Question about Kenmore Elite HE4 Electric Dryer
Kenmore elite gas dryer won't fire up
Everything on the dryer works but won't ignite and fire up. replaced the sensor and it fired up with flame. tried it a couple of times, worked fine, started drying clothes, same problem, no igniting, no flame. new sensor worked for a short time, now nothing again. why did it work a couple of times, and is the ignitor bad, or what caused it to stop working,?
    Genius:
  • 1,028 Answers
Replace the coils on burner valve ..they will fail sometimes after initial heat up both are in kit change both
Posted on Jun 06, 2008
2 Suggested Answers
  • 177 Answers
SOURCE: kenmore elite gas dryer
Does the ignition glow when you start the dryer? if so you have power to gas valve and ignition system. if not you may have an open thermostat or thermalfuse.
If the ignitor just sits there and glows all day, you have other problems, It could be a gas valve, or ignitor sensor.
Posted on Jun 07, 2008
Kenmore Elite He3 gas dryer (110-92832100) not heating. Igniter glows red for a min or so, drum spins, hear a loud 'buzzing' noise....
The problem could be flame radiant sensor or in most cases the gas valve solenoid coils sitting on top of the gas valves. The radiant sensor must be aligned perfectly with the igniter. The radiant sensor contacts bypasses one of the gas valve solenoid coils and as the igniter heats up it makes the sensor contact trips unbypassing the coil and allowing the gas to flow and be ignited.
The problem is with the solenoid coils,
one with 2-prongs and the other has 3, if the radiant sensor is aligned with igniter and working perfectly but no gas is ignited. The buzzing sound is coming from the coils trying to operate the valves. Replacing both coils is the simple and only viable solution.
Jul 18, 2011 | Kenmore Elite HE4 Electric Dryer
Sometimes does not ignite.
you have a bad timer rotory dial that will not pick up the signal for the ignitor to fire
Jan 30, 2010 | Kenmore 73952 Gas Dryer
Kenmore dryer heats at first then quits
You may have a bad thermocouple. The thermocouple is what "tells" the control unit that the flame is present. If it doesn't tell the control, the control turns the gas off to prevent an explosion.
Jan 02, 2010 | Kenmore Elite HE4 Electric Dryer
Glow plug lights but does not fire gas everything
This is most likely faulty gas valve coils. These electrical coils are located just above the gas valves and when energized, these solenoids open the gas valves and permit the burner to light. If faulty, the gas valves cannot open and the burner cannot light. Due to the difficulty in testing these solenoids, it is recommended that both (all) be replaced at once if any are suspected of being faulty. Hope this helped and best wishes.
Aug 08, 2009 | Dryers
Kenmore Elite HE3 Gas Dryer - Heat flame will not ignite
The Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Jun 20, 2009 | Hotpoint NVL333EY Electric Dryer
Kenmore elite gas dryer doesn't always heat or dry clothes
An intermittent heat problem is probably in the gas igniter circuit. I would first check the flame sensor next to the igniter for dust on the glass cover. If you have a trouble door, you can see if the igniter is working. Sometimes gas valve controls will fail. If you have to replace the whole control, check inside the plumbing for filters.
Apr 22, 2009 | Kenmore Dryers
Heat runs ten minutes than heat shuts off continues to run
I'm thinking the thermostat has failed, it get's too hot and the emergency over temp sensor kills the flame before a fire is started.
Apr 07, 2009 | Kenmore 63942 Dryer
Dryer runs, no heat
hey mark we got this one done.if your ignitor is glowing and its not firing over 2 things flame sensor,but rarley.99 out of 100 will be the valve coils 2 black guys on top of the gas valve with wires going to them.you could use the cheapest brand you can find[ie..frigadire,ge,kenmore,amana.there all the same .on my truck i stocked frigadire because it was cheaper for me and then would make more profit yet charging same price as there brand,you can do it .God bless,tom
Dec 28, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Jun 04, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
296 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
