Question about Samsung RS2630SH Side by Side Refrigerator
Samsung rs2630sh The fridge side is not cooling the food I have tried to lower the temperature but it just keeps going back to 16. I have turned it off but nothing has improved
  • Avisdavies Jun 13, 2008
    The problem I have is the firdge will not chill and the water is warm with my Samsung Fridge Freezer RS21JLAT I have called an engineer who has told me that the back panel in the firdge is iced up, This is a known problem to Samsung and this was an item on Watch Dog it is a known fault, so I will have to contact Samsung Customer Service and ask them to repleae the wholde Unit free of charge I hope. Will let you know
My RS2630SH frige side does not cool, but freezer side is ok with more-than-normal frost. Call Samsung, they say to unplug for an hour to reset unit. Have not try it yet, but worth a try, since it is over the warrenty period.
Posted on Jun 11, 2008
Srs618dp model samsung noisy and lose temperature
I have a Samsung srs618dp side by side fridge. I have just turned it on after 5 months and it seems to be working however every 30 seconds it keeps beeping, very annoying. There is no ice build up.
Apr 06, 2013 | Samsung RS2630SH Side by Side Refrigerator
Model gx5shdxvbd03 keeps freezing up
I have a similar Samsung side by side refrigerator and last year had the same problem. i.e. the fridge side ices up.
In our case this eventually led to the circulation fan to stop working and the temperature to rise, all food spoiled. This was caused by the defrosting heating element failing due to a faulty sensor within that component.
Samsung are very aware of this issue and direct contact with their customer services resulted in an engineer's visit and a free of charge repair. We also were given a voucher for the loss of food caused by the failure of the fridge.
Mar 27, 2013 | Samsung RS2630SH Side by Side Refrigerator
How long does it take to let it cool down
If you don't open and close the doors and depending on the amount of food you have in the fridge and feezer, it would take several hours for this fridge to get to optimum temperature.
However, if after 12 hours it still hasn't cooled down, there is a problem.
Ash
Sep 17, 2011 | Samsung RS2630SH Side by Side Refrigerator
Unable to maintain fridge temperature
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 20, 2011 | Samsung RS2630SH Side by Side Refrigerator
Samsung RSA1DTWP
Check the fan units for freezing up. Its just a matter of clearing and removing the units. Ice may make it a bit of a tight problem. Defrost with a hairdryer and make sure the drains are clear. It worked for me. Paul.
Jul 11, 2010 | Samsung RS2630SH Side by Side Refrigerator
Fridge side wont cool properly.
Check out this link below for a PDF manual on your item. Great information to have. Just copy and paste into your browser.
http://www.samsung.com/us/function/search/espsearchResult.do?keywords=RS2630SH&input_keyword=RS2630SH
Try this:
Temperature Adjustment
• After 24 hours, adjust the controls as needed. Adjust temperature gradually: push the button in small increments,
allowing the temperature to stabilize.
• Press the button(Freezer Temp or Fridge Temp) repeatedly until the desired set temper.
• For lower temperature, press the button(Freezer Temp or Fridge Temp) towards coldest.
• For higher temperature, press the button(Freezer Temp or Fridge Temp) towards cold.
If this does not work for you let me know or you can contact Samsung support at 1-800-SAMSUNG (1-800-726-7864) Mon - Sun : 9am - 9pm (EST).
Or you can try this Live chat at this link below, just look to the middle left of their page for live chat:
http://www.samsung.com/us/info/contactus.html
Let me know how this works for you or if I can help you with anything else.
JimmyC
Oct 06, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge not working properly
Your compressor has most likely gone out or you have had a freon leak. I would say the compressor is the culprit. You need to have a appliance company come out to make sure, hopefully it's under warrenty, if not, it's usually better to buy a new fridge than to fix it. It's usually more expensive to fix old fridges than to just replace them completely.
Aug 25, 2008 | Samsung RS2630SH Side by Side Refrigerator
Fridge tempertature
I have the same symptom too - freezer temperature flashes at -2. "Power Freezer" or setting it to any other temperature is not working either.
As a result, no ice being made. Please help!
Aug 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Fridge and Freezer do not keep foods cool
Samsung rs2630ww i have had endless problems i have had it replaced 4 times. red hot center and side panels i have had 2 condensers burn. the problem is that it is simply badly designed!
there is not enough air flow . so if it has any restriction it kills the unit. a Samsung tech told me off the record these units are all problematic! of course he love it at 200 an hour.
Aug 01, 2007 | Samsung RS2630WW Side by Side Refrigerator
Fridge temp too high
probable cause is jammed fan. first take back panel off fridge, electrical connections are plug and socket. yoy may find a quite small build up of ice underneath the fan. melt it off and you should be ok. samsung are prone to this problem
May 08, 2007 | Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
565 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
