Question about Canon PowerShot A75 Digital Camera
Trouble Downloading Pics
Whenever I connect my camera to the computer through the ubs cable, the computer does not acknowledge that I have connected it. If I then use the camera icon to download, it says it cannot read (or loacte) the device. The camera takes pictures fine and I have printing pictures off the card at a kiosk with no problem. Any ideas?
    Novelist:
  • 130 Answers
Here are the steps to take.
1. Establish whether or not you have a connection between your camera/computer by going to your start button, control panel, system, hardware tab and device manager. The camera must be powered on and in playback mode (should automatically go to playback mode when connected, camera's screen should go black if there is a connection). Make sure you have a fully or nearly fully charged battery in your camera.
2. Once in device manager, look under Imaging Devices. If your camera is properly connected it should show up as Canon Powershot SD800. If it shows a yellow exclamation point, there is a driver issue, and even if it doesn't show a yellow exclamation point, you may want to update your driver anyway by right clicking and having the system search automatically for driver updates. If download of driver begins, great...once finished, restart camera and your problem may be resolved. There may also be a driver available for download on the Canon website if you log onto www.powershot.com and go to the download library, select your camera from the menu and select your operating system from the dropdown menu. Look for TWAIN or WIA driver.
3. If there are any other imaging devices, you may have to temporarily disable them to avoid conflicts.
4. If you have any other imaging software running, exit or close the program in your system tray (down by your clock in the right hand corner of your computer's desktop.
5. Try again to connect.
6. If you are on a desktop, try a rear usb port vs. a front port. You can also try a different port on a laptop. After each change, try restarting camera to establish connection.
7. Go to start/My Computer and look for the icon for your camera...you will be able to download images even without Canon software loaded onto computer so this is not a software issue if you have no hardware connection. If you see the icon, right click on it and choose Get or Import pictures. From there the default Microsoft scanner and camera wizard should launch and you will be able to import your images.
8. If still no connection, try going to Start/Run and type in services.msc here you are looking for 4 services to be running. Check under status of each service and make sure it reads that each of these services are started.
  • Canon Camera Access Library 8 (if Canon software loaded)
  • SSDP discovery service
  • Universal Plug and Play Device Host
  • Windows Image Acquisition
Once all of these services are started on your computer, restart camera once again. If any of the last three services are not on your computer or are not started, connecting will be a problem.
If all of these steps fail, try purchasing an SD card reader from your local electronics store for around $12 and download images from there. Canon also offers lifetime technical support for your Powershot, so give them a call if none of these steps work or if you would like someone to walk you through it.
Best of luck to you!
MrsJGreen
Posted on Jun 09, 2008
I plug in the usb cable but nothing opens up I was downloading my pictures to my labtop, it froze so after disconnecting the usb cable, reconnecting, the sound acknowledges the connection, but nothing...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jul 04, 2010 | Canon IXUS 960 IS Digital Camera
Cable for downloading pics to pc is not recognized by pc.
Consider NOT connecting your camera to your computer.
May 21, 2010 | Pentax Optio 50 Digital Camera
CABLE CONNECTION
Use a card reader instead of your camera.
Nov 28, 2009 | Canon PowerShot A620 Digital Camera
Having trouble downloading my pics from my camera. It does not seem to connect.
Check if your USB cable is connected properly.
Check if you need to on the camera after plugging in USB in the computer
Check if you need any software before connecting the USB or your USB needs specific software provided by your Camera Manufacturer.
If it does not help, please let me know then I will let you know some alternates to resolve this issue.
Kind Regards,
KK
Oct 30, 2009 | Dell Dimension C521 PC Desktop
Pc will not recognize that the camera is connected
Apr 04, 2009 | Fuji FinePix S5100 Digital Camera
"SAVE WIZARD PICTURE" does not launch
yes i think u all are having problems in fuji fine pix viewer i think this peace of software is not updated with vista OS so nothing to worry just try alternate source to do this
just connect usb cable supplied with camera and connect ur camera it will show up as a removable disk in my computer open it up and download the pics if u have trouble doing it , first check if ur camera is set to PC = webcam mode and other mode icon means file transfer mode u need to select this mode from menu>setup>usb mode and then go download the pics on pc as described no need for drivers
if u have trouble i can arrange for pics to do that with a diagram
if anything else i can help
pls rate me fixya if i have fixed ur problem
Feb 13, 2009 | Fuji Finepix Z20fd Digital Camera
Trouble downloading pics
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Oct 14, 2007 | Canon PowerShot A70 Digital Camera
Sd600 digital camera trouble downloading pics to computer
Hmmm... Yea sometimes the pc doesn't see the added gizmo your camera. In which case, I suggest when you connect camera to computer click on "my computer" and you should see your device listed there along with your C drive & so on. Click on the camera icon & viola, you can copy the images from there to your computer. Yea I had the same experience with PS too, well Elements in particular. And there is a setting (somewhere in Elements Browser window) to turn it off. Yea to simply download images - it doesn't require any software at all with XP. I use a card reader & rarely deal with using the camera cable to computer hook up. To use that device you'll remove the card from the camera & stick in the reader & its ALWAYS worked for me. Again you'll have to click on "my computer" to find the images there. Otherwise --- next step would be to try another usb cable.
Jun 24, 2007 | Canon PowerShot SD600 Digital Camera
Canon sd600 trouble downloading images to computer
Did you checked that your existing camera's drivers are supported the Win Xp OS ?
Canon PowerShot A75 Digital Camera Logo
105 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
