Cars & Trucks Logo
Posted on Jun 04, 2008
Windsheld removel how to take mouldings of to change the windshield
  • Anonymous Aug 09, 2008
    Need to replace my windshield, are these glued in? '83 300sd
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 10, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
63
Points
Na they not glued in how ever there is a art to taking them out better off letting a glass place doing it if you not sure what you are doing. [email protected]
2answers
Water ingress on fiat punto 2009 passenger side floor
Do you have heat ? Water leaks or engine coolant?
If all above ok
you have dirt on the water channel of sunroof if got one.
OR
clean dirt under the windsheld wipers there is a rubber hose that drives water from the windshield bottom to the engine.
Open hood and look back to the wall you ll see a black rubber pipe its not circular its like a V
2helpful
How do I replace a broken rear quarter glass?
You have to remove the rubber moulding that holds it in place. I would highly suggest a windshield/glass shop for this repair so no moulding/paint damage occurs
Loud whistling noise when 65 to 70 miles an hour
This is sometimes caused by moulding lifting around the windshield and on the panel housing the wiper arms. Sometimes the moulding is affected by temperature. The best thing to do is trial and error taping of a small section of the moulding or the panel covering the wiper arms. What is happening is an edge is poking up and catching the wind. By taping a small section, you are smoothing out the edge that is making noise. Once found, just try removing the tape and then use a clear silicon to fill in the edge gap.
You would be getting water in the vehicle if the wind was coming through the front bottom gasket of the windshield
Drivers side windsheld washer hits to low on windshield
Take a needle and insert it into the windshield washer nozzle, and adjust to the correct position.
2helpful
Driver side wiper gets stuck on side moulding of windshield in windy rainy conditions and on highway at higher speed.
u need to adjust the wiper arm position on its drive shaft spline so when it swings it doesnt hit the shield mouldings...
2helpful
Cabin air filter
it;s under the cowl vent panel.
Cowl Top Vent Panel Removal
  1. Remove the windshield wiper pivot arm (17526) . Refer to Section 01-16 for the removal procedure.
  1. Remove the front door weatherstrip (20530) to access the windshield outside side moulding screws.
  1. Remove the five windshield outside side moulding screws and the windshield outside side moulding (03136) .
  1. Pull the windshield outside moulding (03144) from the windshield glass (03100) .
  1. Remove the three Phillips-head screws from the cowl top vent panel (022A68) .
  1. Remove the three plastic screws by turning them 90 degrees to unlock.
  1. Remove the six pushpins from the front edge of the cowl top vent panel .
  1. Lift up on the cowl top vent panel and disconnect the windshield washer hose (17A605) at the Y-connector.
  1. Remove the cowl top vent panel .
1helpful
Windshield wipers
most of these windshield wiper motors are located right below the windsheld and above hood. you probably have to undo the louvers where the windshield wiper arms are located and it sits in front of the driver side not too bad to swap yourself part itself is about $60 w/old motor turned in
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
xxxxxx xxx
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
