What happens if you have the key in the run position, you foot on the brake and you wiggle, pull, push the turn signal lever. Also try turning the hazards on and off slowly. All while keeping an eye on the brake lights to see if they come on momentarily.
I'm pretty sure the brake and turn signal share the same bulb If so we know that the bulb and the wiring from the switch to the bulb is fine. If there is power into and out of the brake switch than it is reasonable to assume that the problem is in between the brake switch and the turn signal switch if not the switch itself.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
do you have trailer lights? check to make sure. they snap into tail light assembly and could be messing thing up
