Question about Konica Minolta Magicolor 2530 DL Laser Printer
Fatal Error code 16H - Konica Minolta Magicolor 2530 DL Laser Printer
If transfer belt unit appears in good shape, then problem is most likely the opto coupler is full of toner dust. Use duster to clean out opto coupler that senses notch holes in belt.
Posted on Nov 16, 2009
  • DagoberTT Mar 17, 2011
    well, its the belt transfer unit. (plastic belt thingy in the top of the machine if you open it)
    lets sove it: release the 2 screws left and right to the unit
    hook it out to the top (it gives you the edge if you have one more person aviable in this part) -
    carful - you have to release the the plug too - someone sholud hoover the unit near the plug while you release it - finally you should have this thingy in your hands
    vacuum the thing clean - you can also use a soft cloth to clean the plastic belt - its not such sensitive you think of...
    clean the plastic sensor (i think) in the back of the unit with soft cloth too . vacuum the to the electronic device (maybe a sensor too) to the back to the left carefully.
    rebuilt the machine
    it should work
    you dont have to replace the belt unit (its the dust on the sensors (again - for much other errors too) i think)
    best regards
    Dagobert
  • 300 Answers
It relates to the transfer belt unit, replace it
Posted on Jun 13, 2008
3 Suggested Answers
  • 300 Answers
SOURCE: konica magicolor 2430DL Fatal Error Code 16H
  • 300 Answers
SOURCE: Fatla error code 16H
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
How to remove error code service call 16H
Did you remove all the shipping parts. or go a bad belt replace with new one
May 13, 2014 | Konica Minolta KONICA BR BIZHUB C10X 1-SD...
Fatal error 0000000000
Is the operating system Microsoft? When does the fatal error occur, when the laptop starts up? Are there any other letters at the end of the error code, please reply with the full code.
This link has examples of possible error codes:
http://support.microsoft.com/kb/150314
Jan 11, 2013 | Acer TravelMate 4100 Notebook
Fatal error code 2124 on Rosetta stone
There is file called tracking.db3 which gives us lot of error like 2124, 5611, 2123 etc.... you can find a perfect fix at Questions Rosetta Stone Community
Jan 03, 2012 | Rosetta Stone 1, 2, 3, 4 & 5 Set English...
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
Fatal error code: 16H
The Belt Positioning Sensor does not detect the Transfer
Belt position detection hole a second time even after
the lapse of a predetermined period of time after it has
detected one while the Transfer Belt is rotated.
Oct 04, 2010 | Konica Minolta magicolor 2430 DL Laser...
Hi, pretty sure its the transfer belt not able to turn, remove it and make sure there is nothing blocking it, maybe a paper jam
Aug 05, 2008 | Konica Minolta Magicolor 2530 DL Laser...
May 31, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Fatal Error 162
I am pretty sure this is the result for your 162 code:
Toner Sensor Error, Color:Cyan
When cyan toner sensor error has occurred
Try reseating your toner carts.
May 14, 2008 | OKI C5150n Led Printer
Konica Minolta Magicolor 2530 DL Laser Printer Logo
484 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
