Question about Dell W3000 30 in. HD-Ready LCD Television
Set on no picture
We push the on button...the light is green...but set does not go on. We used to press the button several times and it went on but it no longer goes on.
Local repair people don't want to deal with Dell TV sets apparently.
    President:
  • 2,712 Answers
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. Try a hard reset: Unplug the Tv from the AC mains, wait about 10 minutes and replug and power on the Tv and see.
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
4. A circuit board may crack about some of the larger components mounted on it. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
5. The problem could be with the power board. Unfortunately, the board is manufactured by a Chinese company, and they do not sell parts. They only replace entire sets if returned under warranty from Dell..
Posted on Jun 04, 2008
  • Swilin Sampson
    Swilin Sampson Jun 04, 2008
    Try this: Shine a bright light at the screen. If you can see the ghost of an image if you shine a bright light at the panel, then probably the backlight is gone. There may be generic replacements for those,
    they're only a little different from household fluorescent bulbs. Call
    around to TV repair stores that advertise 'all brands'. The lamp power
    supply is also highly subject to failure. A very sharp repair shop can
    fix those with generic parts too, depending on exactly what failed. But
    if it's a proprietary part like a transformer, that was designed
    specifically for that model, I don't think there is any choice apart from getting a new TV...
  • 3,037 Answers
Have you tried using the remote at all. If the remote works, then the button on the tv is at fault and needs replacing otherwise you could be having bigger problems. Please update me on this problem after reading my comment. thanks
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
    Genius:
  • 1,665 Answers
On switch may be fault. it must be checked and replaced if necesary.
    Master:
  • 555 Answers
How old is your unit? Is it still under warranty?
If you provide the Dell Service Tag #, I can look up it's warranty and support status.
When I push the on button the green light comes on for second or two then goes out.(will not stay turned on long enough to even get a picture on the screen.Mitsibishi Model # WS-55315
This set has a self check feature--if set has been unplugged it clears the error buffer--plug in and try to turn on set.
When green light comes on and then goes off ON THE FRONT OF THE SET press and hold BOTH the menu and input(device) buttons at same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat the code for a total of five times.
Let me know what error code you find and I will explain it.
May 27, 2012 | Mitsubishi Televison & Video
Green light comes on then imediately turns off picture has no time to come on
This model has a self check: When set and green light go off on the front of the set press and hold both the menu and input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will blink a two digit error code like 2, 2, and repeat it several times.
Let me know the error code and I will tell you what it means.
regards, SD TECH
Sep 17, 2011 | Mitsubishi WS-65809 65" Rear Projection...
My Projection Tv - when I turn on it turns right back off no picture no sound ? help
To know where the problem is:
when set shuts off and green power light goes off:
On front of set press and hold both the menu and input buttons at same time for at least 5 seconds and release both buttons.
Power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
May 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
The TV shut off by itself. Just before it went off, it said "timer off 0:00 press 09". Now when I push the power button the power light blinks and there is no picture.
sounds like somebody set the timer. normally this only makes the set enter standby mode and pressing the power button or a channel button usually wakes the set normally.
Just a longshot but have you tried pressing 09 while the light is blinking?
Mar 21, 2010 | Toshiba CZ32V51 32" TV
I have to get a printout... When I went to my IP2200, I found several pages jammed. I simply pulled them out and rebundled the paper and set them in the feed tray. I then pushed the resume button, which...
Hi. In such situations it is best to reset the printer.
This procedure resets canon iP1200 /iP1600 / iP2200 printers.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
Jul 29, 2009 | Canon Office Equipment & Supplies
Canon sd 750 how to put the date in the picture?
here is the solution:
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
To set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
dsc_include_date02_tcm14-520511.jpgyour date and time are set now
congratulations!
Rate this answer if it is working with you
thank you
with all my best regards
huetrichard@gmail.com
Feb 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Error number 1700 canon s9000 printer
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
Aug 20, 2008 | Office Equipment & Supplies
Setting date onCanon P23 DHV
I'm not positive because I pushed several buttons just trying to get it set and stay set -- but I think I did the following: fist push the "time set" button, ie the "memory plus" button then push the "format" button, ie the red "minus" button to change the settings -- continue until you have set the date and time -- then when you are finished you have to push the "time set" button, ie the "memory plus" button again to set it in place -- at least I think that's what I did
Jan 29, 2008 | Canon P23-DH Calculator
Red then green blinking lights.
push power on at button (no need to hold button)and press proceed button for 2 secounds at the same time you turn on power and it should reset.
Dec 24, 2007 | NEC PlasmaSync 50MP1 50 in. Television
Camera Frozen
I tried Option No.1 successfully when my Panasonic DMC-FZ7K froze once:
Option No1:
1. Try turning the camera on with the battery inserted.
2. Now remove the battery while the camera is on.
3. Flip the switch on the camera to off, then insert a fully charged battery. (Make sure that the battery's orientation is correct. Also make sure that the battery being used is not damaged).
4. Now flip the camera's switch to ON again.
Option No. 2:
If you can open the Setup menu then the camera can be reset which might help:
Turn on the camera.
1. Press MENU SET.
2. Press the left arrow button.
3. Press the down arrow button.
4. Press the right arrow button.
5. Now, press the up arrow button several times until the menu item named RESET is highlighted. Push the right arrow button and then select and set YES when the camera asks to be reset.
Oct 18, 2007 | Panasonic DMC-FX07 Digital Camera
Dell W3000 30 in. HD-Ready LCD Television Logo
74 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
