Question about Toshiba 26LV47 26 in. LCD TV/DVD Combo
Doesn't power on - Amber LED Blinking
This set will no longer turn on. When plugged in the amber light (disc) blinks 3 times, pauses, blinks 3 times again and so on. Powering on with remote or power button does not make a difference. Owners manual says call Toshiba for service and the service manual says its a "blink" code indicating the TV is rebooting.
My first guess is the power supply. I would simply replace it however it has been on factory backorder sinch March. So now I would like to try to troubleshoot the problem.Any ideas on where to start? Thanks!
  • janrick Jun 12, 2008
    have unplugged the set and replugged it
    still won't come on
    checked to see the controller was in tv setting
    still won't come on
    put in a CD now won't release it
    Help - I just want my tv working. We have had it less than 6 months.
    it is hooked to a cable box was watching; went to change channels and must have hit a wrong button -screen went black.
Here's how I fixed mine...
Look inside the back of the TV just above the power cord - there are two small LEDs, one green and one yellow (no need to open the case - you can see them through the cooling slots). In my case, the green LED would light for a few moments after plugging the TV in, then the yellow one would light and stay lit.
Go to the Toshiba site and download the latest firmware upgrade.
Copy the firmward upgrade to a SD memory card using your PC (SDHC cards larger than 2GB don't appear to be supported by the TV, so use a smaller one). I copied *both* the zip file as downloaded from Toshiba, and the contents of the zip file. That is, I expanded the zip file and copied the contents to the SD card as well.
There's a metal cover over the SD card slot on the back of the TV. Remove it (a single screw)...at one point, Toshiba has directions on the firmware download web site.
Unplug the TV and insert the SD card. Plug in the TV again, and in my case, those little LEDs stayed green. I saw none of the instructions on the TV screen - rather I just let it sit for about 10 minutes, then I unplugged the TV, removed the SD card, and plugged the TV in again. Viola - the TV works.
I'm thinking perhaps Toshiba uses a type of memory that requires battery backup, and if the TV is unplugged for an extended period of time, it's necessary to re-flash it.
Posted on Jun 21, 2009
  • Jason Rolph
    Jason Rolph May 31, 2012
    I had the same problem with mine and I did the same thing that You described (flashing the firmware) and it works fine now. hard to believe it was something so simple :-)
  • Jason Rolph
    I had the same problem with mine and I did the same thing that You described (flashing the firmware) and it works fine now. I couldn't believe it was something so simple :-) definately happy about it though.
  • 2,326 Answers
You could start by removing the assembly from the chassis and do a visual inspection first to check for leaky or bulge capacitors. If you have a capacitance meter even better. Check the capacitors that filter the 5VDC. If the capacitors test or look good, next step should be to measure the rectifiers and zener diodes for shorted, leaky or open conditions.
Let me know if you need further assistance.
Posted on Jun 04, 2008
Blinking Amber Light when power is attached to the unit.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Jul 21, 2015 | Vizio E550VL 55 in. LCD HDTV
Dell optiplex mini tower, when turn on the computer amber led lights blink with a , and will not startup
If the power light is blinking amber - The computer is receiving electrical power, but an internal power problem might exist.
Apr 25, 2014 | Dell OptiPlex GX520 PC Desktop
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Toshiba satelite a15-s129 only blinking amber light flashes which will not go off ever. it keeps blinking and computer will not turn on or off.
If the blinking light is the power on LED (normally green), then you'll have to disconnect it from power and pull the battery to get it to stop. If you connect it back to power and the amber light blinks right away, or if you connect it to power, press the power button, and the power LED starts blinking amber, then you have a bad motherboard. I see about one every two years....
If you think this is a keeper (which I do), eBay is probably the best place to buy a whole or partial unit for a song and a dance ($30-$50 target price). The Satellite A10 and A15 series are hardware identical: A10's are corporate offerings with XP Pro, and A15's are nearly all retail offerings with XP Home, that being the only difference.
Sep 18, 2011 | Computers & Internet
Blinking amber light.I changed 2 motherboards out and still blinking amber. Changed the CMOS battery, same thing blinking amber. Swapped memory and removed all pci cards, same thing. The motherboard has a...
I'm not clear about the blinking amber light you are referring to. Is it on the computer or the monitor.
I checked Dell's web site for the service manual for this computer model, & found this document:
http://support.dell.com/support/edocs/systems/dim8300/sm/adtshoot.htm#1102195
If the blinking amber light is on the monitor, check the connection between it & the computer itself. Make sure the cable is not damaged & that it does not have any broken pins in the socket.
Dec 16, 2009 | Dell Dimension 8300 PC Desktop
Toshiba laptop does not run, just amber light blinking
Did the computer ever work? Have you checked that your memory is properly seated? Remove the bottom plate that reveals the memory modules, pop both loose then back in. Try to restart. Is the battery fully seated?
Sep 18, 2009 | Toshiba Satellite A15-S129 Notebook
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Powers On if I plug it in, and power supply fan runs...
Think of blinking amber as the initial state of the LED. As long as the system is receiving power from a power source and can pass that power through the system board to the LED on the Control Panel it should, at least, blink amber. As a result, a blinking amber Power Button LED is a reliable indicator that the system is receiving power from a power source. This, in turn, tells us that the source and power cord are likely to be functional. The Blinking Amber LED also tells us that the power supply to system board connection is good as well as the connections between the system board, I/O Panel and Control Panel. Depending on the components installed and the condition of those components, the LED may progress past blinking amber and move to solid amber. If the LED does not progress past blinking amber it indicates that the system is not able to properly distribute power to the system components. This is discussed in the next section of the interaction.
It does not indicate that the power supply is bad. It simply indicates that, for whatever reason, one of the power supply 'rails' is not operating within its specified range or, simply, that there is a short somewhere in the system.
The LED state could be the result of a misconfigured or incorrectly installed system component. A bad drive, for example, may be shorting out one of the rails. Incorrectly installed memory can cause a blinking amber front panel power button LED.
Feb 05, 2009 | Dell PowerEdge 1800 Server
ALERT LED light - Blinking Amber - Nothing prints, printer not recognized
The blinking amber light means there is a hardware problem. Got that from Netgear's website because we have a similar problem here. I don't know if it means hardware problem in the print server or in the printer. We put the print server on a UPS Uninterruptible Power Supply and that problem seems to be gone. We are in an old factory and the wiring is not so reliable. Maybe you could try this same fix.
Nov 28, 2006 | NetGear PS101 Mini Print Server Print...
Toshiba 26LV47 26 in. LCD TV/DVD Combo Logo
726 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
