Question about Eisenworld Alohabob PC Relocator Ultra Control 6.0 (pcrelocatu6) for PC
Pc relocator program
Every time i try to load the programon the new PC I receive the following error
1607 unable to install installshield scripting runtime
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
CAUSE loadTOCNode(1, 'cause');This issue may occur if one of the following conditions is true: • The user account that you use to install the game does not have administrative rights. • You have programs running in the background that are interfering with the setup. • .NET Framework is not installed on the computer. • The Windows Installer program that helps you set up the game is not installed correctly.
RESOLUTION loadTOCNode(1, 'resolution'); Locate and then close the files loadTOCNode(2, 'resolution');To resolve this issue, locate, and then close Idriver.exe and Msiexec.exe.
To do this in Microsoft Windows XP, follow these steps: 1. Open the Task Manager. To do this, click Start, click Run, type taskmgr, and then click OK. 2. In the Processes tab, in the Image Name column, find idriver.exe and msiexec.exe. 3. Select each instance of both processes, and then click End Process. 4. Click Yes on each Task Manager Warning popup window that you receive. 5. Close the Task Manager.To do this in Windows Vista, follow these steps:
Windows Vista loadTOCNode(3, 'resolution'); 1. Click Start and click Control Panel. 2. Click User Accounts and Family Safety. 3. Under User Accounts, click Add or remove user accounts. 4. Click Create a new account. 5. Type in the account name. 6. Select the account type: Standard or Administrator. 7. Click Create Account. Select the account you just created. 8. Click Create a password. 9. Type in a password for the user account and an option password hint. 10. Click Create password. 11. Log off your current account, log back in using your new account. 12. Start the installation. Perform a clean boot procedure
Posted on Jun 06, 2008
How to fix windows 1607 unable to install instalshield scripting runtime
You might have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Jul 14, 2012 | Microsoft Windows XP Home Edition English...
Good Morning: I am trying to run my copy of PC
update your framework, check on your software publisher what framework support.
Mar 22, 2011 | Eisenworld Alohabob PC Relocator Ultra...
Error 1607 unable to install InstallShield
how you fix it
Reinstall the InstallScript engine loadTOCNode(2, 'resolution'); To reinstall the InstallScript engine from InstallShield Developer, follow these steps:
  1. Download the ISScript7.zip file. To do this, visit the following InstallShield Web site: http://consumer.installshield.com/kb.asp?id=Q108322 (http://consumer.installshield.com/kb.asp?id=Q108322)
  2. Extract the ISScript7.zip file.
  3. Double-click the ISScript.msi file.
Running Setup from a virtual drive loadTOCNode(2, 'resolution'); If you are running the Setup program from a virtual drive created by using the SUBST command, you can delete the virtual drive and instead run the Setup program from the physical hard disk. To delete the virtual drive, click Start, click Run, type subst drive_letter: /d, and then click OK.
good luck
Mel
Jun 05, 2010 | Microsoft Windows Vista Home Basic for PC
I get the following problem during installation 1607: Unable to install installshield scripting Runtime. please help me
Unable to continue or unable to install with this program are searching for support on it. Runtime errors are common in system registry which a certain is missing or broken.
There are some causes on it.
  1. Confliction with TSR or other running program.
  2. Software Issue
  3. Computer Virus
  4. and Memory Use.
To fix it here is a link to help you:
www.yboyandrei.com/runfix
This one can repair all broken DLLs in your system.
Please rate if i am helpful to you.
Thank you.
Sep 01, 2009 | Peachtree Software Accounting 2005 for PC
When trying to re-install from disc get error: 1607
The failure appears to be occurring because the installation script cannot obtain Scripting.FileSystemObject. This is most likely due to registrations belonging to your Windows ScrRun.dll being missing from your machine - and the problem may be specific to your machine configuration.
Click on the orb/start menu and type in the search box regsvr32.exe scrrun.dll
If the fix is successful
try running the install again.
Regards.
Aug 06, 2009 | Canon Cameras
Cannot install my download due to error message 1607
That software doesn't work in vista... what OS is urs??
Nov 21, 2008 | InstallShield Computers & Internet
Trying to install Quarkxpress 7.0 error message says Unable to install Installshield scripting Error 1607
CAUSE loadTOCNode(1, 'cause'); This issue may occur if one of the following conditions is true: • The user account that you use to install the program does not have administrative rights. • You have programs running in the background that are interfering with the setup. • .NET Framework is not installed on the computer. • The Windows Installer program that helps you set up the game is not installed correctly. Heres what I would do, Firstly download and Install the lates .NET distributable from here
http://www.microsoft.com/downloads/details.aspx?familyid=0856eacb-4362-4b0d-8edd-aab15c5e04f5&displaylang=en
Then download and install the Latest windows installer package from here
http://www.microsoft.com/downloads/details.aspx?FamilyID=889482FC-5F56-4A38-B838-DE776FD4138C&displaylang=en
If after you install both of these and REBOOT you still get the error then let me know and we can go more indepth
Aug 24, 2008 | Computers & Internet
Eisenworld Alohabob PC Relocator Ultra Control 6.0 (pcrelocatu6) for PC Logo
175 people viewed this question
Top Eisenworld Computers & Internet Experts
Tony
Are you an Eisenworld Computer and Internet Expert? Answer questions, earn points and help others
