Question about HP Computers & Internet
Charging my laptop
I have my brand new lap top plugged into the charger. Everything is connected correctly and it says that it is plugged in but not charging! What is wrong??? Why won't it charge??
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    Hi - brittathan - Was the battery installed when you got it or did you have to put it in? Either way, sometimes batteries are shipped with little protective plastic pieces on the contacts. Make sure these have been removed. If you didn't put the battery in yourself, turn your laptop off and remove the battery. There will be a slide lock and then a slide to remove the battery. Be sure not to let the battery fall when removing. Check the ends for the tabs and also the inside of the battery compartment. If you find any remove and replace the battery making sure it's all the way in and then be sure to re-lock it. Power up and check it. Either way, let me know what happens please. Thanks.
    Jeff
  • 45 Answers
If its not already fully charged, then you may be having an electronics issue. take it in and have it serviced.
Posted on Jun 04, 2008
My toshiba click mini wont charge
If you are using the correct charger and it isn't charging, look at the port for any visual damage and make sure the charger is fully plugged into the laptop (may sound basic but best to cover everything)
You may also want to try plugging it in to different plugs.
If it still isn't charging you may want to considering removing the battery from the laptop and then plugging it back in and trying again, you may also have to purchase another battery if yours is faulty, if you bought it recently brand new then you may be able to get this via the warranty from where you purchased it from.
If you bought it second hand then contact the seller or merchant and request a replacement.
Nov 20, 2016 | Toshiba Computers & Internet
Hello i have Toshiba lap top when turned on its on for 2 seconds then switches self off ,it will not switch back on even by taking battery out connecting power then.
The battery is not charging, the laptop may be in hibernation.
It should still work nevertheless. Try pressing F8 to go in to safe mode
Oct 13, 2014 | Computers & Internet
Ac wont charge laptop icon says plugged in but not charging? Got new Ac adapter
Battery dead? Is the cord/charger same power spec DC volts and milliamps?
Dec 24, 2012 | Computers & Internet
No power to my gateway m-6750 lap top. Have been
First use the following steps:
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Connect the charger (don't connect the battery yet) and try to start by pressing the power button.
If everything remain same, check the charger with a multimeter and match the voltage output with its specs.
If the charger is good, then there can be some problem with the DC jack (where you connect the charger).
Thanks
Feb 25, 2010 | Gateway M-6750 Notebook
Lap top not charging . purple light is not on. is it battery or charger?
the charger lasts longer than the battery .you need another lap top battery
Oct 16, 2009 | Computers & Internet
Wont charge
Try a car charger. If the car charger works, then it is either
A) Your power outlet
B) Your wall charger Power Supply unit
C) The phone connector on your wall charger.
If it doesn't work on the car charger, then it is most likely your phone charging system or the connection for charging on your phone. Either way, you will most likely need a new phone. Sorry.
Sep 23, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Problem with charging adapter on my laptop acer aspire 5335
the charger gets real hot??????? O really? wonder why?....Charger defect... guaranteed
Jun 27, 2009 | Acer Aspire 5335-2257 Notebook
Dell c640 charging problems.
Instead of spending alot of time trying to do something that could potentially harm your laptop..why not just buy a power supply?
You can get one here Click here for about 16 dollars. That's a great deal they are usually about $60 and its a Dell brand not some off brand.
Good Luck
Jan 18, 2009 | Dell Latitude C640 Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
