Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag dyer MDE9206AYW
I went to turn my dryer on and it made this load pop nosie and now will not turn on. but when u hold the start button in it makes a sound like it is on but not turning and when u let go it shuts off
  • 3 Answers
Moter bad
start switch wont ingage
Posted on Jun 17, 2008
Changing belt on Maytag electric dryer model #MDE9206AYW
Go to www.repairclinic.com and enter MDE9206AYW. You will be presented with a list of common parts and may be able to view a video showing disassembly.
Jul 29, 2016 | Maytag Dryers
Maytag MDE9206AYW won't start
When "they" say the timer can't be tested, what they mean is testing is not practical. If your machine uses an electromechanical timer, you can access the inner workings and observe operation and test control voltages for far longer than the time required to oder and install a replacement.
Jan 11, 2014 | Dryers
How to remove top and front panel on Maytag Dryer model MDE9206AYW
To access these parts you first need to first lift the top up. This is done by pressing the clips inward. These are located on the left and right side in between the top and front on the dryer. When this is done the top will left up and backwards. Next, on the upper inside there are two screws, usually 5/16" bolts, that will need to removed to take the front off. Now you'll will access to the inside of the dryer. The belt will have to be removed to to take the drum out to test the rollers.
Jun 06, 2012 | Maytag Dryers
Maytag MDE9206AYW will not heat. What do I need
I assume it is a gas dryer. Turn it on and if no clicking sound is heard within 30 seconds the spark ignitor needs a replacement. If it is an electric dryer you need to check the relay for the burner system first
Apr 16, 2010 | Maytag MDE9206 Dryer
Maytag dryer makes an electrical buzzing noise when start button
It sounds to me like the motor is not turning, but the heating element is coming on. with no air flowing over the element, it is getting too hot. Can you operate the start switch with the top tilted up so you can see if the motor is turning but the drum is not, and just where the buzzing is coming from. Also, I would try the dryer on manual setting and on air dry to see if any setting works. Good luck
Jan 07, 2010 | Maytag MDE6000 Dryer
I hit the start button on my maytag MDE9206AYW and it don't start
Sounds like the motor is going bad. If you keep going like that eventually you will hear a loud noise, and it won't even start.
Aug 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
How to change belt on maytag model MDE9206AYW dryer
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
May 02, 2009 | Maytag MDE9206 Dryer
Maytag mde9206ayw
HI WHEN YOU PUSHED THE BUTTON TO START DID IT HUMM IF IT DID YOUR MOTOR IS THE PROBLEM ESPECIALLY THE BURNING SMELL
May 24, 2008 | Maytag PYE2300AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
201 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
