Question about Samson G-TRACK USB RECORDING MICROPHONE Microphone
Samson G Track
Also...the specs says the G-Track does not need Phantom Power,,,
    Problem Solver:
  • 27 Answers
No, it does not need phantom power.
Posted on Mar 01, 2009
How to work EMU 0204 with CAD GXL2200
Turn on phantom power for mic? Try a different cable.
Aug 01, 2012 | CAD Microphones GXL2200 Professional...
What is the likely cause of the phantom power of a samson 900 mixer to go bad?
The phantom power is used for condenser mics. MAKE SURE you do not plug in other mics or devices that do NOT have balanced, isolated outputs as they will short out the phantom power to others.
You should find between 15 and 48 volts between BOTH pins 2 and 3 of each mic connector when measured to pin 1 of the connector. There is about 6K ohms impedance from the phantom supply to pins 2 and 3.
IF you have an accident and connected high voltage to pin 2 or 3 it COULD back up and blow the bypass cap for the 48 volts.
Please note: ALWAYS power ANY interconnected equipment from teh SAME receptacle to avoid damage due to ground bounce in the event of a fault in a piece of equipment.
Oct 22, 2010 | Samson Xm910 8Channel Powered Mixer...
I bought a samson se50 headset microphone to go with my GTD Audio wireless system. It has the correct adapter plug to plug in to the transmitter. The plug is a mini XLR plug. The microphone does not...
You need power from the transmitter to power this mic. See your mics specs to determine if it needs "Phantom Power"
Perhaps the transmitter doesn't supply power. Condenser mics may not work. Stay with the dynamic type. IMHO
Jul 29, 2010 | Nady Systems Nady ATM-75 Headset Mic w/...
I got a 35 mm cable on my c01 and it won't work on my pc does someone know the problem..cuz when i put another mic in it just works fine
You Samson microphone requires phantom power to operate. PC's don't have phantom power. You need to run your mic thru a mixer that has phantom power.
Apr 14, 2010 | Samson C01U Consumer Microphone
How to make my co3 mic work
You will need a pre amp that supplies whats called phantom power which is power that feeds the mic .. This will come from either mixers [small cheap ones..but check it has XLR mic input with phantom power] or from a stand alone pre amp or audio interfaces with built in inputs for mics with phantom power.. Also you will need an XLR mic lead..Buy a good one with neutrik plugs or similar..
Mar 19, 2010 | Samson CO3 Microphone
I cant make my condenser mic to work with mixcraft only dynamic w
Condenser microphones need phantom power (48V) to operate. Some condenser mics use batteries to work and get around using phantom power from an audio mixer. hope this helps
Feb 28, 2010 | Samson C01U USB Condenser Microphone...
My microphone CL7 Studio Condenser Samson does not work.
your microfone needs a phantom power to work,so your fast track dont have the necessary energy to make you microfone work, so you need to conect you microfone on a pre amp then your fast track, this is gonna make your microfone work like it shold.
Dec 22, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Samson CO2 Pencil microphones
The CO2 is a condenser mic (also called capacitor mic), and as such, requires phantom power to operate. Ensure that your system is providing phantom power to the microphone, usually accomplished by flipping a switch near your mic input on your sound board.
Dec 19, 2007 | Samson CO2 Professional Microphone
Connecting samson co2
The Samson CO2 is a condenser (also called capacitor) mic, and thus requires phantom power to operate. In order to apply phantom power, you must have a board capable of handling an XLR connection, and supply phantom power. Usually there is a switch located near the XLR-input jack on your board - if you post your sound board type, more help can be given.
Dec 16, 2007 | Samson CO2 Professional Microphone
Samson G-TRACK USB RECORDING MICROPHONE Microphone Logo
124 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
