Question about Nintendo Wii Console
Don't eject discs.
I recently buy a game for my wii console, but I push the eject button and the blue light works, but it doesn't eject the disc. I can play with the game that is inside, but I can't put any more disc. Thanks for helping.
  • amswiergul Jan 19, 2009
    We can't eject the disc from the console.Thanks for any suggestions.Ania
    Problem Solver:
  • 19 Answers
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide.. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Feb 21, 2009
Try holding it down
Posted on Jun 05, 2008
ctf1800
  • 4402 Answers
SOURCE: Wii console feed and eject problem
cdrom drive bad
Posted on Jan 09, 2008
SOURCE: cd drive won't pull disc into console
Do you have a warranty? If you do, go to the place where you got it and have them check the inside. You may have a broken gear. That could be why it does not take in the disc or eject it. =D
Posted on Mar 25, 2009
treborswindl
  • 212 Answers
SOURCE: my wii is not accepting any disc. I push the disc
I have just finished fixing a wii system that did the exact same thing. It had 2 pennies jammed into it. After i removed them it was perfect. I am a game sytem technician and a special type of screwdriver is required to open the unit. It can be purchased on ebay.Good Luck
Posted on Nov 23, 2009
SOURCE: every time i put a disc in the wii console the
every time i put a disc in the wii console the disc ejects then pulls back in and then pushes out of the console
Posted on Jan 20, 2010
MeKnowAll
  • 66 Answers
SOURCE: wii won't accept disc. console spits disc out
Try cleaning the disk and make sure your disk drive dosn't have any gunk in it then if that dosn't work try putting the disk in the other way.
Posted on May 09, 2010
We got a game stuck in the wii consele....We tried ejecting the game as well as turning the game off...nothing is working.
You have to try out all these options first:
Turn the Wii off and on again after about 20 seconds. Press the eject button again.
Unplug the Wii's AC power supply if Step 1 doesn't work. Wait 1 to 2 minutes, and trying to eject the disc again after turning the Wii back on.
Hold down the eject button for 5 to 10 seconds.
Try ejecting the disc with the Wii at different angles. If you hold the Wii upside down, it may help the disc fall out.
Call Nintendo and send the Wii back if non of these steps work. In most cases, a disc stuck in the Wii should be covered by warranty.
Nintendo says to see if power light was coming on, AC adapter reset. unplug from both ends for 90 seconds.Hold eject button for five or 10 seconds.
If none of this works, you might wanna try this, but it is not a preferred method, if you ask me, even though it can be done.
To remove a disc you'll need three sets of tweezers. And possibly a bobby-pin.
First you need to turn the Wii upside down (and preferably unplugged from a power source)
Second, using two sets of tweezers, press the small metal "guards" down. These are located just inside the mouth of the Wii. They're there to keep the disc from free falling, and inhibit their removal. They aren't locked and shouldn't be difficult to press down.
Third, you'll need to reach "up" through the middle of the mouth with the third set of tweezers to grab hold of the disc. I'd highly recommend using flat tweezers, not sharp ones as the disc may become scratched.
NOTE: The disc itself rests on the internal carriage (through the center hole of the disc) and if upside down, should fall into your tweezer's grasp easily. If it doesn't then you need a bobby pin to dislodge. Gently press the bobby pin on top of the disc and then grip the disc with the tweezers.
Finally, gently pull and the disc and push on the bobby pin and the disc will slide out easily .
This can be done with one person, but helps if you have an extra hand.
Good luck.
Sep 23, 2011 | Nintendo Wii Console
Disc will not eject
Aug 22, 2010 | Nintendo Wii Console
Eject button isn't working
maybe theres no disc or your wii button needs more pressure
Feb 18, 2010 | Nintendo Wii Console
Wii Console will not turn off. After pressing the Power off button the console light goes from green to yellow (not red.) After about 5-10 minutes the blue light will start to cycle on and off and the game...
try turning it off on the console and not with the controller. turning it off with controller turns it yellow. press and hold the power button on console for 5 seconds it should turn red.
Jun 30, 2009 | Nintendo Wii Console
Disc won't eject.
When you hit eject do you hear it attempting to push out the disc? It may be blocked by something. If it is not attempting to push out the disc then something isn't registering with the eject button. In this case, power down the wii, unplug all plugs from the back, wait 90 seconds or so, plug in just the power plug and hit the eject button (before hitting power or anything else). If it still does not try to eject then either the button is broken or the disc drive in the wii has died.
It is still probably under warranty from Nintendo, they can fix it for free for you. If anything, give them a call at:
1-800-255-3700
Jun 25, 2009 | Nintendo Wii Console
Game stuck in console
Try thees steps
Turn the Wii.html#" target=_blank itxtdid="7750962">Wii off and on again after about 20 seconds. Press the eject button again. 2
Unplug the Wii's AC power supply if Step 1 doesn't work. Wait 1 to 2 minutes, and trying to eject the disc again after turning the Wii back on. Hold down the eject button for 5 to 10 seconds. 4Try ejecting the disc with the Wii at different angles. If you hold the Wii upside down, it may help the disc fall out. 5Call Wii.html#" target=_blank itxtdid="7751052">Nintendo and send the Wii back if non of these steps work. In most cases, a disc stuck in the Wii should be covered by warranty. Nintendo says to see if power light was coming on, AC adapter reset. unplug from both ends for 90 seconds.Hold eject button for five or 10 seconds Good Luck
Jan 23, 2009 | Nintendo Wii Console
Won't eject disc, just clicks like it's tring to.
Hmmmm, try reseting the wii or synching it. The sync button is under a removeable piece of plastic on the console??? it will show you in the manual.
Srry, im no an expert if that doesnt work.
Jan 21, 2009 | Nintendo Wii Console
My eject button
Literally give Nintendo a call 1-800-255-3700. They might offer you a replacement console.
May 05, 2008 | Nintendo Wii Console
Wii disk not ejecting
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Jan 23, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
222 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
