Question about Zyxel Prestige 660HW Wireless Router (PRESTIGE660HW)
Internet Connection I have just changed from a wired connection to a wireless one using the same gateway ZyXEL P660 and a G202 USB adapter. My connection keeps dropping off but my partners laptop stays connected. I have tested the USB adapter on her laptop and it works fine. Help!
  • 611 Answers
Give the dns value properly in the zyxel p660 and re-installed the driver of the usb adpater
Posted on Jun 10, 2008
Zyxel P 660HN T1A as a wifi router to be connected to a modem
Website says its 802.11n Wireless ADSL2+ 4-port Gateway, so yes.
May 27, 2013 | Computers & Internet
I have g202 wireless adapter and im using it With windows vista, my problem is that my ping is changing from 50 to 500 all the time, is there some solution how to get it stay steady? and both router and...
Depends what machine you are pinging! It could be normal depending on your reception to your router or a site on the other side of the world. Connected directly to a router by wire should be less than 10ms.
Sep 12, 2011 | Zyxel Zyair G-202 USB 2.0 Adapter
Im having a zyxel wireless usb adapter and im playing alot of games. and i have to change my nat or whats it called to open network. how do i do?
If the ZyXEL device you have is a USB adapter then that is not the device you need to look at to change NAT settings. Either the wireless router or possibly your modem will need to be set up to allow the ports your games need in order to connect. Which ever device you have with the internet connection coming to it is where you will need to look at changing settings.
Feb 17, 2011 | Zyxel (91-004-361002) Wireless Router
I have a zyxel router, after connecting to the laptop via wireless, sometime it cant load the webpage such as www.google.com. but the wireless signal there showing "Connected" with full tab. After once...
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 01, 2009 | Zyxel ZyAIR B-100 802.11b (AM5009004)...
Wireless connection fine but internet connection impossible
if you only have usb connection in your modem, internet on the zyxel router will not work since it's using ethernet connection. in order for your zyxel device to work with tiscali, you will need a cable/dsl router that has ethernet connection as well. you can contact tiscali if they can provide you with that kind of modem.
hope this'll help you
ciao
Nov 10, 2008 | Zyxel Prestige 334 Router
Zyxl P660 HW can not connect 1 pc wireless and 1 cabled at the same time. only 1 at a time
hi Bradius,
I suggest you update your P660 gateway's firmware to the latest version, seeing as how the latest firmware has the latest driver for the P660 wireless module. The new firmware can be downloaded at
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906164737&ModelIndexflags=0,420041221102511,420041221102520,420050117110858,420050117110916,420050117110934,420050831093216,420050831095441,420060420160946,420060816160116
After updating the firmware of your gateway, I suggest you update your PC's wireless network adapter's driver to the latest version (if you can supply me with the make and model I'll be happy to direct you to the site where you can download the driver).
If you still have problems connecting the PCs after you have updated as per above guidelines, I suggest looking into how to map the gateway's LAN port 1 and wireless LAN port to PVC (Private Virtual Connection) 1at
http://www.zyxel.com/web/support_knowledgebase_detail.php?KnowledgeBaseID=4805&pid=20040812093058
I hope you find this information helpful in solving the problem.
Please take the time to rate this solution.
Kind regards and thanks for using the FixYa service.
Mar 19, 2008 | Computers & Internet
No Internet Connection
what type of internet connection are you using? DSL or CABLE? BPCS
Jan 13, 2008 | Zyxel P660HW-D1 Router
Zyxel p660hw and g202 problem
I had an almost identical problem and contacted Tech support at Zyxel. They were excellent and the guy talked me through to a solution. The main issue related to 'Bandwith management' which defaults to active on the router configuration. Unset all three (Wan, Lan, Wlan) and see if it sorts out problem. Because of some other issues I did have to reset the router to start with and on the wireless client I unset 'Obtain IP address automatically' and used an IP address with the default gateway set to the router address. If this does not help, I would recommend talking to Zyxel Tech Support, the consultant I spoke to was brilliant.
Nov 22, 2007 | Zyxel P660HW-D1 Router
Zyxel Prestige 660HW Wireless Router (PRESTIGE660HW) Logo
309 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
