Question about Dell 3100cn Laser Printer
ERROR 024 -965
WHAT IS THIS ERROR MESSAGE - CONTINOUSLY ASKS TO LOAD TRAY 1
CHECKED TRAY IS PUSHED IN
  • 2 more comments
  • Q Mod Jun 09, 2008
    We're having the same exact problem. No paper jams, correct paper type & size chosen... A solution would be great.
  • Anonymous Jul 11, 2008
    same problem
  • CALM Jul 16, 2008
    There must be something wrong with sensor . . . it always says to load tray 1 . . . which, alas, has plenty of paper in it.
  • Dianne64 Sep 22, 2008
    Same problem...I checked the properties on the printer and the computer both are set for plain paper.
You should check the page setup of the original document. If this is not set to match the paper in the feed then it wont accept it.
I was at this for a while, messing with printer settings and a fair amount of foul language before it clicked....My word document was in letter format. Once I changed this it all worked like a charm!
Posted on Apr 25, 2009
Pull out the paper tray and set aside. Look inside the tray housing towards the back. On the bottom left and right sides you should see white plastic "stops". These stops are required for proper functioning of the paper tray. They are small white "T" shaped hard plastic pieces that snap in to holes at the bottom of the tray housing. (partially visible from the underside)
When you push the tray in, it rolls over these plastic pieces, releasing the spring in the tray, which in turn pushes the paper in the tray up against the printer rollers. Without these properly in place on both left & right sides, the paper will not be able to feed into the printer.
Hope this helps.
Posted on Sep 08, 2009
Just came across this error with one of our users. It was caused by the slider in the tray not being placed in correctly and not on the correct paper size. As soon as the slider was moved and the drawer was closed, the issue was resolved. Hope this helps.
Posted on Sep 03, 2009
I could be wrong but have you checked the paper type and size is the same on both the computer properties and on the printer. If in computer properties you have covers 2 selected then the printer will continue to ask you to load media until you have selected covers 2 on the printer menu.
Posted on Jul 28, 2008
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P2055d Printer
Tray 1 load recycled letter?
Switch off & on once the printer, load papers in both trays, go to system choose file ask to print, when dialog box appears go to properties, select tray2., the shoot print, check its printing or not. If its printing problem in tray1 paper sensor,clean it.Reason why its not taking from tray 2. In menu settings its selected default tray as tray1. if no paper present in tr1 printer ask to press OK choose another tray to print, during this period indicating error.Best to do: clean all paper path sensor tray1 and tray 2 to prevent further errors... Pl revert..best of luck..
Feb 03, 2012 | HP LaserJet 4100dtn Printer
I have an HP Laser Jet 1320. The error light with the triangle and the explanation point is flashing. There is no paper jam. I have turned off the unit and plugged it back in. Can you please tell me what...
Its indicates attention..1. door open 2. cartridge missed 3. no paper in tray 4. paper jam.
open the door there is notch which pushes the switch check notch broken? reinsert the cartridge check, load paper in tray check paper sensor flag strucked. Lift registration assm plate any paper partials under clean it..
Sep 07, 2011 | HP LaserJet 1320 Printer
My LaserJet 4,000N HP printer is giving me an error everytime I print. when printing certain documents I get a message on the printer " tray 1 load plain A" to get past this i have to push ok...
you need to go into your printer properties and make sure when you push print, it's NOT asking to be printed on A4 paper which thats what it sounds like. Make sure its set for exactly what you have in the tray and make sure the printer paper tray setting are set to exactly what you have in the tray also... should this be of any help, please mark as FixYa!! Get Paid To
Sep 01, 2011 | HP LaserJet 4000n Printer
For Sharp AR-M237 Copier/Printer. Tray 1 is showing up as paper size A4. How do we change it to 81/2 x 11?
1. push "custom settings" button
2.select the "tray settings" button on the screen itself
3.select the tray you want to change the paper setting
4.Select the size and type of paper that is loaded in the tray.
The currently selected paper type will be highlighted.
• To change the paper type selection, touch the appropriate type
key.
• To change the paper size selection, touch the appropriate size
key.
• To change the displayed size selections to AB sizes, touch [AB
? INCH].
Message will appear asking you to check the paper in the tray.
hope this helps!
Ryan
Oct 27, 2010 | Sharp AR-M237 Digital Copier
Printer will not kick out document automatically, attention lite keeps flashing. tray 2 selected but always defaults back to tray 1
Sounds like you have a mismatch in the paper you are trying to print on and the paper that is loaded in the printer. HP printers look to feed paper from tray 1 anytime the computer settings don't match the paper loaded in tray 2. Tray 1 is the multi purpose tray and prety much any size paper can be loaded in tray 1. Double check your document settings and double check the paper size loaded in the paper tray 2 and make sure they match. Also try printing a different document to see if the error persists. If it does this on everything you try to print you should also double check teh rear guide in the paper tray. There is a rear guide in paper tray 2. If it slides back too far it will make the printer think that paper longer than 8 1/2 x 11 is loaded. Push the paper all the way forward in the tray and push the rear guide until it is snug with the tail end of the paper stack.
Nov 01, 2009 | HP LaserJet 4700 Printer
Receiving a "load paper" error message; has to do with paper size
Don't know this printer that well. Open tray one and look in the back and see if there is wheel or slider where you can change the paper size.
Apr 10, 2009 | Ricoh Aficio AP410 Laser Printer
Error message on 4050n printer "manually feed hp tough letter"
What error message is on the display?
To solve one common problem, try this: Take out the paper tray. Slide the blue fence at the back away from the paper (toward the back of the tray) then slide it back to the correct position for the size of the paper. Replace the paper tray and see if the error message still appears.
Jan 20, 2009 | HP LaserJet 4050n Printer
Error message unable to print
1.The printer is asking you to manualy load the right size paper.
source tray possibly tray 1
2. The printer has finished printing the first side of a manual-duplexed job and is waiting for the pages to be reloaded so it can print the second side. Reload the pages.
3.you are trying to print to the source (tray) and there is no paper in the selected tray. laod paper trays.
4. The print image is larger than size of paper in the tray. Load the right size paper. Press go Button
Jan 02, 2009 | HP LaserJet 2550L Printer
OPTRA T610 NOT PRINTING FROM TRAY1
What happens is that the rubber roller that's supposed to pick paper up and load it in doesn't pull the paper from the tray anymore, hence it gives the paper jam error message. If you want you can replace that rubber roller to fix the problem, however first thing I do is to take that rubber roller out (remove tray and look underneath to find the roller) and turn it inside out then fit it back. This will give the rubber roller the grip that it missed and solve your problem.
Jul 13, 2008 | Lexmark Optra T610 Laser Printer
Dell 3100cn Laser Printer Logo
8,541 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
