white square 4-socket hole connector, that is by the Top/Left corner of the motherboard.
That's it for power cables from Power Supply, TO motherboard.
The SATA harddrive also requires a power cable. A SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Note that a SATA power cable's connector has 15 contact pins.
Between it, and a SATA data cable, it has the longer connector.
A SATA data cable's connector has 7-pins,
The SATA data cable example is at top.
A SATA motherboard connector example is at bottom.
YOUR SATA connectors look different. They are the two Blue connectors below the Ram Memory slots, and to the left of the black round piezo buzzer.
Note the L-shaped opening of the SATA data cable connector.
The SATA power cable connector also has this L-shaped opening.
Lines up with the L-shape on the motherboard connector, or Harddrive, or Optical Drive, connector.
The SATA data cable connector, and the SATA power cable connector; may also have a Lock on them.
Usually a small bulb type of affair, that you depress with your thumb.
Depress the Lock to install, or remove.
The SATA cable connector, power or data; that goes to the Harddrive, or Optical Drive; is usually a 90 degree bent elbow.
The connector end of the SATA data cable to motherboard; is a Straight connector.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
Sometimes abbreviated as FP_PANEL, or FP, or FP1, or PANEL; just to name a few abbreviations.
Does it look like this Jan?
http://www.intel.com/support/motherboards/desktop/sb/CS-009016.htm
Wiring from the Front Panel.
No easy guessing game here. Color code you have MAY be right, may be not.
Remove the Front Panel. See where the wires lead up to.
Wires that go to the Power On switch, and Power On LED, may be in the same area; but the HDD LED is away from them, and should be easy to spot.
Now you are down to the Power On switch, and Power On LED wires.
Suggest process of elimination.
It's usually pretty easy to see where the Power On LED wires go.
Right TO the Power On LED.
Now you know the other wires are for the Power On switch.
Still no?
Then remove all wires from the Front Panel header.
According to the info I posted in the link, the Red area's 2 pins are for the Power On switch.
BRIEFLY touch a small flat tipped Jewelers screwdriver, to those 2 pins.
(I state Briefly because the Power On switch is a Momentary Contact Switch. No more than 2 seconds)
Power Supply still doesn't come on?
Then post back in a Comment, and I will state out the simple procedure for testing if the problem is the Power Supply.
For additional questions please post in a Comment.
Regards,
joecoolvette
(It also may be that the 'power box' you are trying to use, doesn't have enough Wattage for that Motherboard/Processor/Ram Memory)
Jan 14, 2013 | Packard Bell Winfast Mcp61dm2ma-8ers2h Am2
Replace motherboard
Rob, Rob, Rob.............if I told you a thousand times, I............
Oh.......... where was I?
1) Power cables from Power Supply to motherboard:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01237538&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3878557
A) 24-pin ATX main power cable;
Looking at the motherboard view the Right side. To the right of the Blue 39-pin IDE connector, is the 24-pin ATX main power cable connector, on the motherboard.
This is a general example of a 24-pin ATX main power cable, and it's respective connector on the motherboard,
The power cable connector has a Lock on one side, and the motherboard connector has a matching Lock Tab.
When the power cable is deemed to be installed Correctly, and Properly; the Lock's hooked end is over the Lock Tab.
[Note* Color of connectors does NOT matter ]
B) 4-pin ATX +12 Volt power cable;
The processor socket is white in color. Around it is the black mounting ring.
The 4-pin ATX +12 Volt power cable connector on the motherboard, is to the Left/Bottom corner, of that black mounting ring.
Square, whitish (Opaque), and 4 socket holes.
This is a general example of a 4-pin ATX +12 Volt power cable; and it's respective connector on the motherboard,
2) Peripheral power cables from Power Supply;
A) The Harddrive is a SATA unit. Uses a SATA power cable,
B) The optical drive/s (CD/DVD drive) are also SATA units. They use a SATA power cable.
A SATA power cable's connector has 15 contact pins. Between it, and the SATA data cable, it has the longer connector.
Peripheral Data Cables;
This is a general example of a SATA data cable, it's connector, and a SATA connector on the motherboard,
(Note* Color does NOT matter),
Here you can see the L-shaped opening of the connector, and matching L-shaped tab on the motherboard connector.
Most SATA power cable connectors, and SATA data cable connectors, have a lock. All you see is a 'bulb' type affair on top of the connector, that you squeeze down with a thumb tip.
Depress to remove, depress to install.
A 90 degree elbow connector for the SATA data cable, is used on the Harddrive, and optical drive. The straight connector end of the cable, plugs into the motherboard.
There are two SATA connectors on the motherboard. One White, one Black. One of them should have a SATA1 next to it.
(Or one will at least have SATA2 next to it)
SATA 1 connector is for the Harddrive. SATA 2 connector is for the optical drive.
The beauty of SATA is though, you can connect any SATA device, to any SATA connector on the motherboard; and BIOS will find it.
So it really doesn't matter what you plugged in where, as far as those two SATA headers are concerned.
3) Processor Fan cable, System Fan cable (Computer case fan);
Going back to the HP Support page above, and Motherboard Specifications; scroll down the list.
Click on the + sign to the left of the blue - Motherboard layout
Below the ATX12V1 connector is the System Fan connector.
(SYS_FAN)
This is where the computer case fan connects.
(ATX12V1 connector, is the 4-pin ATX +12 Volt power cable, connector)
Above the Ram Memory slots, and a little to the right; is the Processor Fan connector. Power to the fan. (CPU_FAN)
4) Front Panel audio connector, optical drive audio connector, Front Panel USB connectors;
Bottom edge of motherboard, from Left to Right;
Yellow connector is AUDIO1. Front Panel audio.
White connector is ATX_IN
For the audio cable from the optical drive.
Black connector (HD_AUDIO) is also for the Front Panel audio.
Don't know how they have the Front Panel audio, hooked up.
YOU will. The cable connectors to them are different from each other.
Further to the right are two white connectors. EACH one can support TWO USB ports.
One should be for the two USB ports in the Front Panel.
The other will go to a Card Reader in the Front Panel.
All the way to the right corner is the Front Panel header.
This is where the main wires from the Front Panel go.
Power On switch, Power On LED (light), and Harddrive activity LED (light)
The cable, and connector should match that 9-pin header.
If not here is an HP 9-pin Front Panel header - pinout,
http://h30434.www3.hp.com/t5/Desktop-Hardware/Getting-a-new-case-i-need-Front-Panel-pinout/td-p/842897
Scroll down to the photo, and pinout. (Dave G)
Believe that is it.
For additional questions, or to have me clarify anything I have stated above, please post in a Comment.
Regards,
joecoolvette
(Ya know I was jus kiddin' above, right?..............
Rob?...................................................................Rob?)
Nov 27, 2012 | Compaq Presario SR5712F (SR5712F-B) 19 in....
Dell dimension e510 flashing amber light USB front panel
If you are comfortable around computers, you could try the following to test the power supply. Unplug the cord from the power supply, hold the power button in for about 15/20 seconds, open the case, unplug the 24-pin power connector from the motherboard and jump the Green wire to one of the Black wires, reconnect the power cord and power the system on and if power supply fan and hard drive run, then the PSU should be good. Note: Do not remove any wires from the plug, use a small piece of wire or a paper clip as a jumper. Power supply checks out and the system still does not work, again remove the power cord, hold power button in for several seconds to discharge the residue power, reconnect the 24-pin connector to the motherboard. Remove all the PCI cards, the video card [if applicable], memory, all peripherals, disconnect the data and power cables to all the drives, check that the front panel cable is connected to motherboard, with nothing else connected to the system, reconnect the power cable and power the system on. If you do not get any beep codes or diagnostic lights on the front panel, then it would appear that motherboard has died.
Aug 07, 2012 | Computers & Internet
How to connect the connectors power switch - hdd led - reset switch etc on a motherboard GA-K8NSC-939 ?
Click here for the Motherboard manual and refer page No.23 for Front panel wiring details.
Feb 18, 2012 | Gigabyte GA-K8NSC-939 Motherboard
Proper installation of tower wires
According to Gateway Support, the Gateway 505GR desktop computer uses an Intel (Ausberg) 915G motherboard,
http://support.gateway.com/s/PC/R/3724/3724iv.shtml
http://www.ascendtech.us/itemdesc.asp?ic=MB4GWAUGSBURG
Scroll down to the photo with the sections marked in red.
In the top link, looking at the motherboard with the computer case open, the USB and Firewire (1394a) cables, can be seen attached to the motherboard near the letters D, E, and F.
In F that red cable is a SATA cable. One end attaches to the back of the SATA harddrive, (The angled end), and the other end of the SATA cable attaches to one of those SATA headers on the motherboard.
(SATA header = SATA connector on motherboard)
Preferred SATA header for the Harddrive is SATA 1.
DOESN'T matter though. That's the beauty of SATA. You can plug the SATA data cable into ANY SATA header on the motherboard, and BIOS will find the harddrive.
In the second link, looking at the motherboard photo shown, and comparing it to the view of the motherboard as mounted in the computer case, the Front Panel header is at the very Bottom Right.
Two rows of pins in a White rectangular shaped header,
(S points to Front Panel header)
[ The plastic front of a desktop computer is the Front Panel.
The area of pins on the motherboard, that the Front Panel wires go to, is the Front Panel header ]
A) Top row has Even numbered pins
B) Bottom row has Odd numbered pins.
1) Power LED = Power On LED light
2) Hard Drive Activity LED = LED light that flashes (Usually red in color) when your harddrive is active. Being used.
3) Reset switch = Reset Button. The Reset switch is behind the Reset button. (IF the computer uses a Reset switch)
4) Power Switch = Power On switch
5) Forget about Pin 9. That's for 5 Volts DC - Out. Used by factory.
Which wires coming out of the Front Panel, are the Power On wires, Harddrive LED light wires, Power On switch wires, etc.?
Remove the Front Panel, and trace where the wires end.
IF, the wires already installed coming from the motherboard to the Front Panel, are Too short, you should make notes before you remove them from the motherboard.
Note what color pair of twisted wires, went to where, in the Front Panel.
Compare to the chart of the Front Panel header given above.
(IF any wires are still connected to the Front Panel header on the motherboard)
Once the Front Panel is removed, it's usually pretty easy to trace the two wires up to the Power On switch.
Same for the Power On LED light.
Again, same for the HarDDrive activity LED light.
The SATA harddrive requires a DATA cable, and a SATA power cable.
The connector for a Data cable has 7 contact pins. It is the shorter connector.
The connector can be at a 90 degree angle as shown, or a straight connector.
IF the data cable has an angled connector, it plugs into the Harddrive.
Straight connector goes to the motherboard.
The connector for a SATA power cable has 15 contact pins. It is the longer connector,
Note the L shape of the connectors for the SATA data cable, and SATA power cable.
Also;
This is a 4-pin standard Peripheral power cable. Commonly misnomered as a 'Molex' power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
IF, the SATA harddrive has a provision for a SATA power cable, AND a 4-pin standard Peripheral power cable, ONLY use just the SATA power cable.
Using both power cables will burn up the harddrive.
May not happen immediately in some cases, but WILL eventually happen.
Regards,
joecoolvette
Nov 17, 2011 | Gateway 505GR PC Desktop
Advent t9307 power switch not working
Your laptop's power button sits directly on top of a device called a power button board. This is a small circuit board where all power and control buttons interface with your laptop's motherboard. The repetitive use of the power and control buttons can damage the power button board. Repairing your power button means removing and replacing the power button board, which requires partial disassembly of your laptop.
1.Power down your laptop. Unplug the AC power adapter and all external devices from the computer. Close the laptop's LCD panel and place the laptop face down. Rotate the laptop so the front opening edge is facing you. Remove the battery pack from its compartment on the laptop's bottom side.
2.Flip the laptop over, and pull open the display panel as far as possible. Use a thin, flat-head screwdriver to pry the keyboard cover from the laptop. The keyboard cover is the plastic piece situated above the keyboard assembly that houses the power button board.
3.Lift the keyboard cover out of the laptop slightly, and disconnect the cables extending from the power button board to the motherboard. Remove the keyboard cover from the laptop.
4.Place the keyboard cover face down on a flat surface. Remove the Phillips-head screws fastening the power button board to the cover, and remove it. If your speakers are situated inside the keyboard cover, disconnect the speaker cables from the power button board before removing it.
5.Place the new power button board inside the keyboard cover. Align the screw holes on the button board with the holes on the keyboard cover. Replace the Phillips-head screws fastening the button board to the keyboard cover. Reconnect the speaker cables to the button board, if necessary.
6.Reconnect the power button board's main cable to the motherboard. Place the keyboard cover back inside the slot above the keyboard assembly. Press down on the cover until it snaps into place. Replace the battery pack and reconnect all cables.
Sep 06, 2011 | Computers & Internet
Hi ,, i have just fitted a intel d845gvsrb in my pc but i am not sure where the tower speaker wire , reset sw , power sw , power led , h h d led and the black single one go`s can you please help me ..
The Picture below shows you the locations of the places to put those wires are in relation to your motherboard. In yellow is the power switch and such. and the audio connection is in red.
The Pin layout for the power and other connector are as follows:
the layout for the audio header is as follows: avatar23454_8.jpg
To install the cable that connects a front panel audio solution to the front panel audio header, follow these steps:
  1. Turn off all peripheral devices connected to the computer. Turn off the computer and disconnect the AC power cord.
  2. Locate the front panel audio header (J8A1).
  3. Remove the three jumpers from the header (this disables the back panel audio connectors).
  4. Install a correctly keyed and shielded front panel audio cable.
  5. Connect the audio cable to the front panel audio solution.
To restore back panel operations follow these steps:
1. Remove the front panel audio cable. 2. Install a jumper on pins 5-6 (rear R channel). 3. Install a jumper on pins 9-10 (rear L channel). 4. Install a jumper on pins 1-2 (mic). 5. Replace the cover.
Apr 17, 2011 | Intel D845GVSR Motherboard
Gigabyte Slot 1 GA-BX2000 Motherboard Logo
268 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
